Spending too much time making this thing...
- blokeinamoke
Postby blokeinamoke » Fri May 21, 2010 7:46 pm
finished that one in around an hour and a half (yes im slow and crap at soldering....) attach to cycling glove and hazzah!
a little basic at the moment and obviously needs a bit of refinement but its fun!
yeh just a note... this is the first one and its for use on my flat bar roady.... ive got a second set in the woodworks for use when in the drop-downs... just a little harder with the tilt switches is all...
Just thought id share...
-Matty
Re: Spending too much time making this thing...
Postby Chaderotti » Fri May 21, 2010 8:16 pm
Hell instead of a PCB you could put everything into some sort of flexible plastic/silicone.
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
Postby zues » Fri May 21, 2010 8:18 pm
I hope you make a million
- blokeinamoke
Postby blokeinamoke » Fri May 21, 2010 8:23 pm
the LED's are already 5.5mm dont know how much larger i can get? already is just a 3v Li cell, as for the flex plastic silicone, if i could i would, but i dont know where to start!Chaderotti wrote:Don't know whats on the other side but you could chop down that PCB quite a bit. Less but larger LEDS, little single cell lithium polymer cell in a small pouch sown on to the glove.
Postby Chaderotti » Fri May 21, 2010 8:54 pm
The picture isn't too fantastic so it's kinda hard to see.blokeinamoke wrote:the LED's are already 5.5mm dont know how much larger i can get? already is just a 3v Li cell, as for the flex plastic silicone, if i could i would, but i dont know where to start!Chaderotti wrote:Don't know whats on the other side but you could chop down that PCB quite a bit. Less but larger LEDS, little single cell lithium polymer cell in a small pouch sown on to the glove.
If you're looking for a business partner...
Postby Mark Kelly » Fri May 21, 2010 10:53 pm
If you need some help designing the printed circuit PM me. If what you want is simple enough I'll do it for free.
BTW you could incorporate a tilt sensor so the thing turned on automatically when you put your hand out.
Postby Chaderotti » Fri May 21, 2010 11:46 pm
are those even legal anymore?
- hartleymartin
Postby hartleymartin » Sat May 22, 2010 12:56 am
There are some pretty powerful far tinier LED's out there. Your idea looks good. I'm just wondering whether or not it is a good idea to try and integrate them into a glove. Could they be worn like a wrist-watch on both wrists? Could you integrate some sort of timer chip to make them flash like indicators?blokeinamoke wrote:the LED's are already 5.5mm dont know how much larger i can get? already is just a 3v Li cell, as for the flex plastic silicone, if i could i would, but i dont know where to start!Chaderotti wrote:Don't know whats on the other side but you could chop down that PCB quite a bit. Less but larger LEDS, little single cell lithium polymer cell in a small pouch sown on to the glove.
I'm not nit-picking, I think that it's pretty brilliant of you to come up with that. I'm just not convinced that glove-mounted ones are such a great idea. Stick a pair onto some gloves and I'll be happy to be proven wrong.
- blokeinamoke
Postby blokeinamoke » Sat May 22, 2010 2:22 am
hartleymartin wrote:There are some pretty powerful far tinier LED's out there. Your idea looks good. I'm just wondering whether or not it is a good idea to try and integrate them into a glove. Could they be worn like a wrist-watch on both wrists? Could you integrate some sort of timer chip to make them flash like indicators?blokeinamoke wrote:the LED's are already 5.5mm dont know how much larger i can get? already is just a 3v Li cell, as for the flex plastic silicone, if i could i would, but i dont know where to start!Chaderotti wrote:Don't know whats on the other side but you could chop down that PCB quite a bit. Less but larger LEDS, little single cell lithium polymer cell in a small pouch sown on to the glove.
Yeh, i was thinking that originaly Marto, but it had already been done, so im trying to take that idea, compress it and put it nicely integrated into a glove (with obvious change in design to incorporate summer gloves, winter gloves etc...)
or perhaps i could make it with 2 silicone loops, a big one for the wrist and a small one for a finger or 2 that way it can just slip onto and over any glove... thats a nice idea... means having to figure out how people make those silicone things first!
Thanks for all the input guys.
-Matty
Postby Chaderotti » Sat May 22, 2010 2:54 am
The stuff I've seen which is supposedly 'silicone' is a two part mixture, mix up both parts then put into some sort of mold (clay) for several hours. The mold could consist of all the channels and cut outs for the leds?
- AUbicycles
- Site Admin
Postby AUbicycles » Sat May 22, 2010 7:05 am
One thing I would try, is putting 3M reflective tape behind the LEDs - so when signaling you also get the advantage of car lights reflecting.
One negative is that typically they will always be on - so probably distracting when riding (blinding at night) so if you havn't already though about it you would need to think about some kind of proximity setup (like a smart card) so that they only light up when your hands move away from the handlebars. The circuit is broken when you hands are on or close to the handbars. A few different solutions for this.
For interest, check out LEDwear who have waterproof jackets and backpacks with LEDs and see how they integrate the LEDs. While it will be challenge to build your own in a similar fashion, it is a good reference.
I look forward to more.
Christopher
Postby Mark Kelly » Sat May 22, 2010 10:12 am
- blokeinamoke
Postby blokeinamoke » Sat May 22, 2010 2:02 pm
Thanks for the info Mark, did you get my PM perchance?
-Matty
Postby Stuey » Sun May 23, 2010 6:33 pm
Dunno, but I think either Jaycar or Altronics still sells them. They also sell the 'rolling ball' type.Chaderotti wrote:mercury switches?
- Nate
Postby Nate » Mon May 24, 2010 8:50 am
Use a normally closed type of switch, just go into jaycar & have a look.
or you could mount the switch to the back of a finger - when your hand is closed its off, open the hand & straighten the fingers & its on - it'd be more comfortable
Chad is on the money with the bracelet (sorta) - forget mounting it on the back of the palm, its a very odd shape & it changes when you move your hand making a good fit close to impossible.
Get a bracelet going instead - even pinch one of those dodgy silicone ones & tinker with it.
3 super bright LEDs & you should be away.
maybe something like: http://www.jaycar.com.au/productView.as ... BCATID=635
All you need is a battery & switch - i'd forget circuitry too complex & will start to consume power, keep it simple
