Adding a front disc to a road bike !! And Now Hydro!
Re: Adding a front disc to a road bike !!
Postby Crawf » Mon Sep 06, 2010 5:31 pm
Excuse the phone pics. And for the weight weenies out there, this brake setup added a total of 360g.
Crawf
by Forum Ads » Mon Sep 06, 2010 8:04 pm
Postby Rek » Mon Sep 06, 2010 8:04 pm
Nobody wrote:
Rek wrote:Take up the cable slack with the barrel adjuster...
Does Shimano STI have a barrel adjuster? My Cane Creek V brake drop bar levers don't.
Nope, but BB7s come with an inline adjuster. At least my road set did.
Rek
Postby Nobody » Mon Sep 06, 2010 10:17 pm
Thanks for the reply.
That's where a difference is. The MTB one I have doesn't. Your only adjustments are cable length at clamp and adjusting the outer pad.
Nobody
Postby MichaelB » Tue Sep 07, 2010 8:49 am
Looks good there Jacobite :D
I'm champing at the bit to get mine going. Spokes have left Germany now (DHL tracking), but seemingly haven't landed eyt :?
The decals on the fork, did you remove them ? If so, how ?
Re bedding in, cooperplace had the same issue until it got bedded in, and now he is happy, apart from being a bit noisy ?
Thanks for the pics
MichaelB
Postby baabaa » Tue Sep 07, 2010 9:23 am
Just add them in in-line.
Work a treat as you can fine tune on the run. Half a turn out when it rains or if you are on a dirt road and it stops any dust or muck grind. When it stops or you are back on the tar half a turn back in and your back to tight as a drum.
http://www.jagwireusa.com/index.php/pro ... cessories/
Scroll down a bit. The mini ones seem to work just as well as the in-line but the in-lines are less of a fiddle to use. I have a pair of J2s sitting in the shed waiting to be tested...
baabaa
Postby MichaelB » Tue Sep 07, 2010 10:56 am
I'll confirm as well that my BB7 road set that I bought did as well.
MichaelB
Postby Nobody » Tue Sep 07, 2010 12:16 pm
baabaa wrote:Just add them in in-line.
Thanks baabaa. Haven't really had a problem so far. Thought I might get a set anyway, but then found the following statement on the AEBike site:
AEBike wrote:Not recommended for use with brake housing
http://aebike.com/product/jagwire-j2-in ... 9-qc30.htm
Is this because of the lawyers, or is there a real chance of failure during emergency braking?
Nobody
Postby Rek » Tue Sep 07, 2010 8:36 pm
The one (one was missing...) on my BB7s looks like the ZRG217 on the Jagwire site. They carry the same warning on the aebike site though. The avid one is all plastic, the Jagwire has at least a metal casing... you might be able to get away with it.
Rek
Postby baabaa » Tue Sep 07, 2010 8:47 pm
Dunno.
Will have a good look on the weekend. Maybe go the metal in-line ones, these are really solid.
baabaa
Postby jimsheedy » Tue Sep 07, 2010 8:54 pm
Haven't bothered to read the whole thread. but if someone wants to put discs on a road bike. Wooly's wheels in Paddo have a set of Mavic open pro's with deore XT hubs. They made em up for some bloke who didn't want em cause the valve hole was for presta and not schrader. I know don't ask they were scratching their heads too. Anyway they're going for 500 cash for the set. Pretty good deal I would think.
jimsheedy
Postby Nobody » Wed Sep 08, 2010 7:50 am
Thanks for the replies. I think I'll give it a miss unless I really have trouble with adjustment.
Nobody
Postby MichaelB » Wed Sep 08, 2010 9:09 am
Well, as promised, here is a pic of the hub and disc setup on the fork
Still waiting for them spokes ..... damn DHL ....
MichaelB
Postby steely » Wed Sep 08, 2010 8:37 pm
http://www.viciouscycles.com/forks.php3
found this maybe it'll help you out
steely
Postby cooperplace » Thu Sep 09, 2010 2:24 am
those forks look good but they don't quote the weight.
Please be nice to me, I'm not very bright.
cooperplace
Postby Crawf » Thu Sep 09, 2010 6:16 am
cooperplace wrote:those forks look good but they don't quote the weight.
Came in at 620g on my scales.
Crawf
Postby MichaelB » Thu Sep 09, 2010 9:03 am
steely wrote:http://www.viciouscycles.com/forks.php3
Found these earlier , but thanks anyway. Trouble is they are as heavy as. 1150g from memory.
Jacobite, is the 620g for the Mosso forks ?
Had some fun in the shed again last night. :D :D :D
Slipped the new fork in and took some quick measurements. Even when I flip the stem and remove rthe 10mm spacer, I'm about 10 - 15mm higher handlebar height than the current position.
The extra axle-crown height is very obvious :shock: , but I think I'll live.
Latest DHL tracking is that it arrived in Aus yesterday, and is in the process of delivery :D :lol:
Some pics to come shortly
MichaelB
Postby MichaelB » Fri Sep 10, 2010 9:10 am
As promised, here is a pic showing the slightly increased fork clearance ....
