Page 4 of 6
Re: Schwalbe Ultremo blowing off rim
Posted: Wed Dec 12, 2012 6:24 am
by Comedian
From my in box.
Dear Sir,
Thanks for your interest in our product.
140psi is definitely no problem for our 23-622 Ultremo DD. Our 25-622 Ultremo DD is limited to 130psi, but shouldn´t blast up to 290psi anyway!
I guess tire and rim size suit each other, right (both 622)?
The tube is not clamped in between rim horn and tire bead?
Can you see any defect at the bead area?
Best regards
Christian Lademann
Product management race
SCHWALBE - Ralf Bohle GmbH
Otto-Hahn-Str. 1
51580 Reichshof
GERMANY
Mobile : +49 170/8312209
Tel. : +49 2265/109942
Fax. : +49 2265/10968
skype : XXXXXXX
E-mail : XXXXXX
http://www.ultremo.com" onclick="window.open(this.href);return false;
http://www.schwalbe.com" onclick="window.open(this.href);return false;
Registered at court: Siegburg HRB 8044
> ----------------------- Anfrage über
http://www.schwalbe.de" onclick="window.open(this.href);return false; -------------------
> Sehr geehrte Damen und Herren,
> Sie haben eine Anfrage über Ihre Webseite erhalten.
> Daten der Person:
> Strasse: XXXXXXXXXX
> PLZ/Ort: XXXXXXXXXXXXX
> Land: Australia
> E-Mail: XXXXXXXXXXXXXX
> Thema: Technische Fragen
> Nachricht:
> Hi,
> I have purchased Ultremo DD and when I inflate it it blows off my Mavic
> Kysrium Elite wheels. I\'ve tried once at 140psi, and once at 130psi.
> I put the tyre on the rim by hand and then inflate a little to check the
> bead. I have them pumped to pressure and it blows off a minute or two
> later. I\'ve never had trouble fitting tyres before. Can you advise what
> I should do with this tyre?
> Thanks,
> Comedian.
> ---------------------- Fragen:
info@schwalbe.de -------------------------
Posted: Wed Dec 12, 2012 9:45 am
by winstonw
usernameforme wrote:could someone please explain to me how spoke tension causes tyres to blow off rims?
I suppose someone includes me.
Overtensioning can crack nipple holes, crack or deform nipple heads, bring the spoke thread closer to the tube, distort the rim.
The higher the tube pressure, the more the tube will push into/against the nipple head or protruding spoke thread.
A tube that bursts under high pressure can blow a rim off.
Putting cost aside, I think it would be very interesting to see whether Comedian's problem persisted after a wheel rebuild on the C50s.
It would also be a meaningful troubleshooting step to put Comedian's blowing tires on several of his mate's wheels. If they don't blow off those, what's to be made of that?
Posted: Wed Dec 12, 2012 1:13 pm
by usernameforme
The RS80-C50 are a deep section wheel, I don't think that the spoke thread is going to protrude out of the hole. If the spokes were to protrude out of their holes (on say something shallower) it means your spokes are too long. If the high tension does indeed distort the rim, the wheel would not be true and I'm sure the OP would have noticed that... Or am I missing something?
Posted: Wed Dec 12, 2012 2:19 pm
by jacks1071
Comedian wrote:From my in box.
I'm going to call BS on their claim that the tyre should stay on the rim up to 290psi. I don't know of any clincher rim that'll even handle that kind of pressure.
The process you're following if anything is far too careful, I've never done ANY of that stuff and have never had a road tyre blow off.
I'm feeling that you're stretching the casing when you are going to those 130-140psi pressures, at this point in time my money is that this is the cause of your problem and the tyres that you've done that with are toast. You shouldn't ever have a requirement to pump a clincher past 120psi and unless you are a really heavy rider 120psi is too much for most people.
Easy enough to test.
Get yet another new set - don't pump them past 110-115psi and see how you go.
If you want to really take care of your tyres and take it a step further, let them down to 60-80psi inbetween rides. I do this on my race clinchers and the tyres are always TIGHT on the rims even after sometime. Whereas my training tyres that are left pumped up are quite loose on the rim by the end of their life.
Posted: Wed Dec 12, 2012 2:29 pm
by winstonw
usernameforme wrote:Or am I missing something?
