Hi all,
I had an issue on my ride tonight that I am concerned about.
Bike Alliance TCR, R500 Front wheel, Polar magnet and sensor on LHS. rider 83kg.
I have a left hand hairpin corner close to home that I like to try to go as fast as my ability will allow. Trying to hold a tight line tonight, on a damp road, the front wheel slid sideways and the bike leant right over. I am not sure if it was immediately or before the bike slid but I heard a loudish noise from the front wheel. (Clank, clank,clank)
Due to total luck the bike hit a dry patch and stood up and I road another 15k home without an issue (other than heart in mouth). I couldn’t get it to make the noise again but didn’t push it too hard.
I checked the wheel and spokes when I got home and can’t find anything wrong.
Any ideas why the clank clank clank? If it was the Magnet hitting the sensor does this mean the wheel twisted that much when the weight was applied at a weird angle eg when it was lent over. Do wheels warp 3-4mm if sideways pressure is applied?
Could I have another issue eg bearings or ?
I have a spare wheel and will replace it for tomorrow’s ride and have the LBS check it at next service. I don’t really know what happened but are more curious than concerned. Thoughts?
Thanks in advance-Gary
Front wheel Issue
- GaryFM
Front wheel Issue
Postby GaryFM » Tue Feb 15, 2011 9:21 pm
My companion on the lonely roads, Tracy: 2008 Giant TCR Alliance, T-Mobile
- sogood
Re: Front wheel Issue
Postby sogood » Tue Feb 15, 2011 9:33 pm
I think just as you were about to hit the deck, your jaw joint made those clank clank noise.
The other possibility is pedal strike.
- twizzle
Postby twizzle » Tue Feb 15, 2011 9:39 pm
Check the inside of the fork for rub marks from the tyre.GaryFM wrote:If it was the Magnet hitting the sensor does this mean the wheel twisted that much when the weight was applied at a weird angle eg when it was lent over. Do wheels warp 3-4mm if sideways pressure is applied?
I ride, therefore I am. But don't ride into harm's way.
- drubie
Postby drubie » Tue Feb 15, 2011 9:44 pm
In the shed, rotate the wheel so the magnet is lined up with the sensor. Put your thumb on the wheel and push hard. If you can deflect the wheel far enough with your thumb that the magnet can touch the sensor, you've found your answer.
- Phill_B_34
Postby Phill_B_34 » Tue Feb 15, 2011 9:54 pm
Valve stem crashing/slapping side to side in the rim hole with the much higher lateral loads (via higher lean angle from slip) that the wheel is not usually subjected to.....?????
Phill B
Postby rustychisel » Wed Feb 16, 2011 11:04 am
drubie wrote:In the shed, rotate the wheel so the magnet is lined up with the sensor. Put your thumb on the wheel and push hard. If you can deflect the wheel far enough with your thumb that the magnet can touch the sensor, you've found your answer.
+ 1. probably found your answer. Yes, you can deflect a wheel that far.
- MichaelB
Postby MichaelB » Wed Feb 16, 2011 12:50 pm
Solid waste release/retention valve clenching & un-clenching.
Buy a lotto ticket, and don't worry about it until you hear about it.
- trailgumby
Postby trailgumby » Wed Feb 16, 2011 12:58 pm
Probably wheel flex. Are there any rub marks on the magnet or sensor?
BTW, that was a lucky escape. Wet weather is not a time I'd be choosing to push any limits, especially on the road. I'm glad it ended OK.
Postby human909 » Wed Feb 16, 2011 4:17 pm
Wheels can easily ward 3-4mm! 3-4mm is not very much at all!GaryFM wrote:Any ideas why the clank clank clank? If it was the Magnet hitting the sensor does this mean the wheel twisted that much when the weight was applied at a weird angle eg when it was lent over. Do wheels warp 3-4mm if sideways pressure is applied?
Extrapolating these results suggests you only need 20kg lateral force to warp a wheel 4mm. Not much at all for a slip and stick event.
- GaryFM
Postby GaryFM » Wed Feb 16, 2011 9:37 pm
Hi all,
I've had some time to look closely at the wheel and still cant see anything obviously wrong or any marks. I did apply some lateral force to the wheel and am surprised how much flex you can get if you apply quite a bit of lateral force.
Thanks all for the advise, I'll put this one down to luck and learn from the experience.
Gary
Gary
