Removing oldschool cranks
ZiggySS
Postby ZiggySS » Sun Nov 23, 2008 8:13 am
Hello guys,
I have basically stripped all the components of my 1975 centurion for my SS project.
The only part which i connot get of is the cranks! ... They are a much older style to what im used too.
They Have a little screw wich had a nut on the end which i have removed. DO i have to hit the actual bolt out ?
I would post some pictures but not past the time peroid !
Any tips much apreciated!
Postby familyguy » Sun Nov 23, 2008 9:09 am
You need one of these or these.
Any LBS will have a variant model (IceToolz or SuperB tool).
[/img]
ZiggySS
Postby ZiggySS » Sun Nov 23, 2008 9:23 am
Hey Jim,
This wont work on the type of oldschool crank .. If only i could post a picture ...
I will Pm you the link and could you chuck the link up ! not past the seven days ! bugger
gclark8
Postby gclark8 » Sun Nov 23, 2008 9:38 am
I have an old Centurion here, it has the normal square drive cotterless crank, just buy a cheap BBB (or similar) crank puller. :wink:
NO HAMMER!! :roll:
George.
Lark2004
Postby Lark2004 » Sun Nov 23, 2008 9:40 am
does it look like one of these?
If so, then yes you have to tap out the cotter pin with a hammer, it may be jammed in quite hard, as they are tappered, and probably haven't been moved for many years.
Postby familyguy » Sun Nov 23, 2008 9:54 am
ZiggySS wrote:Hey Jim,
Ah, old-old-old school...see Larks post about cotter pins.
ZiggySS
Postby ZiggySS » Sun Nov 23, 2008 9:59 am
Yeah it is kinda like that ! its called a RS super silver .. I will PM you the pic Larks !
Cheers for the help champs
Lark2004
Postby Lark2004 » Sun Nov 23, 2008 10:19 am
These are the cranks in question......
Are you planning on re-using these cranks for the rebuild? or were you going to upgrade to some slightly more modern cranks?
I would suggest that you may want to avoid hitting the pin directly with a hammer if you want to re-use the cranks. Use a bit of hardwood in between, and also give it a good soak in WD-40 for a few days before you try to remove it.
On the other hand, if you don't plan on using those cranks, just bash away.
One thing how ever that you must do, is to rest the crank on a solid peice of wood, right beside the pin. That way, when you hit the pin, you won't be transfering any shock or force etc..... into the frame.
ZiggySS
Postby ZiggySS » Sun Nov 23, 2008 10:39 am
Hey thanks mate !
I dont plan on re using these cranks they are in a bad way only think im re using is the frame and the drops..
One more thing im hitting the part of the pin that is sticking out ? Is that right ? (just want to be sure i dont make things worse !)
Lark2004
Postby Lark2004 » Sun Nov 23, 2008 10:46 am
If the part thats sticking out is threaded, then yes, thats what you need to be hitting.
IF you don't think you can budge it.... you could also just cut the bottom bracket axle. you don't want to use an angle grinder for this, they are too much for a bike.....a hacksaw with a 32tpi blade will do, it is hardened steel, so take your time if you go down this path.
HappyHumber
Postby HappyHumber » Sun Nov 23, 2008 12:20 pm
The great sage Sheldon Brown (RIP) has a page on the subject of cotter pins. Probably more info than you need - but worth a skim over
- Kym
AzzA
Postby AzzA » Sun Nov 23, 2008 2:27 pm
Ahh, i had to remove cotter pins from two bikes yesterday.
A hammer worked perfectly. The first one i stuffed up a bit though, as i had to hit it a few times with the hammer, so i ended up bending the thread end of the pin a little. Afer that i learnt if you just give it one solid whack with the hammer it comes out perfectly and can be re-used.
I just read Sheldon Brown's info and it was spot on with my experiences yesterday.
Postby il padrone » Sun Nov 23, 2008 3:05 pm
It can also be helpful if you leave the nut on the cotter, wind it to flush with the end. Sit a peice of hardwood on the nut, and give it one good whack with your hammer. Usually works quite well.
A long time sinceI worked with cotter pins now. But I had them on my old tourer for 3-4 years in the 70s, and worked a couple of jobs in bike shops and for an assembler in the early 80s. Glad to get away from the cotter pins :)
Postby munga » Sun Nov 23, 2008 6:21 pm
mmm cotter pin scars on your ankles..
