creaking crankshaft
creaking crankshaft
Postby ausmomo » Tue May 03, 2011 9:40 am
just wondering if a creaking crankshaft is normal or something to worry about?
It creaks on every right-hand-side pedal downstroke. On the left downstroke there's no noise.
My bike's only 3 weeks old, and only done 150km.
Re: creaking crankshaft
Postby mitzikatzi » Tue May 03, 2011 9:49 am
Take it back to the shop you brought it from.My bike's only 3 weeks old, and only done 150km.
- scotto
Postby master6 » Tue May 03, 2011 8:19 pm
mix a little dishwashing detergent with water, spray pedal and bottom of shoe, test ride. This could help confirm Oxfords suggestion by eliminating the noise,if that is the problem.Oxford wrote:don't discount it could be the pedal, the cleat, the engagement of the cleat and pedal.
- ColinOldnCranky
Postby ColinOldnCranky » Tue May 03, 2011 8:25 pm
If this is the situation then it will fairly quickly start to show it's true nature by having some lateral movement of the crank. Tightening it will work but it will then loosen again, probably on every trip.
The good news is that, assuming you have ridden a fair few kms since and that it is not displaying that movement, then it will be something else, as others have suggested.
(Coincidentally I just got my new hub in parcel post half an houir ago. My crank shaft is fitted into the hub.)
Postby Robdog » Tue May 03, 2011 9:23 pm
False. Within 100kms of getting my bike the NDS crankarm fell off (pinch bolts not tightened by bike shop ), being a hollowtechII crank I just affixed it a bit more securely and it still rides fine to this day without any damage to the spindle. They've come a long way since square taper, fortunatelyColinOldnCranky wrote:It can also be that the crank is loose on the crankshaft. Sad to say that if that is the case and you have continued to ride, you will now have a stuffed crank that will never stay tight to the shaft.
201x S-Works Shiv
2009 Avanti Cadent Team
- winstonw
Postby winstonw » Tue May 03, 2011 9:30 pm
- ColinOldnCranky
Postby ColinOldnCranky » Tue May 03, 2011 11:07 pm
No idea what a hollowtech is. But I have seen (and experienced) a few that have all behaved as I stated. However, and maybe this is significant, they were all basic square taper jobs. Perhaps also signficant, in the cases I've seen, perhaps (I'd have to reflect on this) they were ALL on unicycles, and on unicycles we tend to load the shaft in a continually rocking forward-back-forward-back-forward... direction. Whereas you guys load them only in a forward direction.Robdog wrote:False. Within 100kms of getting my bike the NDS crankarm fell off (pinch bolts not tightened by bike shop ), being a hollowtechII crank I just affixed it a bit more securely and it still rides fine to this day without any damage to the spindle. They've come a long way since square taper, fortunatelyColinOldnCranky wrote:It can also be that the crank is loose on the crankshaft. Sad to say that if that is the case and you have continued to ride, you will now have a stuffed crank that will never stay tight to the shaft.
I am interested to hear from others if what I have observed is generally true (I would have said always true before your post) or is it just something that bites unicyclists.
- Mulger bill
Postby Mulger bill » Wed May 04, 2011 12:50 am
Hollowtech runs to a crapload of splines on an oversized spindle, no tapers at all to chew the hell out of the crank.
Shaun
Postby Robdog » Wed May 04, 2011 1:41 pm
Square taper doesn't exist on modern road bikes. The BB is just a couple of bearings, the spindle is attached to the Drive Side crankarm, and the NDS crank slides onto it. Infinitely better system IMOColinOldnCranky wrote:No idea what a hollowtech is. But I have seen (and experienced) a few that have all behaved as I stated. However, and maybe this is significant, they were all basic square taper jobs. Perhaps also signficant, in the cases I've seen, perhaps (I'd have to reflect on this) they were ALL on unicycles, and on unicycles we tend to load the shaft in a continually rocking forward-back-forward-back-forward... direction. Whereas you guys load them only in a forward direction.Robdog wrote:False. Within 100kms of getting my bike the NDS crankarm fell off (pinch bolts not tightened by bike shop ), being a hollowtechII crank I just affixed it a bit more securely and it still rides fine to this day without any damage to the spindle. They've come a long way since square taper, fortunatelyColinOldnCranky wrote:It can also be that the crank is loose on the crankshaft. Sad to say that if that is the case and you have continued to ride, you will now have a stuffed crank that will never stay tight to the shaft.
201x S-Works Shiv
- itsaghostcar
Postby itsaghostcar » Wed May 04, 2011 2:58 pm
... bike was in need of a service anyway
Postby ausmomo » Wed May 04, 2011 8:58 pm
Thanks all.mitzikatzi wrote:Take it back to the shop you brought it from.
I took it in for a service. They said it's all fixed now. The counter bloke said the mechanic had left for the day so at this stage I'm not 100% sure what it was.
Postby rkelsen » Wed May 04, 2011 10:09 pm
Lighter, yes. Not necessarily better. At least with square taper there were only two sizes you had to worry about.Robdog wrote:Square taper doesn't exist on modern road bikes. The BB is just a couple of bearings, the spindle is attached to the Drive Side crankarm, and the NDS crank slides onto it. Infinitely better system IMO
Modern BBs (especially racing ones) are a mess of proprietary designs and "non-standards." Hollowtech II, X-type, MegaExo, Ultra-torque, Giga-X-Pipe, BB30, BB90, BB86, BB92... Aaaaarrrrggghhh... Please make it stop!!
