Adding a front disc to a road bike !! And Now Hydro!
Re: Adding a front disc to a road bike !! And Now Hydro!
Postby MichaelB » Tue Jan 15, 2013 11:20 am
OK, so discs still worked well, but the pads wore quicker than anticipated (because they hadn't encountered these conditions before) because the pad material was not suitable for the conditions.
So from the comment from rkelsen (thanks for that), were there hyd disc brakes in the race ? Or was it just supposition of how they'd potentially perform (sensible conclusion though) ? Mind you, no one mentioned that the disc pads fully wore out, just they wore pretty quick. Mind you, it also sounds like the 'pads' only covered half the race distance too.
It's called a learning experience.
Experience now is then to use different pads (ticker, better material, hydraulic system) for similar conditions.
Fix the CAUSE not the effect.
Going back to canti's is fixing the effect (whilst the pads may last longer, how well does the braking compare ?) and not the cause.
Thicker pads would weigh SFA compared to the extra mud that gets caked on the bike during the race ....
MichaelB
by Forum Ads » Tue Jan 15, 2013 11:46 am
Postby Nobody » Tue Jan 15, 2013 11:46 am
rkelsen wrote:Discs are meant to shine in these conditions. This is proof that they're not all that they're cracked up to be and that there is no perfect, one-size-fits-all solution when it comes to bicycle brakes.
Since this thread is about disc brakes on road bikes, it isn't that relevant. However, if rim brakes were indeed better off-road, I'm sure MTB XC racing would be using them exclusively.
rkelsen wrote:The largest obstacle when it comes to disc brakes on a bicycle is weight. If you want better braking, you need bigger, thicker [and therefore heavier] discs and pads... But then you have to push all that extra weight.
The largest obstacle to forward motion on a road bike is aerodynamics, since the average climbing of a road bike rider is ~1%.
I just weighed my new EBC sintered pads to find they are 24 grams. Most of that would be backing plate weight. I'm sure this would matter on the WW forums.
Nobody
Postby rkelsen » Tue Jan 15, 2013 12:39 pm
Nobody wrote:Since this thread is about disc brakes on road bikes, it isn't that relevant.
<dons flame suit>
A "road" bike with disc brakes is a CX bike. There are no road bikes with disc brakes, only CX bikes. Adding disc brakes to a road bike makes it a CX bike.
Flame away. :lol:
MichaelB wrote:It's called a learning experience.
Absolutely. I'm sure that something good will come from this in the development space. It'll be interesting to watch how they handle it.
MichaelB wrote:Going back to canti's is fixing the effect (whilst the pads may last longer, how well does the braking compare ?) and not the cause.
Bad brakes > No brakes... Particularly if you're in a hurry.
volutamus scandemus
rkelsen
Postby Nobody » Tue Jan 15, 2013 1:23 pm
<dons flame suit>
Flame away. :lol:
Oh well, there's some bikes below the manufacturers call road bikes, but you can call them CX bikes if you prefer. Either way people will buy them and ride them on the road. But then many people do that with MTBs too.
http://www.bicycling.com/bikes-gear/new ... ke-preview
Nobody
Postby MichaelB » Tue Jan 15, 2013 1:57 pm
<dons flame suit>
:shock: :? :?:
Qeh ?
Um the following bikes are NOT CX bikes in the slightest ;
Volagi Liscio
BMC GF02
dbikes RACE
Colnago C59
Time Fluidity
Canyon's new roadie (don't remember name)
Handfuls of small manufacturer ones like Lynskey, Crumpton, Rose etc
and some others I can't remember
Oh, Nobody beat me to it ...
MichaelB
Postby barefoot » Tue Jan 15, 2013 2:32 pm
rkelsen wrote:A "road" bike with disc brakes is a CX bike. There are no road bikes with disc brakes, only CX bikes. Adding disc brakes to a road bike makes it a CX bike.
Flame away. :lol:
Adding fat knobby tyres to a road bike makes it a CX bike [1].
The only reason CX bikes have brakes any different to road bikes is that side-pull calipers don't fit over fat knobby tyres (and mud and grass pulp and small furry animals). So, when you add fat knobby tyres to a road bike and make it a CX bike, you necessarily have to figure out a way to make it stop. So that brings the most visible technical difference between road and CX bikes to the table - CX bikes have cantilever or disc brakes.
But that's not to say that road bikes can't have cantilever or disc brakes.
You're not going to fit knobby tyres on one of these:
http://www.bicycling.com/bikes-gear/new-bike-gear-previews/time-fluidity-s
You're not going to ride off-pavement on the 23mm slicks that fill the stays on that bike. It has disc brakes, but it is categorically NOT a CX bike.
tim
who designed his disc braked road bike with more road-like geometry (short chain stays, low BB), because, even though it can fit >40mm knobbies, it's going to spend much more time riding road than it is racing CX. When I have road tyres on it, it's a road bike.
[1] of sorts. Not optimised in terms of geometry and features.
barefoot
Postby toolonglegs » Tue Jan 15, 2013 5:00 pm
I think the issue was the pads wore so quickly that they went out of adjustment... ie hydraulic would have kept the pads close to the disc, but the cable systems obviously can't do that. Longer wearing pads would have helped slow the need for adjustment down.
