For those riding 6061 T6 or other aluminium frames
Rob74
Postby Rob74 » Fri Nov 08, 2013 1:08 am
An interesting read
Anyone had a Tange Fusion II Aluminium Road Fork fail?
Rob
HappyHumber
Re: For those riding 6061 T6 or other aluminium frames
Postby HappyHumber » Fri Nov 08, 2013 1:32 am
Why do you ask about those Tange forks?
Just curious, as I have one that looks very similar. Same crown and is aluminium. Bought with a Columbus EL-OS frame. I've yet to finish building it up, but I have had some niggling, maybe unfounded, doubts about aluminium forks in general.
- Kym
Nobody
Postby Nobody » Fri Nov 08, 2013 6:41 am
HappyHumber wrote:Why do you ask about those Tange forks?
Your doubts about Al forks failing over the long term are hardly unfounded. I have a problem with the way an Al fork can let go with little warning. As a comparison, here's an example of a steel fork that couldn't take the strain, but failed slow enough to be noticed. Suffice to say that I prefer steel forks.
Nobody
Postby Nobody » Fri Nov 08, 2013 6:52 am
Thanks for posting Rob.
From the brief read I get the impression that 6013-T6 must be more expensive as I'm sure the bike companies already know what lasts 3.5 million cycles, but won't make them as much profit. It appears they are aware that the few original owners who ride far enough to make a frame fatigue fail are a minority.
Postby find_bruce » Fri Nov 08, 2013 7:21 am
Nobody wrote:Suffice to say that I prefer steel
:shock: :shock: :shock: when did you reach this epiphany ?? :lol: :lol: :lol:
Nobody
Postby Nobody » Fri Nov 08, 2013 7:47 am
About 1992 when I heard about (then expensive) Al MTB frames cracking. :)
Rob74
Postby Rob74 » Sat Nov 09, 2013 10:21 am
Re HappyHumber » Fri Nov 08, 2013 12:32 am
"Why do you ask about those Tange forks?"
Steel is real & That Tange Fusion II is fitted to a 1989ish Shogun Team Issue.
Rob
Postby il padrone » Sat Nov 09, 2013 11:07 am
It was about 40 years ago when the Viscount Aerospace bikes came out as the latest great thing. Then the failures began........
It had a very cool TA crankset and rings though 8)
