bottom bracket
bottom bracket
Postby scott71 » Wed May 20, 2009 9:07 pm
- trailgumby
Re: bottom bracket
Postby trailgumby » Wed May 20, 2009 9:17 pm
Tools to DIY can be had for about $35, and then you can look after yourself, plus save 30%+ buying online. You pays your money and takes your choices.
Re: bottom bracket
Postby master6 » Wed May 20, 2009 9:18 pm
What type of bottom bracket axle do you have?
The fact that you have a steel frame is unimportant, as the items fitted to it could be any of many makes, models , and styles?
Are you a competent cycle mechanic?
My view is that tools are not all that expensive, and once purchased can be used again of course.
Let us know more information and people will be better able to help you
Re: bottom bracket
Postby scott71 » Thu May 21, 2009 5:47 am
- m@
Re: bottom bracket
Postby m@ » Thu May 21, 2009 9:04 am
There are a couple of traps for young players though - different tools may be required to remove the old bottom bracket if it's the old lockring style (you can easily tell by looking at the exterior of the old bb, and older ones can generally be removed with a hammer and cold chisel to avoid buying a tool for only one use). You also need to make sure the new bb has correct spindle length (again, easy to do by measuring the old one before removal).
- ValleyForge
Re: bottom bracket
Postby ValleyForge » Fri May 22, 2009 8:20 pm
Re: bottom bracket
Postby brauluver » Sat May 23, 2009 9:40 am
Ride into Nth Adelaide cycles and have a chat with kim(friendly/helpful) he'll probably give you a ball park quote on the spot.scott71 wrote:My bottom bracket on my road bike (steel) has way too much play in it, how much would a bike shop charge to replace it. I would buy a crank puller but figure by the time i buy that and the bracket it would be easier just to get them to do it. I dont want to get ripped off thou. Last time i had it done it cost 120 and that was a few years at least. cheers.
Re: bottom bracket
Postby rkelsen » Mon Jun 01, 2009 1:14 pm
How are you managing the second mortgage?ValleyForge wrote:... I now use a Phil Wood BB. Suddenly it's been one less bit of a bike to worry about.....
- ValleyForge
Re: bottom bracket
Postby ValleyForge » Mon Jun 01, 2009 4:02 pm
- hartleymartin
Re: bottom bracket
Postby hartleymartin » Wed Jun 03, 2009 8:54 pm
Re: bottom bracket
Postby thomas_cho » Thu Jun 04, 2009 10:50 am
The sealed units are really a fit and forget item.
The only hitch with removing old bottom brackets is that you might require more leverage to make the thing budge. That requires the bike to be securely held, and the tool to sit securely.
I once tried to remove my bottom bracket from my Colnago frame, I didnt have a way to hold the frame and tried bracing it with my feet. Just could not generate enough leverage to budge it, so brought it to my LBS, and it took them 2 mins to get it off, and no charge. Obviously I made sure I bought some bar tape before I left the shop.
Pays to support your LBS and have a good relationship with them.
Re: bottom bracket
Postby ausdb » Thu Jun 04, 2009 11:45 am
The trick is to put the BB tool in a vice and then turn the frame around it, that is if you are using something like a shimano or cyclo tool that is designed to be held in a large spanner or such. For an added bit of security put a bolt through the tool with a large washer under its head and thread it into the bottom bracket to keep the tool captive whilst you hoik on it.thomas_cho wrote: The only hitch with removing old bottom brackets is that you might require more leverage to make the thing budge. That requires the bike to be securely held, and the tool to sit securely.
Re: bottom bracket
Postby thomas_cho » Thu Jun 04, 2009 12:33 pm
My tool that came with the tool kit used a socket wrench, and could not be secured using the QR skewers either.
- lemmiwinks
Re: bottom bracket
Postby lemmiwinks » Thu Jun 04, 2009 12:36 pm
