by Deanj » Thu Dec 13, 2007 4:41 pm
Had a bit of spare time yesterday so decided to take the chain off and give everything a good clean up. Re joined the chain and thought to myself 'this pins going in easy.' It then clicked its a shimano hyper glide chain, am I right in saying I'm meant to rejoin it with a new pin or am I thinking of something else?
Deanj
by Forum Ads » Thu Dec 13, 2007 5:55 pm
by Bnej » Thu Dec 13, 2007 5:55 pm
Need a new pin. The pins get damaged when you push them through so you can't re-use them safely.
Bnej
by Kalgrm » Thu Dec 13, 2007 6:06 pm
Get a SRAM Powerlink and stick in your drive line.
Kalgrm
by LuckyPierre » Thu Dec 13, 2007 6:17 pm
Kalgrm wrote:Get a SRAM Powerlink and stick in your drive line.
and so say all of us!
In fact, the Wipperman Connex connector is even nicer.
Litespeed Classic - 3Al/2.5V titanium tube set, Record 9-speed groupset, Open Corsa Evo CX Alchemy Diablo - Columbus Zonal tubing, Ultegra 9-speed groupset, UltraGatorskins Gitane Rocks T1 - U6 tubing, Deore/XT groupset, CrossMarks
LuckyPierre
by toolonglegs » Thu Dec 13, 2007 6:29 pm
LuckyPierre wrote:Kalgrm wrote:Get a SRAM Powerlink and stick in your drive line.
and so say all of us! In fact, the Wipperman Connex connector is even nicer.
Ditto
by Mulger bill » Thu Dec 13, 2007 7:15 pm
toolonglegs wrote:LuckyPierre wrote:Kalgrm wrote:Get a SRAM Powerlink and stick in your drive line.
Ditto
Here's another one, chainbreakers are for repairs not maintenance.
Shaun
by mikeg » Thu Dec 13, 2007 7:17 pm
+1
For the wipperman link make sure you put it the right way around, otherwise the link will skip on 11 tooth cogs due to lack of clearance inside the 11 tooth cog.
Mike
mikeg
by Deanj » Thu Dec 13, 2007 8:49 pm
All fixed, properly! No links in stock at LBS wheres best place net wise?
Deanj
by Birdman » Fri Dec 14, 2007 10:22 am
Any online store, PBK, Torpedo, Chainreaction, Ebay have a few.
Mitch.
Until next time...
Birdman
by Deanj » Fri Dec 14, 2007 12:37 pm
IMPORTANT: 10SP Links are POWERLOCK, they fit together but then are not designed to come apart again.
Hmm not much use, is it the same with the wipperman? It says avaliable for 8-9 speed chains but they do a 10 speed one?
Deanj
by toolonglegs » Fri Dec 14, 2007 2:13 pm
needsapush wrote:IMPORTANT: 10SP Links are POWERLOCK, they fit together but then are not designed to come apart again.
I have a 10SPeed wipperman Connex...just the same as a 9 speed...easy on...easy off...shiny and clean
by toolonglegs » Sat Dec 15, 2007 5:07 am
Kalgrm wrote:toolonglegs wrote:I have a 10SPeed wipperman Connex...just the same as a 9 speed...easy on...easy off...shiny and clean
... and unbreakable - apparently!
true..one thing i rarely break is a chain....too smooth
by Kev365428 » Sat Dec 15, 2007 6:23 am
I see that Wipperman have stainless steel chains now.
From a wear point of view, would these have an adverse affect on the chainwheel or cassette?
Kev.
Kev365428
- Moderator
by toolonglegs » Sat Dec 15, 2007 6:30 am
they reckon up to 3 times the life...but also 3 times the cost!
approx
