Drum Brakes
- hartleymartin
Drum Brakes
Postby hartleymartin » Sun Jul 12, 2009 12:18 am
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Tue Jul 14, 2009 3:49 pm
- zozza
- leximack
Re: Drum Brakes
Postby leximack » Tue Jul 14, 2009 4:34 pm
zozza wrote:I think I saw some at the Powerhouse once
Re: Drum Brakes
Postby LittleWheelsandBig » Tue Jul 14, 2009 5:46 pm
F&S used to make rounder drums than English SA, which often used to judder a little. I haven't used the larger SA drums but the Sunrace-made 70 mm drums are pretty good.
Re: Drum Brakes
Postby Low Racer » Tue Jul 14, 2009 6:40 pm
I have SA drum brakes on my Greenspeed GT3II trike and it is far superior to rim brakes on my recumbent bike. Drum brakes needed to be bedded in and once you have achieved that, they are really good brakes for dry and wet conditions. You do pay the weight penalty though.hartleymartin wrote:I know that drum brakes are inferior in performance to rim brakes, but I figure that since I typically use chromed steel rims which are almost useless in the wet, that drum brakes might be good on one of my roadsters.
Re: Drum Brakes
Postby LittleWheelsandBig » Tue Jul 14, 2009 7:05 pm
Little wheels help drum brakes perform much better.Low Racer wrote: I have SA drum brakes on my Greenspeed GT3II trike and it is far superior to rim brakes on my recumbent bike.
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Tue Jul 14, 2009 10:03 pm
I was looking at purchasing a sturmey-archer front dynohub, but they don't make a plain dynohub any more. They all come with drum brakes on them. I've thought of the possibility of using cable-operated drum brakes both front and rear on a newer utility bicycle to ensure better all-weather performance.
Re: Drum Brakes
Postby Chaderotti » Tue Jul 14, 2009 11:30 pm
I guess it's the same as different rotor diameter in disc brakes. A smaller diameter will virtually have the same stopping power as a larger roter, but heat up and wear out faster.hartleymartin wrote:In my mind I had reasoned that larger drum brakes would be more powerful, but I thought I had better ask around to see if anyone could confirm it.
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
- Zynster
Re: Drum Brakes
Postby Zynster » Wed Jul 15, 2009 9:53 am
Re: Drum Brakes
Postby rkelsen » Wed Jul 15, 2009 10:53 am
And begin to fade quicker.Chaderotti wrote:I guess it's the same as different rotor diameter in disc brakes. A smaller diameter will virtually have the same stopping power as a larger roter, but heat up and wear out faster.
Bigger surface/contact area is always better with any kind of brake, if only for heat dissipation & therefore fade resistance. Excess heat in brakes is always bad.
You know, you could avoid all this simply by using aluminium rims, HM... What with all the talk of a drop handlebarred, derailleur geared bike, your integrity has come into question anyways...
Re: Drum Brakes
Postby LittleWheelsandBig » Wed Jul 15, 2009 12:31 pm
Most of the disc and drum brakes I've used have increased power as the size increases (for the same design).Chaderotti wrote: I guess it's the same as different rotor diameter in disc brakes. A smaller diameter will virtually have the same stopping power as a larger roter, but heat up and wear out faster.
- WyvernRH
Re: Drum Brakes
Postby WyvernRH » Wed Jul 15, 2009 4:52 pm
Also, depends if they are leading or trailing shoe activated or twin leading shoe activated (assuming we don't go into the exotica of more than two brake shoes)LittleWheelsandBig wrote:Most of the disc and drum brakes I've used have increased power as the size increases (for the same design).Chaderotti wrote: I guess it's the same as different rotor diameter in disc brakes. A smaller diameter will virtually have the same stopping power as a larger roter, but heat up and wear out faster.
The twin leading shoe design is more complex/expensive but works considerably better than the simple leading shoe design.
Trailing shoe activation sucks.
Most bicycle brakes are leading shoe activated with only one pivoting cam pushing one end of the two shoes apart and into the brake drum. The twin leading shoe activated brake was standard on British motorbikes before disc brakes became popular and has two pivoting cams linked by a rod so the two shoes are pushed evenly apart into the brake drum. As a motorbike brake it was very effective when properly adjusted.
As a young engineer new to bicycles, I modified and old Sturmey front to be twin leading shoe using my BSA Rocket's front brake as a model and found several problems.
