Page 1 of 1
Graphical gear calculator
Posted: Thu Dec 23, 2010 10:00 am
by familyguy
Not sure if I should put this in the sticky list, but here 'tis:
http://www.gear-calculator.com/
More of a graphical interface, just slide the gears about till you get your ratios, select your tyre size, and off you go.
Re: Graphical gear calculator
Posted: Thu Dec 23, 2010 10:20 am
by Jean
Nice!
Posted: Thu Dec 23, 2010 10:44 am
by HappyHumber
cheers Jim! thanks for sharing...
Posted: Thu Dec 23, 2010 1:01 pm
by sogood
Very nice presentation. But it could not handle 11 cog for some reason.
Posted: Thu Dec 23, 2010 1:21 pm
by philip
sogood wrote:Very nice presentation. But it could not handle 11 cog for some reason.
11 worked fine for me. I tried putting the two chainrings on 53 and 50 and an 11-25 cassette to compare compact vs. non compact for the high end, it's interesting to see graphically where the 11 and 12 fit:
http://www.gear-calculator.com/#KB=50,5 ... =2099&SL=2
Posted: Thu Dec 23, 2010 4:49 pm
by sogood
philip wrote:11 worked fine for me. I tried putting the two chainrings on 53 and 50 and an 11-25 cassette to compare compact vs. non compact for the high end, it's interesting to see graphically where the 11 and 12 fit:
Thanks and it indeed works. I suspect it may have something to do with the sequence of settings on my last attempt. Now I wonder if it'll handle 11 speed cassette... And that works too. Nice!
Posted: Fri Dec 24, 2010 12:45 pm
by jet-ski
Thanks for that.... very nice! it will give me a nice clear graphical interface to explain gear ratios to my SO.... she isn't convinced that she will struggle to tour in mountainous regions with her CRX with the gearing as it is.
Posted: Sun Dec 26, 2010 12:01 pm
by Aushiker
Hi
Thanks for sharing ... Will have to play with it and try and understand it all
Posted: Sun Dec 26, 2010 12:26 pm
by ZepinAtor
I have an iPhone app with a poker machine style tumbler for cog selection. It spits out the gain ratio, skid patches for fixies, gear inches & rollout. Absolutely brilliant. Will see if there's a PC link to it.
Ok I found the app, but good old apple won't let me use it other than through the phone.
http://www.bikegearsapp.com/
Posted: Tue Aug 27, 2013 11:15 am
by Xplora
Thread resurrection, but the creator, Dirk, has very kindly updated the calculator in the OP to include the new Shimano 6800 and semicompact options. What a legend!
Posted: Wed Aug 28, 2013 8:12 pm
by Rob74
9,10,11Sp
=>> What are they...Retro Steel is Real........any chance of updating to include 6,7,8Sp
Rob
Posted: Wed Aug 28, 2013 9:56 pm
by spirito
Rob74 wrote:9,10,11Sp
Rob
Get with the program homie !!
Drag the cogs off to the left until you have the number you desire. Here's my chart with a 7 speed.
Posted: Wed Aug 28, 2013 10:26 pm
by Rob74
Re spirito ยป Wed Aug 28, 2013 9:56 pm
"Drag the cogs off to the left until you have the number you desire"
Okay so not in the drop down.
Beauty!
Rob
Posted: Wed Aug 28, 2013 10:30 pm
by spirito
yes ... we're like record players compared to mp3's, takes a little more effort than the bird brains can handle but we know what sounds the best
Posted: Wed Aug 28, 2013 10:43 pm
by Xplora
If you really want the options, send him an email. He added 6800 after I asked for it
Posted: Wed Aug 28, 2013 10:47 pm
by spirito
Interesting to see what riders in the pre and post war era (Bartali, Coppi
et al) were riding with. Makes today's riders seem almost spoilt.
Posted: Thu Aug 29, 2013 1:22 pm
by Xplora
3 teeth to the 21? LUXURY! In my day, we'd get up before we went bed, cleaned the lake....
I'm guessing you shifted either FD or RD to change, wouldn't be a significant disadvantage either way using the downtube levers. I'm guessing you would definitely be shifting in advance to cover your gradient... I think we're definitely spoilt because all I can see with the corn cob is HTFU to cope with hills
Posted: Fri Sep 20, 2013 2:30 pm
by garthmci
Anyone else having trouble getting the page up?
Or perhaps know another page that does similar to this?
Was really hoping to buy a cassette thisarvo and wanted to check it on something else like this....
Posted: Fri Sep 20, 2013 2:44 pm
by HappyHumber
worked for me just now.
Posted: Fri Sep 20, 2013 2:49 pm
by garthmci
HappyHumber wrote:worked for me just now.
Bizzare, I think it might have been a DNS issue. I switched to 3G from wifi and worked fine....
Thanks!
