MB, FM166 is 130 rear
Adding a front disc to a road bike !! And Now Hydro!Re: Adding a front disc to a road bike !! And Now Hydro!Hmm leaning to 135 now, and yes the two hubs I would use are both 135mm.
I guess that is related to the fact that they are using the FM-066 as the base. I wonder what the rear spacing is on some of the other road disc frames that you see on Alibaba ?
I think you misslept "slightly less bad" tim
Re: Adding a front disc to a road bike !! And Now Hydro! http://www.bikeradar.com/news/article/t ... ils-36756/
Re: Adding a front disc to a road bike !! And Now Hydro!The HY/RD doesn't interest me, but the Quadiem SL does (silly name ...)
![]() From the same article as per jasonc's link above
Now, just gotta work out the piston size in the master cylinder .....
I've been close to getting some BB7s to replace the BB5s on my commuter, but I think I'll hold out until we get a few reviews of the Spyre. Pretty much exactly what I'm looking for, and honestly I can't imagine I'd need anything better (mech/hydro or hydro) for commuting. Though even these are probably a bit overkill for commuting, but sometimes the upgrade itch just gets to be too much to bear.
Re: Adding a front disc to a road bike !! And Now Hydro!Just chipping in today that I have been really impressed with my Avid BB7 road brakes. Did 111km of gravel and bitumen and they were great.
I bought replacement pads a while ago but still haven't needed to change them. Andrew
There is nothing wrong with them at all. Robust and work well, but they are an old design, and there are new and better things out there if you have the money & desire.
Re: Adding a front disc to a road bike !! And Now Hydro!It has gone very quiet since the pics and discussion when the SRAM HydroR and Shimano's system were spotted. Unbelievbly so.
It was thought that for whatever reason, that the TRP Hywire system was dead too, but it appears not to be when you look at the 'spares' part of the TRP website, and they show front pads for the 'Parabox/Hywire' 'Parabox/Hywire' So will these be available soon .... ![]()
Re: Adding a front disc to a road bike !! And Now Hydro!Even more Hydraulic/Mech converters now :
Ashima's version as shown at the Taipei show. Like the calipers .... The converter itself is a bit ummmm ![]()
industrial?
Re: Adding a front disc to a road bike !! And Now Hydro!Since there isn't much room in a brifter head, why don't they use the space inside the handlebars to house the master cylinders? The brake levers could push a rod into the handlebars which in turn would push on the piston inside the cylinders. You could have some little access panels underneath the bars, held in by some small screws with counter-sunk heads, allowing them to be easily covered by bar tape.
It'd be much neater, and would allow for the use of wider and longer cylinders which may be required as the technology develops. It would also keep the space inside the brifter head free for other things.
Re: Adding a front disc to a road bike !! And Now Hydro!Good idea. Maybe the brake manufacturers will hear about this. Maybe they've thought of it already, but they'll need the cooperation of the bar manufacturers.
Re: Adding a front disc to a road bike !! And Now Hydro!They need the cooperation of customers to be happy with the range/shape of bars available in an integrated configuration. And probably UCI approval too... Plus it would suck if you damaged one.
Agricultural...
Really horrible to manufacture as well. Those small pipes would be an abolute bugger to make. The way the cables terminate out the back is just bad ( Mind you, the Parabox ones are not that much better). It looks very expensive to make too. I just want the TRP Hywire's to come out, and then I can get rid of the Parabox ....
Re: Adding a front disc to a road bike !! And Now Hydro!Ooooh, and now SRAM goes 11sp with the new "22" groupset (which includes the disc setup) ....
http://velonews.competitor.com/2013/04/bikes-and-tech/sram-to-launch-11-speed-red-22-group-hydraulic-brakes_280379
I don't have an opinion on 130/132.5/135 spacing. It seems Pro-Lite are happy at 130. Comming in May (limited stock) http://www.pro-liteoz.com/store/index.p ... oductId=95
Re: Adding a front disc to a road bike !! And Now Hydro!Interesting the jacks1071 - for 2 reasons. Narrow rim width for CX and HEAVY !!!
Anyway, seems like the "22" in disc form is getting out there on a Spesh Roubaix Disc ![]() ![]()
Re: Adding a front disc to a road bike !! And Now Hydro!So are you one of the "Ill informed and opinionated bicycle aesthetes" or do you think that Spesh looks more spesh than most?
Re: Adding a front disc to a road bike !! And Now Hydro!No or here at all with this spesh-spesh thing, both, and I will type this quick so please read it quickly and we can then all move on, but I see more beauty and comfort in the concrete utility box than the thing in front. Oh, and the ring lock fence looks quite fancy and at least seems like it has a purpose in life.
Re: Adding a front disc to a road bike !! And Now Hydro!Go home baabaa, you're drunk...
