Bikeshop workshops you'd rate.
Schmenz
Postby Schmenz » Tue Oct 18, 2011 10:05 am
I need to put my bike in to get a rear cassette changed.
I can go to several different bike shops so am wondering which ones you would recommend as I don't want to have a dodgy job done.
(I am not sure on the forum rules regarding this, but if we avoid saying x shop is bad because of x that should be ok, and just recommend the good ones :D)
choices are
blackman bicycles parramatta
bike barn parramatta
cylcesport thornleigh
turramurra cyclery
hornsby cycles
(or any in the parramatta, hornsby area. I am also happy to go to north sydney as well. I do need something with decent opening hours preferrably).
Newbie to the cycling world.
2011 Giant TCR Advanced W
http://www.sea2summit2011.blogspot.com
Re: Bikeshop workshops you'd rate.
Postby Mulger bill » Tue Oct 18, 2011 10:13 am
Hate to sound rude Schmenz, but why not pick up the tools and get stuck in yourself?
A/ You will know the job is done right.
B/ The satisfaction from knowing that you need never be stranded by a roadside mechanical.
Cassette change would be a great place to start, while specific tools (2) are needed, the job itself is even more of a doddle than crucifixion. :wink:
Shaun
jimsheedy
Postby jimsheedy » Tue Oct 18, 2011 10:29 am
Buy this
one of these
some of these
And have a go yourself.
There are some jobs im wary of and will happily pass them onto a mechanic. But there are plenty that are pretty easy. Follow all the steps and give yourself plenty of time.
Don't start new jobs the night before an early ride.
CommuRider
Postby CommuRider » Tue Oct 18, 2011 10:39 am
And when I first joined, someone posted this
http://bicycletutor.com/
Schmenz
Postby Schmenz » Tue Oct 18, 2011 10:45 am
CommuRider wrote:And when I first joined, someone posted this
oooo where have you been all my life!
thank you!
Doing it myself is definitely something I want to learn but I am pretty pressed for time at the moment and am happy to get someone else to do it. But once its done, if i want to change it back - im definitely going to look at doing it myself!
Postby Mulger bill » Tue Oct 18, 2011 10:53 am
A DIY cassette swap should take less time than actually taking the bike to the LBS. Budget for 15 minutes including the post job brew of coffee. :wink:
Schmenz
Postby Schmenz » Tue Oct 18, 2011 10:54 am
Mulger bill wrote:A DIY cassette swap should take less time than actually taking the bike to the LBS. Budget for 15 minutes including the post job brew of coffee. :wink:
oooo THAT easy!
so probs an hour for me.
rightio.
exactly what tools would i need? or anyone got a linky? will double check that bike tutor site.
CommuRider
Postby CommuRider » Tue Oct 18, 2011 10:55 am
Hmmm...MB, first time it took to install my rear rack it took 2 freaking hours!!! :evil: So never overestimate newbies, tools and dexterity :-P
Schmenz
Postby Schmenz » Tue Oct 18, 2011 10:59 am
i was going to drive to steve hogg which is an hour each way.. so either way.. 2 hrs and im still even.
although it took me 2 hrs to clean my bike on the weekend :( and 4 hrs for my car :(
janus77
Postby janus77 » Tue Oct 18, 2011 11:15 am
i"ll probably go down in flames for suggesting this, but i've found the guys at Clarence St Cyclery to be pretty good, and reasonably priced... (compared to some others i've encountered).
Not too far from North Sydney if you're around there.. otherwise doesn't really matter with a cassette change, it would take a REMARKABLY poor bike mechanic to stuff that one up.
Schmenz
Postby Schmenz » Tue Oct 18, 2011 12:01 pm
janus77 wrote:i"ll probably go down in flames for suggesting this, but i've found the guys at Clarence St Cyclery to be pretty good, and reasonably priced... (compared to some others i've encountered).
I like clarence street. really helpful and my sister really rates their service.. but parking is a NIGHTMARE! it drives me mental everytime i go in. :evil:
ozdavo
Postby ozdavo » Tue Oct 18, 2011 12:09 pm
1. Cassette Lockring Tool
2. Chain Whip
You may also need a chain breaker to replace your chain (which should ALWAYS be done with a cassette change IMO.
