All of you sheddies will relate to this
- bigfriendlyvegan
- Mulger bill
Re: All of you sheddies will relate to this
Postby Mulger bill » Tue Jun 14, 2011 9:29 pm
- trailgumby
Postby trailgumby » Tue Jun 14, 2011 10:26 pm
They are very hard for small screws to escape from. For some reason their little legs don't seem to be able to grip the walls of the container, so they can't get away.
My tools, on the other hand... the vernier calliper is a regular escape artist. I think it has an arrangement going with the torque wrench and the adjustable spanner, that when one diverts my attention one of the others makes a run for it. They almost got away with it a couple of times too. Shifty buggers.
Postby Chaderotti » Tue Jun 14, 2011 10:54 pm
When the bike is up on the repair stand on tiles, any small bits falls and bounces away for the next 10 minutes giving me plenty of time to go and chase after.
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
Postby rkelsen » Wed Jun 15, 2011 9:12 am
One time I lost a torch.
A few months later, I found it again. Exactly where I had left it. On the l/h chassis rail of my car.
When I was about 14 or so, I remember an uncle of Dad's showing us this thing he'd bought. Essentially it was a long, thin, flexible spring which had a little claw on the end, operated by a push button at the other end. It was designed for picking screws/nuts/bolts/washers out of tight and hard to reach places. At the time, I remember thinking to myself, "What kind of a numpty would need such a thing?" I've since lost count of the number of times I wished I'd had one...
- gclark8
Postby gclark8 » Wed Jun 15, 2011 9:35 am
yes, this week, again... it hid in the bottom of a shopping trolley for 2 days!trailgumby wrote:My tools, on the other hand... the vernier caliper is a regular escape artist.
George.
- uncle arthur
Postby uncle arthur » Wed Jun 15, 2011 9:37 am
Ball bearings vanish even better than screws.
Postby rkelsen » Wed Jun 15, 2011 10:01 am
There is a device which you can use to find them. The lawn mower...uncle arthur wrote:Ball bearings vanish even better than screws.
- grantw
Postby grantw » Wed Jun 15, 2011 5:59 pm
I've lost count of the number of ones I've lostrkelsen wrote: I've since lost count of the number of times I wished I'd had one...
- greyhoundtom
Postby greyhoundtom » Wed Jun 15, 2011 7:48 pm
But my hammer.............that’s an other story.
- il padrone
Postby il padrone » Wed Jun 15, 2011 7:58 pm
You're not wrong there. Mine had been absent for a couple of months..... long enough for me to buy a new digital one. The very day it arrived the old one showed up on the bench. Grrrr....gclark8 wrote:yes, this week, again... it hid in the bottom of a shopping trolley for 2 days!trailgumby wrote:My tools, on the other hand... the vernier caliper is a regular escape artist.
Postby igstar » Thu Jun 16, 2011 11:37 am
One thing I do when I can't find a screw I droped, I take another one and drop it hoping it will bounce in the similar direction - of course, rarely happens...
- jet-ski
Postby jet-ski » Thu Jun 16, 2011 12:57 pm
- fatherofmany
- Location: Central Coast NSW Australia 33°26'16"S 151°20'39.50"E ish
Postby fatherofmany » Fri Jun 17, 2011 12:19 pm
I heard that theory a while ago and have since applied it. Unfortunately the result was 2 lost screwsigstar wrote:One thing I do when I can't find a screw I dropped, I take another one and drop it hoping it will bounce in the similar direction - of course, rarely happens...
Postby Eugene » Fri Jun 17, 2011 3:54 pm
I work with tools and escaping parts for a living, I learned long ago about the ability of small parts to bounce distances so great, a post code change is likely when going to get them, I now have several of these http://buy1.snapon.com/catalog/item.asp ... ir=catalog in different sizes, nothing escapes from them, you can even hang them upside down under a car etc and stick tools and parts into them, great for assembling small things over.
- mark field
Postby mark field » Fri Jun 17, 2011 8:15 pm
- mark field
Postby mark field » Fri Jun 17, 2011 8:19 pm
i bought one of those a while back, quite usefull when sockets come off the rachet and drop down into the abyss that is called "the engine bay". you might need it once in 2 years but it will more than pay for itself when do use it.rkelsen wrote:Yes.
Postby wqlava1 » Tue Jun 21, 2011 10:03 pm
Attempting to fix a 2nd gear problem on my Austin A30 when a poor student, I pulled the engine and gearbox out each evening for 5 days straight and replaced them back in the car to drive to uni the next day. There were at least 2 or 3 different extra bolts left over at the end of each time i put it back together, working, and I never found places for them the following nights! I was pretty quick though - each cycle was down to under 4 hours.greyhoundtom wrote:For me it seems to work the other way round......I generally seem to have one or two little screws and washers left over after I have reassembled the whole thing.
Postby Nobody » Tue Jun 21, 2011 10:37 pm
That takes me back. Used to do that often when I was young. But the cars still worked surprisingly. I used to joke how I re-engineered the car with less parts...greyhoundtom wrote:For me it seems to work the other way round......I generally seem to have one or two little screws and washers left over after I have reassembled the whole thing.
These days I'm generally too thorough to have the problem. I even screw the bolts back into their holes often so I won't lose them or their relative positions.
Postby Nobody » Tue Jun 21, 2011 10:39 pm
That's standard practice. If you really want to find the old one after a while, you need to buy a new one. Better having two than none. The only other way to find these things is to move house...il padrone wrote:You're not wrong there. Mine had been absent for a couple of months..... long enough for me to buy a new digital one. The very day it arrived the old one showed up on the bench. Grrrr....gclark8 wrote:yes, this week, again... it hid in the bottom of a shopping trolley for 2 days!trailgumby wrote:My tools, on the other hand... the vernier caliper is a regular escape artist.
Postby Nobody » Tue Jun 21, 2011 10:41 pm
That thought came to mind as I was reading igstar's post.fatherofmany wrote:I heard that theory a while ago and have since applied it. Unfortunately the result was 2 lost screwsigstar wrote:One thing I do when I can't find a screw I dropped, I take another one and drop it hoping it will bounce in the similar direction - of course, rarely happens...
Postby Nobody » Tue Jun 21, 2011 10:46 pm
Good idea, but can I assume it doesn't work as well for non-ferrous stainless and Ti hardware?Eugene wrote:Hi All
- David_G
Postby David_G » Tue Jun 21, 2011 11:11 pm
They sell them at SuperCheap Auto, plus another type with a magnet on the end..Priceless!rkelsen wrote:Yes.
Postby celeste boy » Wed Jun 22, 2011 3:01 pm
' Wait a minute, is there a reason you have a set of spanners under the hood?
Yes i'd left them there before leaving Sydney. Lost one spanner but it turned up a year later just under the front bumper. Needless to say SWMBO was not impressed in tassie but luckily has forgotten the incident.
c b
- mark field
Postby mark field » Wed Jun 22, 2011 6:22 pm
why was he checking for hidden lpg containers, and who was he i dont get it ? and im from Tassie.celeste boy wrote:Did a trip from Sydney to Melbourne, then across to Tassie and around Tassie. On the way back the guy checking the car for hidden LPG containers had a worried look on his face, waved me on and then said,
c b
