PRO DIGI - X10 Computer - HELP
Narara01
Postby Narara01 » Mon Jul 26, 2010 6:24 pm
Hi all,
I have just upgraded from 700x@*'s to 23's and have found that the instructions for my cycling computer are missing.....
ARGHHHHH!
Does anyone out there have the same model and could let me know the correct code for the new tyre size?
Cheers.
Myddraal
Re: PRO DIGI - X10 Computer - HELP
Postby Myddraal » Mon Jul 26, 2010 9:05 pm
It shouldn't make any difference. You're only changing the width of your wheel, not the circumference.
lethoso
Postby lethoso » Mon Jul 26, 2010 9:11 pm
Myddraal wrote:It shouldn't make any difference. You're only changing the width of your wheel, not the circumference.
wider tyres will also have a greater height
Narara01
Postby Narara01 » Mon Jul 26, 2010 9:57 pm
Even though it would only be a small difference..... I do recall there being a difference in the codes between almost all tyre sizes....
Oh well, the search continues....
Any help would be really appreciated
hillclimber
Postby hillclimber » Mon Jul 26, 2010 10:06 pm
700 x 23 is about 2133 (the diameter)
Hope that helps.
Narara01
Postby Narara01 » Mon Jul 26, 2010 10:20 pm
hillclimber wrote:700 x 23 is about 2133 (the diameter)
Hope that helps.
Thanks Hillclimber, just punched it in with no issue.....
I'll pace myself against a mate tomorrow to check all is good.
Cheers.
Myddraal
Postby Myddraal » Mon Jul 26, 2010 10:51 pm
If all you needed was the circumference, not a particular code why didn't you just measure it? You can use google, wolfram alpha or the calculator on your computer if you don't have a scientific one handy.
http://www.google.com.au/search?q=2*Pi*647
...the more you know.
hillclimber
Postby hillclimber » Mon Jul 26, 2010 11:04 pm
Hope that helps.
Meant to say circumference, sorry.
Narara01
Postby Narara01 » Wed Jul 28, 2010 8:49 pm
Myddraal wrote:If all you needed was the circumference, not a particular code why didn't you just measure it? You can use google, wolfram alpha or the calculator on your computer if you don't have a scientific one handy.
Yep, now I know.... I thought initially that the number to enter was a manufacturers code, but have since learnt the obvious!
Thanks everyone for your help.
Users browsing this forum: chyaroh, piledhigher2, The Great Boffo