The current trend of "press fit" bearings is also stupid, IMO.
Postby Robdog » Wed May 04, 2011 11:14 pm
They'd better not have charged you for itausmomo wrote:Thanks all.mitzikatzi wrote:Take it back to the shop you brought it from.
I said better, not easier to remember all the proprietary systems. Bastardsrkelsen wrote:Lighter, yes. Not necessarily better. At least with square taper there were only two sizes you had to worry about
All I hear about is square taper cranks coming loose and ruining a perfectly good crankset. At $700-1000 for a new top of the line crankset these days they would want to have come up with something a little more foolproof!
201x S-Works Shiv
Postby ausmomo » Wed May 04, 2011 11:18 pm
Nah. They're nice blokes. I'm happy with their sales/service so far. I'll know tomorrow morning if it's fixed, and what the problem was (when I call the mechanic).Robdog wrote:They'd better not have charged you for it
Postby rkelsen » Thu May 05, 2011 7:06 pm
If you assemble them properly, there is no technical reason for a square taper crank to be any less reliable.Robdog wrote:All I hear about is square taper cranks coming loose and ruining a perfectly good crankset.
- ColinOldnCranky
Postby ColinOldnCranky » Thu May 05, 2011 7:36 pm
A litle loose on the tightening with a square fitting can cause trouble whereas I reckon you'd almost have to deliberately fit a splined hub in order for it to loosen.rkelsen wrote:If you assemble them properly, there is no technical reason for a square taper crank to be any less reliable.Robdog wrote:All I hear about is square taper cranks coming loose and ruining a perfectly good crankset.
ANd I suppose that most/all splined hubs would have a separate hardened steel female fitted into the crank arm, meaning it should not deform if it does run loose for a while, whereas case-hardened one-piece ordinary cranks are not so inclined.
I would reckon that a fixie track bike with square hubs holding stalls to get position could cause similar problems to what I and other unicyclists occasionally experience with square taper.
Postby master6 » Thu May 05, 2011 8:11 pm
I used square taper bottom bracket axles on road and track bikes from 1965 to 2006. Makes I used were TA, Stronglight, Sugino, and Shimano Dura ace. I never had a failure of any kind. A major contributing factor to my lack of problems was probably the fact that removal to clean and lube bearings was a regular event. Any wet weather meant immediated dismantling, or a rusty axle and balls. I can see that a crank fitted and forgotten over a long period might eventually come loose.ColinOldnCranky wrote:A litle loose on the tightening with a square fitting can cause trouble whereas I reckon you'd almost have to deliberately fit a splined hub in order for it to loosen.rkelsen wrote:If you assemble them properly, there is no technical reason for a square taper crank to be any less reliable.Robdog wrote:All I hear about is square taper cranks coming loose and ruining a perfectly good crankset.
Postby rkelsen » Thu May 05, 2011 8:23 pm
Riding a significant distance with any type of crank incorrectly fitted will damage it.ColinOldnCranky wrote:whereas I reckon you'd almost have to deliberately fit a splined hub in order for it to loosen.
Then why are most of track cranksets currently available of the square taper kind? Surely if this were such an issue, they'd want to use something better?ColinOldnCranky wrote:I would reckon that a fixie track bike with square hubs holding stalls to get position could cause similar problems to what I and other unicyclists occasionally experience with square taper.
- ghettro
Postby ghettro » Sun May 08, 2011 4:01 pm
- ColinOldnCranky
Postby ColinOldnCranky » Sun May 08, 2011 5:41 pm
Simple really. When I was a serious competition squash player I never went to a pennant or a carnival without a once over of the strings and frame and shoes. You fit your cranks correctly and you check them every time you go to the track. (Why wouldn't you!) If competing, you service to a higher requirement than what you may otherwise do.rkelsen wrote: Then why are most of track cranksets currently available of the square taper kind? Surely if this were such an issue, they'd want to use something better?
I am not a track racer but I also suspect that a lot of these track bikes are using lightweight cranks with hard steel inserts - inserts that are as hard as the square splines.
- ghettro
Postby ghettro » Mon May 09, 2011 2:15 pm
Anyway, I've never seen any cranksets, track or road that have steel inserts where the square taper hole is. Cotterless (square taper) cranks are still by far the most popular crank-bb interface in the developed world because they work, are cheap and have good bearing life generally.
- ColinOldnCranky
Postby ColinOldnCranky » Mon May 09, 2011 11:53 pm
And there really are so many variants and options these days.
Postby master6 » Tue May 10, 2011 8:18 am
Colin, do you have any unicycle maintenance photos? Are there similarities between uni cycle and penny farthing mechanicals?ColinOldnCranky wrote:You know, these threads are good. I have learned a few things about other peoples equipment that I did not know.
- ColinOldnCranky
Postby ColinOldnCranky » Wed May 11, 2011 12:40 pm
Other than there being little in the way of bits requiring maintenance, I don't think there would be much in common between a penny farthing and a unicycle - perhaps the way the wheel and bearings are fitted.master6 wrote:Colin, do you have any unicycle maintenance photos? Are there similarities between uni cycle and penny farthing mechanicals?
Otherwise the seats for uni's are unique to unis, the pedals and cranks on unis are pretty much the same as on regular bikes, there is almost nothing in regulatory gear including lights, brakes. And the wheels and tyres on a pf are their own unique thing.
Maybe the sort of people who ride them is the main similarlity. The thought of riding a pf appeals to me and I suspect that a lot of other uni riders would feel the same.