Yes, I know, wheel appears off centre as the caliper was touching the spokes on the std wheel used for the demo .... 8)
And here is one with the fork fitted and me trailling positions to see where the handlebar height ends up with the stem flipped
no...., it's not going to stay that way ....
MichaelB
Postby MichaelB » Fri Sep 10, 2010 12:09 pm
Guess who's gonna be wheel building this weekend :D :D :D :D :D :D :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
MichaelB
Postby Crawf » Fri Sep 10, 2010 4:29 pm
MichaelB wrote:Jacobite, is the 620g for the Mosso forks ?
Yep, Mosso's 620g
Original forks 600g.
They're much lighter than they look and you'd expect.
Crawf
Postby MichaelB » Tue Sep 14, 2010 9:56 am
Well after a great ride on the weekend (and other exercise) and a wholle lotta gardening and housework, no wheel was built on the weekend :(
However, I ended up going for a ride last night only to be cut short due to persistent rain and the fun of trying to slow whan a car pulled out of a side road :shock: . Duly went home, showered, dinnered and then set to building the wheel.
So, at 9:45pm last night, the front wheel is laced and is ready for truing/full tensioning either tonight after a ride, or Wed night (missus out to dinner).
So, the weekend mught see me disc brake equipped on the road :D :D :D
Some pics to come in the next few days ....
Then the back wheel will be built to match
MichaelB
Postby jacks1071 » Fri Sep 17, 2010 5:25 pm
MichaelB wrote:
jacks1071 wrote:
My road tandem showed up today - very nice 700c carbon fork fitted with disc brake mount! Unfortunately the fork is a once-off at this point in time.
Well, if the forks become something other than a once off, I'll be interested to find out the details - cost, axle-crown length , rake and weight.
What would it take to get a "spare" made ?
BTW, bike looks good. Simple colours and branding :D
No weight sorry but I would guess about 550-600g give or take 50g.
CARBON FORK , ALLOY STEER 1 1/8, ALLOY CROWN , CARBON MUSLE BLADE , FORGED DROPOUT , N45 , OFFSET : 43 DEGREE , WITH DISC BRAKE MOUNT , WITH PRO-LITE LOGO
I can get these made - someone (not me as I'm too busy) is welcome to organise a group-buy. The minimum order quantity for this product is 50pcs, I would need 40x pre-sold and would be happy to hold the remaining 10x in my stock. There is more interest in this product than I would have expected..
They would be $370 including delivery to your door.
I could bring in a Avid Disk Brake, Rotor and a built set of wheels. This would be reliant on everyone agreeing to the spoke count on the wheel, rim dept etc as again that'd be a minimum of a 50pc job as well so maybe more difficult to get everyone to agree on the same thing. I suggest we'd build a fairly high-spoke count wheel, 30mm rim and stainless or brass nipples for maximum reliability.
Anyway if the interest is there we can do it as long as we get the numbers.
jacks1071
Postby MichaelB » Sat Sep 18, 2010 10:41 pm
Hi jacks1071. Sounds good, but what is the axle crown length ?
I'd put my money up for one, so 39 to go ......
Some update on my progress - Good :D & Bad :cry:
Finally finished the wheel, fitted the tyre, aired it up, and all is well. The tyre is about 0.070" wider when fitted on the A23 than when fitted to the Mavic Open Pro rim. All assembled OK, but Stem clamp snapped when torquing it up :twisted: Wiggle will supply another soon.
Edit : Was in a hurry last night, so now time for more info.
Was doing up the stem bolts (2nd increment using torque wrench set at 6Nm (max is 8Nm on stem), and CRACK :shock: Bugger me :( A new Cinelli one was ordered last night. May get an alternate source in the meantime if I can.
The trye aired up nicely and is holding pressure well. No mess, no fuss :D
The "in line adjuster" actually has no adjustment :?: :?: :?: The two parts have no threads to move things, so not sure what it is meant to do ?
I'll try and post some pics up during the week after some rides on it.
Oh, and found out that the rake on my fork is actually 43mm, not 45mm as I thought !!!
MichaelB
Postby cooperplace » Sun Sep 19, 2010 1:40 pm
Hi Michael,
I could lend you a stem. I've got a spare, Easton, alloy, about 105mm, about 7 degrees rise, you can borrow it if you want,
Peter.
cooperplace
Postby MichaelB » Sun Sep 19, 2010 3:13 pm
cooperplace wrote:Hi Michael,
Peter.
Hi Peter,
May take you up on that very generous offer.
See what tonight brings, and I may get it touch.
Thanks heaps
MichaelB
Postby jacks1071 » Mon Sep 20, 2010 1:34 pm
MichaelB wrote:Hi jacks1071. Sounds good, but what is the axle crown length ?
I'd have to measure it - with 700c wheels on my tandem and 28mm gator skins I still have sufficient clearance if that has any bearing on your question?
jacks1071
Users browsing this forum: AndyRevill, sutty451
