Fork 6 ways damaged just by riding on it!
Re: Fork 6 ways damaged just by riding on it!
Postby Nobody » Wed Jan 02, 2013 7:47 am
il padrone wrote:Tom just needs to take account of the fact that it has a 1" steerer tube, not the much stronger 1 1/8" that MTBs have. It should be fine for routine riding for many years, but doing kerb drop-offs, pulling wheel stands or other tricky stuff will significantly shorten the fork's lifespan. For any sort of stunt riding he'd need a much tougher MTB, preferably a jumps bike as he's a big lad.
Agree. Never had a crack in the steel 1 1/8" forks I have. Although lighter then, I used to give my Giant rigid 1 1/8" fork a hard time in MTB cross country racing. But it's still going 20+ years later. Because I still jump up & down curbs and regularly do stoppies in emergency braking practice at the end of my rides, I don't ride any 1" steerer frames anymore. I'm 82Kg currently.
Nobody
by BNA » Wed Jan 02, 2013 8:02 am
Postby spirito » Wed Jan 02, 2013 8:02 am
il padrone wrote: .... unfortunately, Speedwells never were much more than average road bikes.
il padrone wrote:BTW I am talking about Speedwells from the late 70s through to whenever the brand finally died out.
I'd agree with you re: 70's but you could have made that clear in your first statement.
Fwiw, I know of at least one frame builder that worked at Malvern Star during the late 40's and early 50's tin Sydney that believed the Speedwells (made by Smith Sons & Ree's just down the road) where clearly better made bikes.
I have been fortunate enough to own a few very good Spedwell's from the 30's to the 60's and some truly stunning Speedwell's have pass through my hands over the years. As I mentioned they also produced some very ordinary bikes as well, they had quite a wide range as was common by many Australian bike manufacturers.
spirito
Postby il padrone » Wed Jan 02, 2013 8:28 am
My comments needed to be taken in context - stated in relation to the OP's bike - clearly not any sort of vintage Speedwell.
This is not the retro forum :wink:
Postby brentono » Wed Jan 02, 2013 9:42 am
wqlava1 wrote:
brentono wrote:Merits of hard wood inside the steerer tube. :idea:
(though it looks like the rust got to it)
:mrgreen:
To stop the steerer pulling away from the lugged crown centre hole?
(And I like your choice of French Blue powdercoat, which I have for my Velosmith as well as Tom's fixie.)
Safety was your priorty.
"the crack between the steerer tube and the top of the fork crown"
Was pointing out, the continuous strain from the original crack, and twisting of the crown,
may have been alleviated with hard wood inside the steerer tube. Brake bolt goes through
crown,steerer tube and the wood, giving support. Also help to prevent sheering.
Was a safety point, and quite utilised back in the day (B.C.=before cyclepaths) on racing cycles.
:mrgreen:
Blues Good :D
Lone Rider- I rode on the long, dark road... before I danced under the lights.
brentono
Postby Nobody » Wed Jan 02, 2013 10:38 am
brentono wrote:Blues Good :D
So, do you use hardwood in that Time steerer, or are you more trusting of modern Al?
Nobody
Postby spirito » Wed Jan 02, 2013 12:34 pm
Nobody wrote: So, do you use hardwood in that Time steerer, or are you more trusting of modern Al?
Apparently, wood has quite a high carbon content (approx. 46 - 55%) ...
http://www.sciencedirect.com/science/ar ... 3403000333
spirito
Postby spirito » Wed Jan 02, 2013 12:35 pm
The whole of the interwebs is the retro forum (one day) :mrgreen:
spirito
Postby brentono » Wed Jan 02, 2013 1:00 pm
Buy it (for sale on Mkt Place) and find out :wink: :P :lol:
(as you are probably un?-aware, only works on "vintage" lugged forks)
:mrgreen:
brentono
Postby Nobody » Wed Jan 02, 2013 1:59 pm
So it must be good. Steel has carbon in it too, so Al must be the evil one. :wink:
brentono wrote:(as you are probably un?-aware, only works on "vintage" lugged forks)
:mrgreen:
Thanks for the reply. :)
Nobody
Previous
Users browsing this forum: David J