Nobody, yes they were on CX bikes... but CX bikes being aloud to run discs in UCI events is one of the main reason manufacturers like SRAM are spending the money on development of these systems... which will obviously filter across to being used on the road only.
Postby Crittski » Tue Jan 15, 2013 5:08 pm
I love riding my road bike with hydraulic discs, I don't care what others may wish to call it - road bike/CX bike/piece of shite ugly bike what difference does it make??. Discs work, and are perfect for road bikes... I really don't get what all the fuss is about!
Its about picking the right tool for the job, at the moment there are a few little experiments being run, but we live and learn...
Santa Cruz Blur TRc XTR
Volagi Liscio Ultegra
Crittski
Postby baabaa » Tue Jan 15, 2013 5:08 pm
Things are starting to blur.
Watch the Paris Roubaix and you will see quite a few riders still opt for cantis and this is really is a road race with dirt and cobbles. Blokes like Lars Boom (best name in cycling) who comes from a cyclocross background has ridden a cross bike in that race. Some even opt for cross top levers.
I doubt many cx riders really need solid/ hard braking and time will tell if in the mud it helps to have the braking surface on the rim or near the hub. Ice and frozen slush would never be good for mech brakes if it builds up around the pads and cables and this is probably why discs are rare in the euro pro circuit.
Discs are ideal in Aust type dirt gravel once you match the power to the correct tyres and psi
The point I see from the velonews bit is that in line adjusters really work for on the go bb7 adjustment and yes on longer (100k) dirt races I carry a torx key so you can adjust pads quickly if needed.
baabaa
Postby cooperplace » Thu Jan 17, 2013 8:47 pm
I haven't followed this thread much lately, so this may have been covered. I've but a BB7 and a 180mm disc on the front wheel of my Ti-framed road bike, and while it's good, I think that a hydraulic front disc would cope better with what seems to an inevitable small run-out in the disc. I almost never use the back brake. So what I would like is a single cable-to-hydraulic adaptor so I could fit a hydraulic front disc. It seems there's a kit for front and back, but I only want front. Any thoughts?
Sorry if this has been covered.
Please be nice to me, I'm not very bright.
cooperplace
Postby Nobody » Thu Jan 17, 2013 11:08 pm
cooperplace wrote:I almost never use the back brake. So what I would like is a single cable-to-hydraulic adaptor so I could fit a hydraulic front disc. It seems there's a kit for front and back, but I only want front. Any thoughts?
It's like you read my mind. I was only thinking about this a couple of days ago. I'm happy to keep a rim brake on the back for now.
I'd also prefer a converter instead of a full master cylinder lever as my shifters are inboard of the levers (DA DTs on Kelly Take Offs). Therefore the last time I crashed and wrecked a lever, it only cost me $25 for new levers. Even if I were to use STI/Ergo, a mechanical lever is going to be cheaper to replace after a crash than a hydro lever. I'd say in CX, crash replacement may be a factor which keeps converters being sold.
I hope that someone decides to sell them individually in the future. Or maybe that new TRP HY/RD could be a hydro option (from page 45 of this thread).
http://www.bikeradar.com/news/article/n ... kes-36104/
Nobody
Postby Mark Kelly » Fri Jan 18, 2013 7:29 am
USE were talking about twin converters a couple of years ago. haven't heard anything for a while.
http://road.cc/content/news/45111-cycle ... -converter
Mark Kelly
Postby barefoot » Fri Jan 18, 2013 8:11 am
cooperplace wrote:I've but a BB7 and a 180mm disc on the front wheel of my Ti-framed road bike, and while it's good, I think that a hydraulic front disc would cope better with what seems to an inevitable small run-out in the disc
A smaller rotor will cope better with runout.
I had a relatively flexy fork on one of my MTBs, which had a 180mm rotor. It scraped and rubbed and pinged all over the place. I converted down to a 160mm rotor and it was perfect.
Just the extra diameter means any relative runout is, effectively, amplified at the braking surface. And any flex, leading to small angular misalignment between the fork leg (= caliper mount) and the rotor, will also be amplified at a bigger diameter.
I'm running 160mm rotors on my road bike because that's what came in the box. They rub a little, occasionally, but they're still bedding in and they rub less every tweak. I reckon they'd be even less prone to rubbing with 140mm rotors... with the corresponding trade-off in performance, of course. I'm happy with the 160s for now.
tim
barefoot
Postby barefoot » Fri Jan 18, 2013 8:55 am
I'm loving my rear disc probably more than the front - for really gentle drags, to control speed gently in a bunch. That's where the modulation of discs is awesome. precise progressive control from almost nothing, right up to lockup.
Of course, there's no real reason to do these drags on the rear. It's just habit, to stay off the front brake unless I really need some serious stopping power. But I'm lovin' me some double-disc braked roadie :-D
tim
barefoot
Postby MichaelB » Fri Jan 18, 2013 9:28 am
Hi Peter,
haven't seen anything that will do a single front only.
