I'm thinking of downgrading some parts from Ultegra to 105?
Postby amt » Fri Aug 14, 2009 10:37 pm
So I'm considering replacement parts the chain and the cassette. To my mind after research and reading the many threads on the topic there's no advantage to using more expensive parts if they don't give better performance or indeed weigh substantially less.
Prices from PBK
Chain:
105 $44.74 280g
Ultegra $51.74 280g
Dura Ace $66.03 280g
Cassette 10spd
105 5600 $83.63 219g
Ultegra 6600 $98.84 235g what's going on here its heavier
Dura Ace 7800 $238.24 173g
I do want to find from you what is the life of a chain and cassette, yes I know this will depend on various factors so I will qualify the question with my riding. I average 150-200km a week with only a few rides in the wet by that I mean around 500km a year. TIA.
Re: I'm thinking of downgrading some parts from Ultegra to 105?
Postby Pushy » Fri Aug 14, 2009 11:27 pm
06' Giant TCR C1
08' Colnago CLX
07' Apollo Swift
VW Jetta Diesel 5.5l/100km
Postby Chaderotti » Fri Aug 14, 2009 11:58 pm
Basically, downgrading makes sense unless you got the dough to splurge.
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
- Christine Tham
Postby Christine Tham » Sat Aug 15, 2009 7:26 am
I just replaced a 105 cassette with Ultegra, and it shifts a lot faster and more accurately. Again, the improvement could simply be the difference between worn and new, but the old cassette looked pretty good (I changed wheelsets, hence bought a new cassette, as the old one stays with the old wheelset).Pushy wrote:Did that a few months ago, now riding a 105 cassett and chain and I could not tell the difference. Well it was actually an improvement due to a worrn cassett and chain.
In my mind, the difference in price between Ultegra and 105 was worth it. If Ultegra was double the price, I probably would have stayed with 105.
- Rockford
Postby Rockford » Sat Aug 15, 2009 7:46 am
Ultegra
11-23 204g
12-27 239g
But that is bugger all weight difference in either case.
Postby thomas_cho » Sun Aug 16, 2009 8:55 pm
Postby lukas » Sun Aug 16, 2009 9:25 pm
I've swapped between 105, Ultegra and DA chains and haven't noticed a great difference, but have noticed a difference between 105 and ultegra cassettes.
If you're hellbent on saving the cash, then definitely go for 105, because at the end of the day it'll still do the job. If your priority is better performance then look at Ultegra.
Canyon Ultimate AL
- geoffs
Postby geoffs » Sun Aug 16, 2009 9:29 pm
Other parts are all dura-ace
- Christine Tham
Postby Christine Tham » Mon Aug 17, 2009 7:49 am
Is is really that much difference? I bought my Ultegra cassette for around A$75.lukas wrote:I guess it comes down to how much that $7 per chain and $35 per cassette means to you.
Oh, I just realised 9 speed pricing is very different from 10 speed. In particular, Ultegra 9 speed pricing seems to be a lot lower, and also very similar to 105 pricing.
Postby colafreak » Mon Aug 17, 2009 9:31 am
Chains and cassettes are not branded 105 or Ultegra, they are branded "Hyper Glide" and then the model number.
I recently pulled apart the rear wheel of an "Ultegra" specced bike and it had the same hyperglide model number as my 105 equipped bike.
Unfortunately I can't remember the model number (6600, maybe?).
If you consult 3 websites for the weights of bike parts, you'll get 4 answers, the variations you've found between "ultegra" and "105" chains/cassettes are just due to other factors (eg. number of sprockets).
If someone wants to sell you an "ultegra" chain, you're being ripped off.
- Christine Tham
Postby Christine Tham » Mon Aug 17, 2009 10:04 am
Ultegra and 105 parts have different model numbers, and there's even a chart that shows you which model numbers correspond to which series.
Maybe your "Ultegra" bike had 105 cassette or vice versa (I notice a lot of manufacturers do that, substitute slightly inferior parts where the brand name is not visible).
- twizzle
Postby twizzle » Mon Aug 17, 2009 10:46 am
Maybe for nine speed, but ten speed they all have different part numbers and wording on the chain links. The main difference in the 'cooking' versions is the plating used. The 7900 (Dura-Ace) chains are quite different with hollow pins and cut-outs in the side plates. As for cassettes - Ultegra have alloy spacers between the cogs instead of the plastic ones used for 105.colafreak wrote: If someone wants to sell you an "ultegra" chain, you're being ripped off.
Postby waynohh » Mon Aug 17, 2009 11:19 am
- Thoglette
Postby Thoglette » Mon Aug 17, 2009 11:49 pm
If it was "6600" it was an Ultegra cassette - 105s should be 5500 (or some other four digit number starting with a 5). Durace starts with a 7colafreak wrote:I recently pulled apart the rear wheel of an "Ultegra" specced bike and it had the same hyperglide model number as my 105 equipped bike.
Postby amt » Thu Aug 20, 2009 12:23 pm
Postby petal665 » Thu Aug 20, 2009 12:50 pm
- m@
Postby m@ » Thu Aug 20, 2009 2:28 pm
Why d'ya say that? I mean, you're probably right - we get all sorts here after all - but appropriate maintenance and expected chain/cassette life really depends on usage - someone who rides 1000Km per week in all weather conditions will need to clean and lube far more frequently than someone who rides a few hundred Km and doesn't ride in the wet - and will still get fewer Km out of their chains and cassettes.amt wrote:Thanks guys. I've just clocked over 4000km and my chain and cassette show minimal signs of wear. Looks like many members perhas don't regularly maintain their chain and cassette. I do a quick clean once a week and a thorough clean every month.
- casual_cyclist
Postby casual_cyclist » Thu Aug 20, 2009 3:38 pm
Because it's true? On one bike I have never cleaned the chain. On my main bike I have cleaned it twicem@ wrote:Why d'ya say that?amt wrote:Thanks guys. I've just clocked over 4000km and my chain and cassette show minimal signs of wear. Looks like many members perhas don't regularly maintain their chain and cassette. I do a quick clean once a week and a thorough clean every month.
I have ordered a new chain and cassette promise to maintain them
Postby amt » Thu Aug 20, 2009 7:35 pm
I concur, that's why I pay even more attention to cleaning after a wet ride. I commented how I see people here replacing parts on a regular basis and I think If people paid more attention to maintenance then you would save money. Part of the reason for the original post was to see what people thought about life of these parts and why I qualified the question with regard to my useage.m@ wrote:Why d'ya say that? I mean, you're probably right - we get all sorts here after all - but appropriate maintenance and expected chain/cassette life really depends on usage - someone who rides 1000Km per week in all weather conditions will need to clean and lube far more frequently than someone who rides a few hundred Km and doesn't ride in the wet - and will still get fewer Km out of their chains and cassettes.amt wrote:Thanks guys. I've just clocked over 4000km and my chain and cassette show minimal signs of wear. Looks like many members perhas don't regularly maintain their chain and cassette. I do a quick clean once a week and a thorough clean every month.
On a side note I was talking to a riding buddy who just had a major service on his bike, this was carried out by a reputable bike shop in Adelaide and the mechanic didn't replace the chain or the cassette. Now this bike has not had a new chain or cassette for almost 3 years so he would have travelled many thousands of km's. I did ask my friend to call the mechanic and ask him about those particular parts. The funny thing about all this is that he thinks I'm maticulous with my bike as he doesn't do any maintenance what so ever.
Postby petal665 » Thu Aug 20, 2009 9:08 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: 2wheels_mond, warthog1
- All times are UTC+11:00