GL
Schmenz
Postby Schmenz » Tue Oct 18, 2011 12:39 pm
ozdavo wrote:1. Cassette Lockring Tool
2. Chain Whip
GL
oo ta.
I've only had the bike since July and it has probably just hit 1K. I have asked around when I was discussing changing it all and everyone seemed to say the chain would be fine.
Schmenz
Postby Schmenz » Tue Oct 18, 2011 2:58 pm
Ok so I gave in. Had an hour to kill in north syd this afternoon so went to clarence. Again I am reminded about why I hate it's location! No parking anywhere. All loading zones. Gave in and used the qvb. Will make it a tax deduction :D
Still a pain in the .... Tho. But it's done, and I'll get the gear and learn to do it for next time :)
Physio then akuna bay to test it! :D
MarkG
Postby MarkG » Tue Oct 18, 2011 4:21 pm
The tools aren't overly expensive (chain whip and lock ring spanner anyway).
Just remember a cable tie, to keep all the sprockets and spacers in their right order!
Take the time to build up an extensive kit of tools, lubes etc, and do it yourself!
Just think, you can pay $150 to get a cassette from your LBS and get them to fit it, or pay $50 and get it on line, and do it yourself!
Then you can spend the money you saved on taking your wife to dinner!
or be like me, and spend the extra $100 on more bike parts!
Postby singlespeedscott » Tue Oct 18, 2011 5:51 pm
Schmenz wrote:I've only had the bike since July and it has probably just hit 1K.
unless you have been riding in sand there is no way your cassette could be stuffed after 1000km.
TimW
Postby TimW » Tue Oct 18, 2011 5:57 pm
Scott, i think Schmenz is riding in a challenge shortly from Sea to summit, and i would imagine has fitted a more climbing suitable cassette.I may be wrong.Tim
Postby trailgumby » Tue Oct 18, 2011 6:39 pm
Hmmm... should have chimed in earlier. KOM2 at Crow's Nest is pretty good. Would have saved you a frustrating drive and park and paying the 25% above retail that CSC routinely charges for parts.
Next time, ask for Brad Prescott and tell him hawkeye from nobmob sent you.
Bike Addiction at North Manly is also decent in my experience.
Schmenz
Postby Schmenz » Tue Oct 18, 2011 8:47 pm
TimW wrote:Scott, i think Schmenz is riding in a challenge shortly from Sea to summit, and i would imagine has fitted a more climbing suitable cassette.I may be wrong.Tim
Yup that's it. An 11-28
My compact chainset is lost in the mail :(
TG - oddly enough I went to KOM on the way home! Well way to Akuna bay.
spirito
Postby spirito » Tue Oct 18, 2011 11:01 pm
If we ever see you selling a bunch of bike parts on the MarketPlace forum we'll know that Mrs.G has been reading these forums !!! :lol: :wink: :P
MarkG
Postby MarkG » Wed Oct 19, 2011 11:49 am
She knows not to read the BNA forums and the stick to the "Good housewives" forums!
human909
Postby human909 » Wed Oct 19, 2011 12:03 pm
Abbotsford Cycles.
A proper bike workshop. It doesn't even sell bikes! Its like having a workshop full of Sheldons.
(But I do all my own bike work.)
master6
Postby master6 » Wed Oct 19, 2011 7:33 pm
Unless you live on the street, do it in your workshop. This can be the kitchen sink, or any of a number of places where you live. Do you have a pitched roof?
Schmenz
Postby Schmenz » Wed Oct 19, 2011 8:05 pm
I would definitely rate mine as one to miss!
Washed bike, relubed with not enough lube. Now the left brake sticks and is nasty, and no matter how I tweak the front derailleur, it still makes a horrible clicking noise as each chain link flicks past it.
master6
Postby master6 » Wed Oct 19, 2011 8:20 pm
Schmenz wrote:I would definitely rate mine as one to miss!
Perhaps you need a pen and paper?
Take one problem at a time. eg left brake. Now list some possible causes. eg . cable frayed in brake handle, crap in rear brake arms, cable dry/needs lube.
Now sit down and think of one possible cause at a time, and devise a method to test for each possible problem.
Should I go on?
