How Do U Adjust The Gearing On A Racer
Unko
Postby Unko » Mon Feb 04, 2008 12:03 pm
ok then i have an ocr with sora gearing on it i was just wondering how u move the frount deralier. I can only use 1 to 5 gears on the middle frount cog. Its really enoying when I have to change up to the big frount cog for a little bit then change back to the middle cog. I have tried before and it didnt make muchof a difference. So dou have the trun the bolts one deralier much??? the rear deralier is easy to do i can do that one fine
Unko
sogood
Postby sogood » Mon Feb 04, 2008 12:55 pm
Can't be well explained by a few lines in a forum. Check out Park Tool's instructions.
http://www.parktool.com/repair/byregion.asp?catid=53
Kalgrm
Postby Kalgrm » Mon Feb 04, 2008 1:05 pm
Edit: Oops - too slow ..... :oops:
Try the Park Tools site: lots of useful info on how to adjust your derailleurs (F & R)
Graeme
Dcyclist
Postby Dcyclist » Mon Feb 04, 2008 8:57 pm
I have found Sheldon Browns site to be very useful as well,
http://sheldonbrown.com/gearing/index.html
Gear adjustment is one of those things which seem like a black art before you learn how, but once learned, is not that hard usually. Hope it all helps unko.
Dave
Merida Scultura 904
Avanti Blade8
Bianchi C2C Via Nirone
Specialized Hard Rock
uncle arthur
Re: How Do U Adjust The Gearing On A Racer
Postby uncle arthur » Mon Feb 04, 2008 11:24 pm
Unko wrote:ok then i have an ocr with sora gearing on it i was just wondering how u move the frount deralier. I can only use 1 to 5 gears on the middle frount cog. Its really enoying when I have to change up to the big frount cog for a little bit then change back to the middle cog. I have tried before and it didnt make muchof a difference. So dou have the trun the bolts one deralier much??? the rear deralier is easy to do i can do that one fine
Unko
Actually - that's quite normal - you shouldn't be able to go from biggest cog to smallest cog on the cassette in one fell swoop without changing on the chainrings - the chain isn't meant to bend through the extreme angles - if you are you're harming your drivetrain..... that grinding noise as the chain rubs on the dérailleurs and chainring teeth is actually bad and means change gears.
I find on the small chainring (your middle) I can go through the top 5 cogs on the cassette - then it's up to the big chainring, and back up one or two on the casette to be back in a similar ratio with further to go.
That said, adjusting the front dérailleur isn't difficult.
Unko
Postby Unko » Mon Feb 04, 2008 11:33 pm
thanks heaps people
Hawkeye
Postby Hawkeye » Thu Feb 07, 2008 2:10 pm
If you have a triple on the front you shoudl be able to get 2 thru 9 or 1 thru 8 no problems from the middle front chainring on a 9-speed rear transmission.
