Yes , i'm having some computer issues....
I'm having a TOPEAK COMP 150. (wireless)
After having it not used for a month i was getting incorrect speeds...
So i just assumed bad battery , so i replaced both battery's...
Resetted the topeak , and done...
No , not done...
The problem is consistent....
It doesn't work in the mornings on my commute..., but does work in the afternoon on the way home...
When the bike is inside , i spin the wheel...it works, i go outside riding...nothing
The only thing i can think off is the temperature...
So i tryd "shivers" putting the bike in the colder shed instead of the warm house...
But again, no speed on the way to work , bnut works perfectly on the way home...
Any ideas? , suggestions??
cycling computer issues...
- damhooligan
Postby damhooligan » Tue Jun 23, 2009 6:53 pm
The dutch have one word to describe the aussie MHL, this word is ;
SCHIJNVEILIGHEID !!
SCHIJNVEILIGHEID !!
- philip
Re: cycling computer issues...
Postby philip » Tue Jun 23, 2009 7:36 pm
I've got that same computer, had it for about 2 years now, it works great for a cheaper computer. I did have an issue on hot (> 30) days if it was in the sun too long, it would go very dim and sometimes turn off. I had another problem where it occasionally turned off when I hit bumps, but found the battery contacts weren't great so gave them a good wipe and since then it's worked fine.
Your problem sounds pretty strange though, the fact it works inside and not out - perhaps some sort of interference?
- CoffsGal
Postby CoffsGal » Tue Jun 23, 2009 7:43 pm
Not using a LED headlight when outside are you...they have be known to interfere with computer operation...
- collect:emit
Postby collect:emit » Tue Jun 23, 2009 9:32 pm
Mate I have a cheap Cateye copy on my MTB commuter and i found that LED lights cause them to go nuts
are you riding in the morning with your light on?
Malvern Star OPPY Bol D'or 09 [url] http://www.thelegendisback.com.au/url]
Haro Flightline 1
Wish List - Matching Oppy Jersey and arm warmers (Hint MS, HINT!)
Haro Flightline 1
- damhooligan
Postby damhooligan » Wed Jun 24, 2009 5:26 pm
ThX Guys.
It could be the lights...
They are on in the mornings , and off in the arvo...
(and off when is test the speedo by spinning the wheel)
I have two off them. so they could cause interference.
Wil try to adjust them in the morning...
SCHIJNVEILIGHEID !!
SCHIJNVEILIGHEID !!
- grosry
Postby grosry » Wed Jun 24, 2009 5:49 pm
Maybe try it now (or when you get a chance) and turn the lights on then off while spinning the wheel inside and see if it is the problem!damhooligan wrote:ThX Guys.
"Pain is temporary. It may last a minute, or an hour, or a day, or a year but eventually it will subside and something else will take it's place. If I quit however, it will last forever." - Lance Armstrong
- damhooligan
Postby damhooligan » Wed Jun 24, 2009 5:58 pm
grosry wrote:Maybe try it now (or when you get a chance) and turn the lights on then off while spinning the wheel inside and see if it is the problem!damhooligan wrote:ThX Guys.
Yeah i was thinking that...
but am a bit lazy at this stage...
Mayby i wil try it later...
SCHIJNVEILIGHEID !!
SCHIJNVEILIGHEID !!
- damhooligan
Postby damhooligan » Thu Jun 25, 2009 4:28 pm
damhooligan wrote:grosry wrote:Maybe try it now (or when you get a chance) and turn the lights on then off while spinning the wheel inside and see if it is the problem!damhooligan wrote:ThX Guys.
Problem solved...
The lights were the problem, moved the light...Fixed...
ThX for your help.
SCHIJNVEILIGHEID !!
SCHIJNVEILIGHEID !!
Postby msavage8 » Wed Jul 01, 2009 12:02 pm
I too have a bike computer that was affected by my LED light. I have tried moving the light as far away from the comp as possible but still get interference when on flash mode. I've been told that some wireless comps use analog and are more affected, while those that use digital wireless are usually fine. Has anybody else heard this?
- m@
Postby m@ » Wed Jul 01, 2009 12:17 pm
My Sigma BC-1606 DTS (digital wireless) drops out whenever my CREE LEDs are on flashing mode, low or mid beam. No problem when they're on high, until the batteries are almost flat and the torch starts to die.msavage8 wrote:I too have a bike computer that was affected by my LED light. I have tried moving the light as far away from the comp as possible but still get interference when on flash mode. I've been told that some wireless comps use analog and are more affected, while those that use digital wireless are usually fine. Has anybody else heard this?
I've seen things you people wouldn't believe
- justD
Postby justD » Wed Jul 01, 2009 8:12 pm
You guys rock!!
I've been going insane with this computer. Speed is wireless and cadence is wired, so I ripped the cadence magnet and fitting off thnking I could at least get my speed/distance back, but obviously didn't help.
Just tested it now and problems start as soon as I put the light on flash.
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
