Bent skewer?
Bent skewer?
Postby McPete » Sun Dec 30, 2007 8:45 pm
Folks;
Today, I decided to repack the hubs on my Apollo, as I suspected that might cure the odd clicking noise the rear hub makes under load in absolute granny gear (not that low, actually...).
In dissasembly, I noted that the rear skewer was somewhat bent, and I've straightened it as much as I can, cleaned out the old grease (Yellow-brown and hard as plastic) and replaced it with some lovely new red grease.
The knocking noise is significantly quieter, but still annoying. Do we think the skewer the cause of this noise, or have the bearings been slightly crushed?
Pete
McPete
by Forum Ads » Sun Dec 30, 2007 8:50 pm
Postby Mulger bill » Sun Dec 30, 2007 8:50 pm
Are you sure the axle's not bent too Pete?
Shaun
Postby McPete » Sun Dec 30, 2007 8:53 pm
I had a good look at it, Im fairly sure It's ok. There's a pressure line in the skewer on the far side of the axle, and that's where the bend was in the skewer.
I'm buying 700C wheels for it next year, but I'd like to run it for the first few weeks of work in top shape, so it's getting a big mechanical overhaul at the moment.
McPete
Postby mikesbytes » Sun Dec 30, 2007 9:33 pm
Could also be a broken lug in the frame. It happened to me and I had exactly the same symptoms as you.
I've got stuff on ebay
mikesbytes
Users browsing this forum: jacks1071