(1) Way too powerful for a solo bicycle on the front, very easy to put yourself over the bars. Maybe better on a tandem, or the rear wheel
(2) Not a lot of 'feel' (see point one ), it came on really quickly (maybe my design needed tuning a bit, less leverage perhaps)
(3) The amount of force you could generate pushing the pad onto the drum caused the brake hub to heat up very quickly (and excessively) if used on long hills, or with hard repeated braking, causing the hub to get REALLY hot so the grease melted out the bearings and the rivets holding the hub together eventually came loose.
(4)The reverse load on the spokes seemed to cause a lot of spoke breakages but again it could have been my dodgy wheel building at the time.
Maybe someone would like to try a modern conversion? I have a suspicion that most modern aluminium hub brakes would just not be up to the stress.
- trailgumby
Re: Drum Brakes
Postby trailgumby » Wed Jul 15, 2009 7:12 pm
No. Definitely not. Larger diameter rotors are definitely more powerful.Chaderotti wrote:I guess it's the same as different rotor diameter in disc brakes. A smaller diameter will virtually have the same stopping power as a larger roter, but heat up and wear out faster.
I had a 7" disc on the front wheel of my original commuter. It was a lot more sudden and had to be used with a lot of care in the wet, especially with skinny commuter tyres. I have since gone back to 6" discs all round. 7" was a lot more brake than I needed.
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Wed Jul 15, 2009 8:46 pm
I've just had a crazy thought with a bicycle which has 4 brakes. Now hear me out:
Front Brake 1: Rim operated by right brake lever
Front Brake 2: Hub operated by lever mounted near stem
Rear Brake 1: Rim operated by left brake lever
Rear Brake 2: Coaster
This gives me rim brakes for normal riding conditions, but also gives me a back-up braking system for wet conditions. Having a coaster brake would limit me to a 3-speed hub, as no 5 or 8 speed hubs are currently made with a coaster option, although Shimano did make a 7-speed hub with coaster brake, it is now out of production.
An alternative 3-brake design (again for drop handle-bars) would have:
Front Brake 2: Hub operated by lever mounted near stem.
Rear Brake: Hub operated by left brake lever
This would allow me to use a 5 or 8-speed hub which has a drum brake.
I've read some of Sheldon Brown's stuff on braking and he reckons that only a front brake should be used in dry conditions, but preference should be given to the use of rear brakes in wet weather conditions. Having a drum brake on the rear (which is not affected by the wet as much as rim brakes) would work well with this sort of braking technique.
I've got some new wheels on the way. The front wheel has a Shimano dynamo hub, and the rear wheel has a Sturmey-Archer SRC3 3-speed coaster braked hub. The bicycle they will be going on is going to have rim brakes front and rear anyway, as I feel as my left hand feels lonely for a brake lever.
- il padrone
Re: Drum Brakes
Postby il padrone » Wed Jul 15, 2009 9:10 pm
No, no!hartleymartin wrote:Just throwing around some ideas with bicycle brakes:
Much beeter option is available:
Rear Brake 2: Disc operated by friction lever at stem, running on Rohloff 14 sp hub
- bigfriendlyvegan
Re: Drum Brakes
Postby bigfriendlyvegan » Wed Jul 15, 2009 10:00 pm
And disk brakes on each wheel.
And a stick to put between the spokes if all else fails.
If you're really keen you could adapt the technology from hybrid cars and use the friction from the braking to recharge a battery for your lights.
David
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Wed Jul 15, 2009 10:11 pm
- WyvernRH
Re: Drum Brakes
Postby WyvernRH » Thu Jul 16, 2009 6:25 am
Been done, many times with varying degrees of success. You would have to come up with a really radical improvement to get your Msc or PhD Unless you really want to home build you would probably just be re-inventing the wheel (no pun intended) but you could assemble a system from pre-made parts fairly easily.hartleymartin wrote:Regenerative braking from an electric hub motor has been considered, but at the moment I do not have the money for a hub motor kit, battery and the electrical gear required to do it. And of course, I've enrolled in an Arts degree, not Science. It would make a good thesis project for science.
Try http://www.atob.org.uk/questionselectric.htm for some basic info and pointers to more complex stuff.
Re: Drum Brakes
Postby kukamunga » Thu Jul 16, 2009 8:02 am
Re: Drum Brakes
Postby Chaderotti » Thu Jul 16, 2009 11:18 am
2. front wheel: disc brake operated by lever mounted on hoods
3. front wheel: hub operated by lever mounted on right side of stem
4. rear wheel: rim brake operated by left brake lever
5. rear wheel: disc brake operated by lever mounted on hoods
6. rear wheel: coaster brake
7. foot on rear wheel
8. stick
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Thu Jul 16, 2009 5:58 pm
- trailgumby
- hartleymartin
Re: Drum Brakes
Postby hartleymartin » Sat Jul 18, 2009 5:32 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
