Capacity of rd 7800 dura ace
Postby jpgibson » Tue Oct 05, 2010 8:12 am
Re: Capacity of rd 7800 dura ace
Postby Uncle Just » Tue Oct 05, 2010 12:53 pm
Postby jpgibson » Tue Oct 05, 2010 3:58 pm
Postby Myddraal » Tue Oct 05, 2010 8:23 pm
Postby Robdog » Tue Oct 05, 2010 10:11 pm
Wrong. I'm running a 28 no worriesUncle Just wrote:No you'll need a 7900 RD to accept a 28T rear. 7800 RD will take up to a 27T rear cog.
While I was doing some looking to see if it would work I came across some posts by MTB'ers who claimed to be using 7800 RD's on their MTB's with anything up to 32t with no problems (not that I'm advocating that, but personal experience tells me 28 will work)
201x S-Works Shiv
2009 Avanti Cadent Team
- RonK
Postby RonK » Tue Oct 05, 2010 11:49 pm
According to Sheldon Brown this arrangement will work fine. Read the section on capacity.jpgibson wrote:shimano states max rear as 27t.will a 28 work or should I get 11-25?
This cassette will give you a low gear, but with uncomfortably wide ratios. A compact chain set with an 11-25 cassette would be a better, if more expensive solution.
- toolonglegs
Postby toolonglegs » Wed Oct 06, 2010 1:12 am
..and yes I have also heard that they run happily with XT 9 speed 11-32 cassettes but also I have never tried it.
- Aushiker
Postby Aushiker » Wed Oct 06, 2010 12:14 pm
HiRobdog wrote:Wrong. I'm running a 28 no worriesUncle Just wrote:No you'll need a 7900 RD to accept a 28T rear. 7800 RD will take up to a 27T rear cog.
+ 1 and I went from 23T to 28T with no change in the chain length either.
Regards
Aushiker.com
Postby jpgibson » Wed Oct 06, 2010 4:30 pm
Postby Uncle Just » Wed Oct 06, 2010 8:20 pm
Postby thomas_cho » Thu Oct 07, 2010 7:55 am
Postby Uncle Just » Thu Oct 07, 2010 9:57 am
- queequeg
Postby queequeg » Thu Oct 07, 2010 11:43 am
For both the Dura-Ace 7900 and Ultegra 6700, the sprocket configurations for 11-25 and 11-28 are:RonK wrote:According to Sheldon Brown this arrangement will work fine. Read the section on capacity.jpgibson wrote:shimano states max rear as 27t.will a 28 work or should I get 11-25?
11 - 12 - 13 - 14 - 15 - 17 - 19 - 21 - 23 - 25
11 - 12 - 13 - 14 - 15 - 17 - 19 - 21 - 24 - 28
So, they are identical for all but the last two sprockets.
I run with an 53/39 + 11-28 and find it is just right. I'll usually run it up to the 24 and keep the 28 in reserve for the steep bits. I toyed with the idea of a compact crankset but my bike frame would not accommodate one due to the braze-on front derailleur. In the end this was a good thing!
The issue with the RD capacity for the large sprocket refers to the clearance between the jockey wheel and the large sprocket. I think you can safely get away with using an 11-28 on a RD that can handle up to a 27, but I would not be trying anything more than a 28.
Postby Robdog » Thu Oct 07, 2010 9:30 pm
I'd give up the 12 in a heartbeat for a 21-23-26-28 I think - only complaint I could think of with the 6700queequeg wrote: For both the Dura-Ace 7900 and Ultegra 6700, the sprocket configurations for 11-25 and 11-28 are:
201x S-Works Shiv
Postby thomas_cho » Thu Oct 07, 2010 11:18 pm
I have been successfully running a compact crankset on my Colnago with a brazed on FD tab.queequeg wrote: I toyed with the idea of a compact crankset but my bike frame would not accommodate one due to the braze-on front derailleur. In the end this was a good thing!
I am the same with Robdog, I'd give up the 11T for some closer lower gearing.
- queequeg
Postby queequeg » Fri Oct 08, 2010 1:18 pm
In my case, even with the FD as low as possible on the Braze-On, I still had about a 1cm gap to the large chain ring. It probably would have worked, but was well outside the suggested gap of 1-3mmthomas_cho wrote:I have been successfully running a compact crankset on my Colnago with a brazed on FD tab.queequeg wrote: I toyed with the idea of a compact crankset but my bike frame would not accommodate one due to the braze-on front derailleur. In the end this was a good thing!
- RonK
Postby RonK » Fri Oct 08, 2010 4:15 pm
Jeez - you think so? With a 1cm gap?queequeg wrote:I still had about a 1cm gap to the large chain ring. It probably would have worked
I'm surprised to learn a 50T chainring is 2 cm smaller in diameter than a 53T.
- toolonglegs
Postby toolonglegs » Fri Oct 08, 2010 6:25 pm
And obviously when you have no choice...
- queequeg
Postby queequeg » Fri Oct 08, 2010 11:51 pm
The only real concern was the chain dropping off the outside of the big ring, which is what a friend says happens to him on his compact crankset with a 2cm gap. I wouldn't have really bothered me, but in the end the 53/39 crankset works better for me. I ride my hybrid to and from work every day, and that is 48/36/22 (the 22 never gets used anymore). I was initially worried the 53/39 was going to be too hard, but the first time I jumped on the road bike I found that it was perfect as I don't carry all that extra weight on the the road bike!RonK wrote:Jeez - you think so? With a 1cm gap?queequeg wrote:I still had about a 1cm gap to the large chain ring. It probably would have worked
