this is a conti explorer that failed on me today:
it failed where the sidewall sits against the rim edge. it looks like the rim edge has cut through the side wall. i went off-roading last night, so maybe that put a bit of pressure on it. i also run about 50-60 psi for commuting, but also for off-roading (only last night - first time in ages) as i mix that in with my commute.
another possibility is that it was a slow leak and the reduced pressure meant that the tyre sidewall was pinched in between the rim edge and pressure imposed by the contact patch (it flatted - but i'm unsure if the flat was caused by the tyre failure, or vice versa - haven't had a chance to check the flat tube yet).
i've had several tyres fail like this - different brands. any clues as to the cause? have others experienced similar tyre failures?
the tyre - a conti explorer 26" MTB tyre is about a couple of years old, but hasn't had much use - maybe several 1000 km of mostly commuting on bitumen/concrete.
tyre failure
- jules21
- trailgumby
Re: tyre failure
Postby trailgumby » Tue Nov 08, 2011 11:11 pm
I've had that happen to a Conti Sport Contact 26x1.3, a couple of minutes after I completed the highest-traffic, highest speed part of my commute
The tyre was pretty close to beng retired due to being squared off (obviously a rear), and I had a history of running it continuously at or very close to the max recommended pressure. I notice that you seem to do the same with this mtb tyre ... maybe that's a common element?
The bike mechanic at the shop I was frequenting at the time confidently asserted that the sidewall pressure markings were conservative, and that the tyre would readily cope with 15-20% or more over the number. With experience since, I'm not so convinced.
Re: tyre failure
Postby rkelsen » Wed Nov 09, 2011 10:02 am
IME, sidewall markings are optimistic. Eg: road tyres rated to 150psi. It's pure crud. Nobody needs that much pressure in a road-going tyre.
- jules21
Re: tyre failure
Postby jules21 » Wed Nov 09, 2011 10:24 am
i suspect that at least in my case(s), the cause could have been the opposite - a slow leak, allowing the sidewall to 'crease' across the rim edge. but i'm unsure - other than knowing that each failure was associated with a tube puncture. but it's a mystery to me which was the cause and which was the symptom.trailgumby wrote:The bike mechanic at the shop I was frequenting at the time confidently asserted that the sidewall pressure markings were conservative, and that the tyre would readily cope with 15-20% or more over the number. With experience since, I'm not so convinced.
but what you need and what they can withstand are two different things. 60 psi is also a lot lower pressure in a tyre with a fairly robust carcass.rkelsen wrote:IME, sidewall markings are optimistic. Eg: road tyres rated to 150psi. It's pure crud. Nobody needs that much pressure in a road-going tyre.
Re: tyre failure
Postby rkelsen » Wed Nov 09, 2011 10:41 am
Yep. Dunno how they test them, but I had the exact same thing happen to a 'robust' 32mm tyre rated to 85psi. I ran it at 60psi for most of it's 4,500km life...jules21 wrote:but what you need and what they can withstand are two different things. 60 psi is also a lot lower pressure in a tyre with a fairly robust carcass.
Then again, it was a Kenda Kwest. Swapped it out for a Continental Sport Contact (again, rated to 85psi but running at 60), and haven't looked back...
- Nate
Re: tyre failure
Postby Nate » Wed Nov 09, 2011 3:43 pm
My mate blew out a Conti 4k - surprisingly just after he CO2 inflated it, went off like a shot-gun!
- Mulger bill
Re: tyre failure
Postby Mulger bill » Wed Nov 09, 2011 6:21 pm
I had an out of the box new WTB Velociraptor do that to me on initial fitting while I was crouched over the pump, took 5" before I could hear anything quieter than a passing F/A18.
Never got a reply from the company
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
