Best Degreaser
Best Degreaser
Postby bemper » Sat Apr 10, 2010 11:20 pm
What the best degreaser to use to clean bike chain?
If you don't mind sharing the reason why and where to get some and possibly price?
I was hoping this thread can help newbie like me to figure out what product out there and learning the differences in them.
Thanks,
bemper
- Mulger bill
Re: Best Degreaser
Postby Mulger bill » Sat Apr 10, 2010 11:45 pm
For mine, kero's the go.
Shaun
- gclark8
Re: Best Degreaser
Postby gclark8 » Sun Apr 11, 2010 12:27 am
George.
Re: Best Degreaser
Postby Colin_T » Sun Apr 11, 2010 1:09 am
Re: Best Degreaser
Postby master6 » Sun Apr 11, 2010 8:35 am
Re: Best Degreaser
Postby LG » Sun Apr 11, 2010 8:41 am
Re: Best Degreaser
Postby }SkOrPn--7 » Sun Apr 11, 2010 9:35 am
Re: Best Degreaser
Postby stevepedlin » Sun Apr 11, 2010 9:42 am
Re: Best Degreaser
Postby Nobody » Sun Apr 11, 2010 9:55 am
Having said that, if you like cleaning, go ahead. Chains are cheap anyway.
Re: Best Degreaser
Postby brendancg » Sun Apr 11, 2010 2:57 pm
Best not to use petrol, it is corrosive and will eat away at the chain.
- Rockford
Re: Best Degreaser
Postby Rockford » Sun Apr 11, 2010 8:50 pm
Or I just use my ultrasonic cleaner.
Re: Best Degreaser
Postby bemper » Sun Apr 11, 2010 10:14 pm
Was told by a few LBS not to use kero with bike. Is this true?gclark8 wrote:Kero, then lube with Inox. (Bunnings)
http://www.inox-mx3.com/product_detail. ... PLICATIONS
- m@
Re: Best Degreaser
Postby m@ » Sun Apr 11, 2010 10:43 pm
Did they also happen to casually mention that what you should use is the degreaser they sell?bemper wrote:Was told by a few LBS not to use kero with bike. Is this true?gclark8 wrote:Kero, then lube with Inox. (Bunnings)
- Mulger bill
Re: Best Degreaser
Postby Mulger bill » Sun Apr 11, 2010 11:52 pm
Shaun
Re: Best Degreaser
Postby bemper » Mon Apr 12, 2010 12:32 am
Yes, but, I counter with the idea of using Australian Export degreaser.. and they said any water-based degreaser are fine. But, I think I seen a few thread they are more dangerous than using degreaser.m@ wrote:Did they also happen to casually mention that what you should use is the degreaser they sell?
http://www.hpa.org.uk/HPA/Topics/Chemic ... 313434474/
A price on a 1L degreaser is $6.95, so not sure whether or not it is due to price or kero is much better cleaner (since it's probably stronger)
http://www.supercheapauto.com.au/online ... 52#details
Btw, how do you use it? Do you spray the chain or the cassette?
Re: Best Degreaser
Postby zero » Mon Apr 12, 2010 1:52 am
I stick some kero in a tin, pull the chain off (wipperman link is good for this) and soak the chain. Amongst other things it dissolves the lube thats on the inside of the link plates, which then causes the grit that has inevitably built up there (and is busily wiping itself onto the roller/pin/plate junction and crushing itself between the teeth and the chain) to fall off the chain. If you fiddle about with the chain on the bike, that stuff just stays there, and you have to put more effort in than soaking it too. If I have enough time, I'll clean the sprockets too - which is easier to do with the chain out of the way.bemper wrote:Yes, but, I counter with the idea of using Australian Export degreaser.. and they said any water-based degreaser are fine. But, I think I seen a few thread they are more dangerous than using degreaser.m@ wrote:Did they also happen to casually mention that what you should use is the degreaser they sell?
- m@
Re: Best Degreaser
Postby m@ » Mon Apr 12, 2010 6:59 am
Kero is also reusable - after soaking the chain I let it sit then pour off the clear stuff into a jar.
- HappyHumber
Re: Best Degreaser
Postby HappyHumber » Mon Apr 12, 2010 8:51 am
+1, +1m@ wrote:+1 to zero's technique, I have quick-links in all my chains and have been known to remove and soak the cassette and chainrings as well
I've bought a 4L bottle of Kero and it is lasting ages. Occasionally these days just buy a 1L "top-up" bottle to allow for spills & evaporation. Rather than let it settle I strain mine through coffee filters into the bottle to be reused. It looses its pretty blue hue quickly, but it's just as effective. Observe crud caught in the coffee filter to see how much stuff you've cleaned out. (yes, it is slow to filter, arguably not as slow as merely decanting and more effective if the bottle is then disturbed.)
I too use master links on the chains and re-use the little clear-with-yellow-top 1kg honey containers (poor mans tupperware) partially filled with kero as a shaker & cleaner. Other parts get a soaking.
But I think a lot of us are just repeating what's already been said on other threads hereabouts
- Mulger bill
Re: Best Degreaser
Postby Mulger bill » Mon Apr 12, 2010 9:04 pm
+1 To all Kyms words, except the honeypot. I still swish about in a dish made of an old 4l kero bottle.HappyHumber wrote:+1, +1m@ wrote:+1 to zero's technique, I have quick-links in all my chains and have been known to remove and soak the cassette and chainrings as well
Shaun
- Zoiks
Re: Best Degreaser
Postby Zoiks » Sun Apr 18, 2010 6:46 pm
While I have read this technique in other places. Some articles I have browsed have advised against soaking in a degreaser. Reason being that the oil in the internals of the chain is put there for a reason and is hard to replace if removed. Instead they suggest just wiping the chain with a degreaser (if anything).This may or may not be true, just something I read.zero wrote:I stick some kero in a tin, pull the chain off (wipperman link is good for this) and soak the chain. Amongst other things it dissolves the lube thats on the inside of the link plates, which then causes the grit that has inevitably built up there (and is busily wiping itself onto the roller/pin/plate junction and crushing itself between the teeth and the chain) to fall off the chain. If you fiddle about with the chain on the bike, that stuff just stays there, and you have to put more effort in than soaking it too. If I have enough time, I'll clean the sprockets too - which is easier to do with the chain out of the way.bemper wrote:Yes, but, I counter with the idea of using Australian Export degreaser.. and they said any water-based degreaser are fine. But, I think I seen a few thread they are more dangerous than using degreaser.m@ wrote:Did they also happen to casually mention that what you should use is the degreaser they sell?
Re: Best Degreaser
Postby MiG » Mon Apr 19, 2010 12:39 am
Care to explain? As far as I know that's bollocks.brendancg wrote: Best not to use petrol, it is corrosive and will eat away at the chain.
Re: Best Degreaser
Postby rustybucket » Mon Apr 19, 2010 3:22 pm
- Cinder
Re: Best Degreaser
Postby Cinder » Mon Apr 19, 2010 4:12 pm
Don't do a lot of it though.
I regards to the petrol thing, not sure about pushies but I have heard that story in regards to other types of chains that have rubber/plastic seals in them. Someone with better knowledge of pushie chains would be able to elaborate I guess.
- pagey
Re: Best Degreaser
Postby brendancg » Mon Apr 19, 2010 9:02 pm
It is the chemical makeup including such things benzene and sulfur that cause the damage. These are not additives but in the makeup of the petrol itself. While not going to destroy the chain overnight it will cause damage if used continually.MiG wrote:
