Chain jammed inside front chainring and downtube ...
Rural Rider
Postby Rural Rider » Mon Jan 01, 2018 11:09 pm
Cheers all.
Got back from a ride today and noticed when putting the bike away that the chain has jumped off the small cog of the front chainring and is good and jammed against the downtube. I don't want to do damage to the Carbon frame or paint if I can help it (2017 Trek Emonda SL6) ... it won't budge with my fingers. The chain is sitting midway on the rear cassette - I'd appreciate some good advice on getting it clear and re-seated.
I'm assumung I'll just need to remove/adjust the chainring and crank arms yes?
Thanks gents! 8)
2016 Specialized Allez e5 Sport
jackthelad
Re: Chain jammed inside front chainring and downtube ...
Postby jackthelad » Tue Jan 02, 2018 1:12 am
Sram is one 8 mm allen key easy job ,
undo retighten once chain is loose
shimano, do you have the tension cap tool?
undo the bolts , release the black wafer thing in the cranks, release the tension in cap,
reverse to retighten , me i just do one good yank, it be free
look at your shifting when you have it out
SantaCruz HighTower LT
SantaCruz Blur XC Carbon
Kona Kula Supreme
Ribble Rd Bike
Postby trailgumby » Tue Jan 02, 2018 12:59 pm
I'd recommend a K-Edge chain keeper. Bolts on over the top of your FD using a longer bolt. Due to my hybrid 10/11spd front setup, I used to drop the chain once every 2-3 rides. Not anymore.
https://www.google.com.au/search?rlz=1C ... 8bEBS4s6P0
jackthelad
Postby jackthelad » Tue Jan 02, 2018 1:59 pm
Go Single ring.... or chain keeper, whichever works best for u
Kona Kula Supreme
Ribble Rd Bike
headasunder
Postby headasunder » Tue Jan 02, 2018 6:14 pm
+1 to the chain keeper it removes fear factor, very ocassionly when I down shift up front there is a clatter as the keeper does it job certainly beats the alternative
Kronos
Postby Kronos » Wed Jan 03, 2018 9:40 pm
A back pedal should usually unjam something like this.
Baalzamon
Postby Baalzamon » Wed Jan 03, 2018 11:35 pm
BV great ride, had this happen very very badly to a rider and had to take the cranks off to fix it. Paint was damaged and a bit of a gouge on the carbon.
Rural Rider
Postby Rural Rider » Thu Jan 04, 2018 12:45 am
Thanks for the tips gents!
I haven't the tools to fix this at home myself right now so will take it to the local Mech to get sorted and will definitely be installing a chain catcher as recommended! I can see there is already a little paint removed where the chain is jammed but hopefully no gouging to the Carbon Frame ... I don't want this happening again - and while usually OCD about damage or blemishes on Bikes, it's down where you can;t see a thing. Local Bike dealer is the Dealer I bought from so perhaps they have a little touch up paint on hand as well.
Cheers RR.
RobertL
Postby RobertL » Thu Jan 04, 2018 10:28 am
If you can't find the right touch up paint, try nail polish. It comes in a million different colours and is great for touching up those sort of chips.
Rural Rider
Postby Rural Rider » Fri Jan 05, 2018 12:38 am
Good tip on the fingernail polish ... tough for me though I'm not sure it will be easy to find such an odd shade of flat metalic grey/black DNISTER BLACK for my Trek. Worst come to worst I could get a mix from a spray shop to a price.
jackthelad
Postby jackthelad » Sun Jan 07, 2018 3:46 pm
Just use clear nail polish, its just to seal the frame, not get fancy
Kona Kula Supreme
Ribble Rd Bike
