Link to image
Was parked on Wilson Ave a few metres back from Erskineville rd on Sunday Nov 14th between 2pm and 430pm
DISTINCT THINGS
I rebuilt this and made a few odd modifications:
- Front crank has had one chain ring CUT off to make it a single speed (can see the grinding work done on the crank)
- is not a true single speed hub, rather uses a conversion kit (17 tooth ring)
- handle bars have not been cut down cleanly
- front forks have a slight backward bend to them
- cable routing on top tube has been ground off
- cable routing on left side of down tube has been ground off