One thing that may be worth trying is a different style of rotor - maybe the Shimano Ice-Tech or a Hope floating rotor may solve some of the issues ?
Cost is minimal, and is an easy way to try.
MichaelB
Postby MichaelB » Fri Jan 18, 2013 9:36 am
Mulger bill wrote:
MichaelB wrote: I'm aming for 7kg all up for my double disc Volagi Liscio (when the frame finally arrives), and can't wait to ride it.
180mm disc on the front and 160 rear :D
You better post loooooottts of pics... :D
Still hasn't artrived yet, but frames are meant to be landing about end of the month :)
Whilst mine will have different running gear, I reckon the frame paint scheme I'll get is the same as use on the Rival setup. It will match the rest of the components well ;
High level spec will be as follows (with balance of weight and price as key factors) ;
FS Carbon 29er rims 28/32 spoke with CM hubs - 1,421g
SRAM Red BB30 Crank with Praxis rings (compact)
Ultegra 6700 shifters, FD & RD
Brooks Team Pro Ti saddle
3T Ergonova Team Bars & Stem
TRP Parabox hydro converter
RT86 Ice-Tech discs (180/160mm)
Michelin Optimum Pro 25C tyres
Tillquist Garmin mount
Should be well under 7.5kg all up, ready to ride
Can't wait ..... :mrgreen:
MichaelB
Postby baabaa » Fri Jan 18, 2013 9:38 am
tim
Hmm same here, rare to use the front only and really do use the rear only way more often than the front or even in combo.
Simple to control and take off speed, still have front to use when really needed.
baabaa
Postby MichaelB » Fri Jan 18, 2013 10:04 am
tim
Yet I'm almost the opposite.
Use the rear brake a bit, but it's more like 80/20 Fr/Rr
Then again, I'm more than different .... :D
MichaelB
Postby MichaelB » Fri Jan 18, 2013 3:22 pm
Oooooohhh ooohhhhh
Guess what :?: :?: :shock: :shock: 8) :mrgreen: :mrgreen:
Road disc frame available from HongFu - FM166
http://www.hongfu-bikes.com/html_products/2013-Disc-brake-Road-Frame-287.html
Looks really interesting.
Anyone know anything else about it ?
MichaelB
Postby baabaa » Mon Jan 21, 2013 8:27 pm
A bit more chatter
Road discs - Industry led bling or the next use of a proven technology?
The industry seems to want them, some riders don't. Personally, I do. There are problems, but they're not insurmountable.
Road discs then. Everyone's talking about them, and quite a lot of people are trying to make them. But they're not ready, yet. Why is that? Personally, I think it's because making discs work in a road bike situation has been a bit harder than people expected. Even though the technology is well proven in a MTB context, there are different considerations and the usage is significantly altered on the road.
http://road.cc/content/blog/73731-road- ... technology
and yet what was old, is new again......
Blanco team bikes also sub in team-only machined aluminum linear-pull brakes instead of the molded carbon composite arms used on production Giant Propel Advanced SL. The material change and chunkier shape certainly add weight – and look to possibly impact the aerodynamic performance, too, at least on paper – a quick pull of the lever reveals that they work quite a bit better, too.
Lever feel is firmer and more positive than on production bikes we've ridden, the cable anchor uses a bigger and more cable-friendly clamp design, and the fully enclosed stainless steel noodle locks into a more secure socket. Team brakes sport a dual-position noodle anchor, too, to more easily accommodate narrow and wide-profile rims without requiring additional adjustment.
http://www.cyclingnews.com/features/pro ... n=features
http://www.cyclingnews.com/features/pho ... -sl/249247
baabaa
Postby cooperplace » Mon Jan 21, 2013 10:33 pm
MichaelB wrote:Hi Peter,
Hi Michael,
that's a great idea, thanks, I'll try a Hope floating rotor.
Hope all is well with you,
cheers,
Peter
cooperplace
Postby cooperplace » Mon Jan 21, 2013 10:35 pm
tim
Hi Tim,
I had a 160mm rotor and wanted more braking, so I went to 180. I would use 200 but it doesn't fit. 160 doesn't give anything like enough braking, for me.
cooperplace
Postby warthog1 » Wed Jan 30, 2013 1:06 pm
I am after a road disc fork with a 370-380mm axle to fork crown measurement for my Azzurri primo, that is now a commuter. It needs to have eyelets for a mudguard also.
the closest I can find so far is this It is very heavy, nice and cheap however which is a good thing.
Does anyone know of a reasonably priced, lighter alternative?
warthog1
Postby baabaa » Wed Jan 30, 2013 1:15 pm
TPR self adjusting dual mechicals plus full cable hydros.....
http://www.bikerumor.com/2013/01/29/trp ... /#comments
Quite like the thinking of the mechs, size looks right too. Prices will probably keep me sitting on my hands
baabaa
Postby jasonc » Wed Jan 30, 2013 1:39 pm
baabaa wrote:TPR self adjusting dual mechicals plus full cable hydros.....
now we're getting somewhere
Users browsing this forum: Bing [Bot], Oscar.S, Ross, thecaptn
