Cassette turns freely in both directions
Postby JFJ » Sat Oct 01, 2011 7:19 pm
I have an old second hand Apollo MTB. It appears to be a freewheel shimano Hub (from all the reading I am doing).
Does it just sound like a loose lock ring or will it be worse? There doesn't seem to be any lateral movement in the cassette so I am a bit worried that there is some kind of internal problem??
I appreciate you thoughts and advice!
- il padrone
Re: Cassette turns freely in both directions
Postby il padrone » Sat Oct 01, 2011 7:31 pm
I ask that as almost all Shimano gears used freehubs since the early 80s. A freehub will have a telltale bulge on the rhs of the hub shell, or if more recent, a larger diameter hub shell.
Your problem may be a number of things, but one simple cause may be someone servicing the cassette/freewheel using grease, which can cause the pawls to stick and fail to catch on the internal ratchet. Easy fix (for a freewheel) is to rinse with kero and re-lube with chain lube, a little trickier with a freehub.
Postby JFJ » Sat Oct 01, 2011 7:49 pm
I just unscrewed most of it (with the exception of the cassette as I dont have a tool for that) and it appears that the bearings on the cassette side arent actually all the way around the inside. On the non drive side they form a nice circle around the axle but on the drive side the bottom has bearings side by side and none on the top of the cavity.. if that makes sense?
Logic tells me to get a tool to unscrew the cassette, reset the bearings in their rightful place then re tighten... Does that sound close to a solution?
- il padrone
Postby il padrone » Sat Oct 01, 2011 8:03 pm
If you've pulled the cone off you are looking at the first row of bearings (in green), the hub bearings. There should be a full ring around the cup, with at most one ball gap. Sounds like someone has pulled it apart and rebuilt it with less than the requisite number of ball bearings.
This is not the solution to your freewheeling problem however .
Postby JFJ » Sat Oct 01, 2011 8:12 pm
Well maybe the next step for now is that I will get the tool to remove the cassette and have a look at what is going on inside...At least this way I can report back with some photos if I am still stumped..
I know this is really a job for my LBS, but if I do that I won't learn anything which I would much prefer to do..
Postby human909 » Sun Oct 02, 2011 12:07 pm
You really DON'T want to be taking apart freewheels and freehubs. The better way is to bath them in kero or degreaser first and see how it goes. If that doesn't work the the best option is to buy a new one! They can be have for around $25 for a freewheel or $70 for a whole new wheel if it is the freehub.JFJ wrote:Wouldnt surprise me.. I knew I should have checked the bike out a little more thoroughly before buying! But hey it was only cheap..
- il padrone
Postby il padrone » Sun Oct 02, 2011 12:12 pm
+1human909 wrote:You really DON'T want to be taking apart freewheels and freehubs.
I've been messing about with bikes for over 35 years and only once have I pulled down a freewheel. Never put it back together, just too many tiny bearings to be bothered getting back into place and pawls to hold in (it was an old worn cluster).
Freehubs would be even worse - I've never pulled the freewheel section apart.
Postby JFJ » Sun Oct 02, 2011 6:51 pm
Good advice re- kero.. I ended up just bathing it in kero and now when freewheeling backwards I get the nice clicking sound, so I am guessing the spring inside was gunked up.
I can still hear some grit in the mechanism, so I am still tempted to open it up but now I need to take back the freehub unlocking tool and get the freewheel tool...
- il padrone
Postby il padrone » Sun Oct 02, 2011 7:33 pm
Noo!! You'll totally f#%& it up....... Oh, that's OK, I see. Have you taken the freewheel off the hub?JFJ wrote:I can still hear some grit in the mechanism, so I am still tempted to open it up but now I need to take back the freehub unlocking tool and get the freewheel tool...
Just more rinsing with kero. With the freewheel off the hub, dunk the whole thing in an ice cream container of kero and spin it. Let it dry out, then get the chain lube into it.
Postby JFJ » Sun Oct 02, 2011 7:49 pm
I have some machine oil.. will that be OK? Also have some of the wax chain lube..
Postby JFJ » Sun Oct 02, 2011 7:51 pm
Postby human909 » Sun Oct 02, 2011 10:14 pm
They cost $25. http://www.this link is broken/Shimano-MF- ... -Freewheel
- Mulger bill
Postby Mulger bill » Mon Oct 03, 2011 12:43 am
I really should pull that old cluster apart just to see...
- il padrone
Postby il padrone » Mon Oct 03, 2011 8:30 am
And, yes, to clean out the freewheel, dunk it completely into the kero, but do this with it off the hub.
Postby JFJ » Mon Oct 17, 2011 8:03 pm
Sorry to drop off the radar.. went on a holiday.
So now I have the correct tool I took off the freewheel from the hub and after a lot of investigation have worked out that the thread on the hub is totally gone.. With the kero and the clean out of the cassette it seems to be totally fine and running better than ever..
I am thinking that considering this is a low-low-low budget exercise that I might just buy a new wheel with freewheel attachment..
Input and throughts otherwise always welcome.
And thanks for getting me to this point!!
- HappyHumber
Postby HappyHumber » Mon Oct 17, 2011 8:42 pm
I actually had a freewheel strip the thread off a hub once - heading out of an exit ramp from basement carpark. I guess the wear though was a gradual torque thing. This was in the days before I started doing a lot more of my own bike maintenance and when I took the bike into my LBS, I distinctly remember them being quite surprised at what had happened..
I had owned the bike since new - a lower to mid range 1990s rigid framed Raliegh MTB. I'd moved to the city and done quite a number of Ks on it by this point with my new commuting regimen. I had started wearing out a lot of things on it and was beginning to develop an appreciation for the finer differences in quality & construction in bikes.
Postby JFJ » Mon Oct 17, 2011 10:50 pm
Hub looks cheap and the cassette threads look fine! Just a few shredded bits of hub thread inside it!...
Do I just try to buy a new hub, or should I get a whole new wheel? A bit scary the thought of undoing spokes etc...
Postby JFJ » Tue Oct 18, 2011 1:48 pm
- HappyHumber
Postby HappyHumber » Tue Oct 18, 2011 2:07 pm
You still referring to the freewheel as a cassette keeps doing my nut though each time I read the subject header
Postby JFJ » Tue Oct 18, 2011 5:20 pm
Postby JFJ » Mon Oct 24, 2011 11:48 am
Thanks everyone for your help - and I hope this thread might be of use to someone with the same problem as me in the future.
I know when it comes to new chain etc that I will probably either sell this POS and move on or convert to a freehub system (buy another tyre!).. It just makes more sense
