campagnolo 10spd chain
Postby silverlight » Thu Nov 06, 2008 9:48 pm
I need to remove a chain from current setup bike and im wanting to know, is there a link i need to remove becasue i cant seem to find one although its oiled up well or can i use a chain remover tool with these chains to remove the link and then put it back.
or is it better i replace the chain altogether. chain has probably done 2000-3000kms
thanks SL
Postby brakepad » Thu Nov 06, 2008 10:40 pm
Do a search on Google.
The Park Tool website has something with lots of pictures.
Hope that helps. Or maybe someone here has better information.
Postby sogood » Fri Nov 07, 2008 6:40 am
Current Campy 10 speed chains are not designed for regular removal. If you need to break a chain, then you also need to use one of their chain link (6 links sold separately) or a third party quick link to rejoin it. They do not recommend using the same pin to rejoin the chain at the same link position.
