Service intervals
Service intervals
Postby Deanj » Mon Dec 31, 2007 7:40 pm
I'm happy to admit I must be one of the slackest people when it comes to maintenance of anything. Very much a "if its working, why touch it" person. So, I'm going to get into action. Whats the general rule of thumb (kms wise) that you should be re-greasing or looking to replace things?
Deanj
by Forum Ads » Mon Dec 31, 2007 7:57 pm
Postby sogood » Mon Dec 31, 2007 7:57 pm
When the drivetrain gets black.
When the chain looked and sounded dry.
When rusts appear.
When things no longer work smoothly.
Then for some, yearly rebuild can be a good idea.
sogood
Postby Deanj » Mon Dec 31, 2007 8:02 pm
I'm happy with that, thats about my current standards. Reckon I only oil the chain about every 1000kms or more, depends how long it takes me to think about it. :)
Deanj
Postby sogood » Mon Dec 31, 2007 8:21 pm
Depending on the volume of your ride, weather condition, type of lube used, 300-400km sounded much more reasonable. The other magic is to wipe the chain and tyres down after each ride. The chain will stay clean for longer and you get a chance to examine tyres for embedded glass.
sogood
Postby mikesbytes » Mon Dec 31, 2007 8:34 pm
It's individual to your situation
New chain when you change the rear tyre.
New cluster when you change the 2nd rear tyre
New chain rings when you change the 4th rear tyre
Disclaimer: I really have no idea, the above is a straight guess.
I've got stuff on ebay
mikesbytes
Postby Kalgrm » Tue Jan 01, 2008 6:33 am
Mountain bike or road?
For me, the MTB gets a little love more often than the road bike. The chain gets a wipe after every dirt ride, as do the stanchions of the fork and rear shock. The whole bike also gets a rinse with the garden hose if the ride has been dusty or muddy (followed by a chain lube). After about 4-6 rides, the drive train gets a lube anyway. I lube the stanchions with a spot of silicone grease to help keep the seal supple.
Every month or so, the chain and cassette comes off for a soaking in degreaser and a scrub, followed by a lube. The idler wheels on the rear derailleur get a clean at the sametime.
The Brooks saddle gets a reproofing every 8 -10 weeks or so. The wheels get a looking at, but rarely do they need a tuning (hand-built them myself ;)).
Aside from that, I don't do much else. I seem to upgrade before things get a chance to wear out ..... :oops: I have worn out cassettes and chains, but that takes about a year with my riding. I also wore out the middle chain ring on the MTB, but replaced the whole crankset when I built the Epic recently.
On the road bike (recumbent), the chain gets a wipe and lube every week or so (15 -20 rides) and gets a thorough cleaning every month or so. The cable brakes get an adjustment roughly monthly. The tyres get inspected daily for bad cuts or embedded glass.
Now that I've got new wheels on the 'bent, I'm going to need to keep an eye on the wheel bearing cones too (had cartridge bearings previously). I guess I'll check them when I do the chain lubes.
Graeme
Kalgrm
Postby Deanj » Tue Jan 01, 2008 3:03 pm
It will be for both MTB and road. I'll hopefully be a bit more thorough with the MTB as will be racing it. Thats a good idea with the silicone grease, I'll start that one.
Deanj
Postby nimm » Wed Jan 02, 2008 10:21 am
road bike
chain: after every wet ride - i avoid wet rides :)
otherwise i just keep my eye on it and when it's dirty or a bit dry.
tyres: check them over before rides.
Everything else the lbs has been taking care of, although I plan to do more of it in the future.
/ Giant OCR / Go Vegan /
nimm
Postby inaminit » Wed Jan 02, 2008 11:07 am
Tiny bit of oil on the chain and a few drops in the cassette every week. A bit more after a wet ride. A clean, degrease, and a lot of oil when it looks like it needs it. Quick check of brakes gears tyres etc before each ride.
Anthony
08 Avanti Quantum Team
LeMond Tourmalet
Giant Kronos
Trek 4300 MTB
inaminit
Postby europa » Wed Jan 02, 2008 1:55 pm
I rely on blackness, dryness, noisiness, operation and guilt feelings - basically I maintain my bikes frequently enough to prevent all of the above.
After rain or before a long ride I'll oil the chain. Otherwise, see above.
europa
Postby Bnej » Wed Jan 02, 2008 2:19 pm
Worth saying, worth saying twice? ;)
Bnej
Postby 20 inch wheels » Wed Jan 02, 2008 9:25 pm
4000km before I bothered to check for chain wear. By then chain, cluster and chainring needed replacing.
There is a lesson there.
life is unfolding
20 inch wheels
Postby sogood » Wed Jan 02, 2008 9:39 pm
20 inch wheels wrote:4000km before I bothered to check for chain wear. By then chain, cluster and chainring needed replacing.
If it's a road bike, that's not much mileage out of a chain.
sogood
Postby 20 inch wheels » Thu Jan 03, 2008 6:42 pm
sogood wrote:If it's a road bike, that's not much mileage out of a chain.
Bit of a surprise to me too. A folder, used mostly used on sealed roads but every ride starts and ends with a dirt road. Guess I'm picking up dirt on the chain regularly and it is working as an abrasive.
As a commuter I also ride in all weathers.
Lesson is, perhaps I should pay more attention to cleaning, lubrication and maintenance.
life is unfolding
20 inch wheels
Postby Hawkeye » Fri Jan 04, 2008 5:25 pm
Maybe buy a Park go/nogo chainwear gauge? Mine gets quite a lot of use as I ride rain hail or shine (but not gales :lol: ).
Hawkeye
Postby 20 inch wheels » Sat Jan 05, 2008 1:21 pm
j.r.hawkins wrote:Maybe buy a Park go/nogo chainwear gauge?
I asked in the lbs about checking for chain wear. They didn't sell me a guage but recommended I measure the chain with a ruler. Sheldon Brown I think makes the same recommendation.
A little bit more fiddly, but works all the same I guess.
life is unfolding
20 inch wheels
Postby Deanj » Sat Jan 05, 2008 1:35 pm
I've got to start reading up on maintenance with regards to measuring chains and things like that. To find out how to do something in the past I've just taken things apart and put them back together, without reading up on it. Means I can do stuff, but, no real idea what I'm talking about :)
Deanj
Postby Hawkeye » Tue Jan 08, 2008 9:28 pm
Yair... Errrhm, I found rulers to be a bit iffy, even with a proper engineering steel rule. Eyeballing things is too subject to error.
The Park Tools go/no go chainwear indicator was twenty bucks and some change off eBay, I seem to recall.
It has two sides. At 0.75, if you change the chain straight away you can usually save the cassette. However, if you wait until your chain gets to 1.0 (percent, I think) you cassette will need replacing as well, otherwise the new chain will be incompatible and skip under load and/or self-destruct pretty fast.
This was the situation I found myself in using the eyeball and ruler method. If I'd had the Park indicator then it would have more than paid for itself immediately.
... Just a thought.
Hawkeye
Users browsing this forum: Dan, JBark, liamw