The rim tape may have stretched due to age, regular high PSI, heat exposure within a car boot....and may not be protecting tubes from sharp rim holes and high PSI....in which case a layer or two of new tape (reinforced at valve hole), or veloplugs would be informative.
From what I understand the problem hasn't always existed with these tires for Comedian. So either something about the tires has changed, or the wheels, or both.
Posted: Wed Dec 12, 2012 7:18 pm
by ironhanglider
Veloplugs would certainly eliminate any doubts with rim tape.
It is possible that the blow offs are caused by different issues.
I know that technique issues have been raised and brushed off before so I am only restricting my comment to the most recent failure and the fact that it coincided with the valve. Since the tube has a patch of reinforcing there it is a common place to pinch a tube. I also note that Comedian's valves only barely make it out of the deep rims.
FWIW I always install a tyre and finish at the valve since the finish point is the most likely for a tube pinch. The reason that I finish at the valve is so that I can push the valve back though the rim into the tyre as far as it will go. This is enough to be absolutely sure that there is no pinch at that point.
As for excessive pressure that is not the problem. Tandem riders routinely exceed the recommended pressures and experience no problems with cold tyres. (Heating tyres up with rim brake use does cause problems though and this is well known, but pressure alone is not an issue)
Cameron
Posted: Thu Dec 13, 2012 1:33 pm
by jules21
stnfldr wrote:I had the same problem once, turns out I hadnt taken the little valve nut of the valve, so every time i inflated the tyre it popped off the rim......
this is an easy mistake to make - i've done it numerous times. where the valve is molded into the tube, the tube is more rigid. it is easy for that section of tube to become wedged under the tyre bead and as you inflate it, lift the bead off the rim.
the trick is to ensure the tube, where the valve is molded into it, is stuffed high up into the tyre. it's important to remember that pulling the valve downwards to allow the pump chuck to gain a good purchase on the valve may interfere with that, by pulling the tube down below the tyre bead. a solution here is long valves.
i'd like to know that too..
Posted: Thu Dec 13, 2012 3:26 pm
by winstonw
jules21 wrote:usernameforme wrote:could someone please explain to me how spoke tension causes tyres to blow off rims?
A competent wheelbuilder told me one cause of a cracked rim, similar to below, is an extrusion weakness unmasked by excessive spoke tension.
Posted: Thu Dec 13, 2012 3:34 pm
by jules21
i would imagine such a failure would be more likely to occur along the section of rim at which the spokes attach (i.e. the inner section, not the outer tyre seat as shown). either way, would that crack cause the tyre to blow off the rim?
Posted: Thu Dec 13, 2012 3:49 pm
by winstonw
jules21 wrote:i would imagine such a failure would be more likely to occur along the section of rim at which the spokes attach (i.e. the inner section, not the outer tyre seat as shown). either way, would that crack cause the tyre to blow off the rim?
a crack isn't excluded from where there's an extrusion weakness.
if a tube is pumped to high enough pressure, it could open the crack further, and move into it, burst, and blow the tire.
Posted: Thu Dec 13, 2012 3:52 pm
by jules21
winstonw wrote:the crack will occur where the extrusion weakness is.
fair enough. but "blow the tire (up)" and "blow the tire off the rim" are different, as i interpret them. what we're discussing is the tire bead unhooking from the rim seat, not the tyre itself failing.
Posted: Thu Dec 13, 2012 4:02 pm
by winstonw
I've seen tires blow off the rim before, on bikes not moving, and it was always accompanied by a blown tube.
Whether the tube blew first, or the tire moved enough to come off then cause the tube to blow, was impossible to tell.
Posted: Thu Dec 13, 2012 4:07 pm
by jacks1071
winstonw wrote:jules21 wrote:usernameforme wrote:could someone please explain to me how spoke tension causes tyres to blow off rims?
That looks more like a fatigue crack caused possibly by excessive tyre pressure. Exactly why you shouldn't run too much pressure in a clincher.
Spoke tension isn't going to crack the rim in that spot, the nipples anchor in the outer edge.
Posted: Thu Dec 13, 2012 4:20 pm
by jules21
winstonw wrote:I've seen tires blow off the rim before, on bikes not moving, and it was always accompanied by a blown tube.
yep - which was my original question. the suggestion was spoke tension could cause it. we're no closer to knowing how
Posted: Thu Dec 13, 2012 8:16 pm
by usernameforme
I'm going to call BS on this, on a clincher rim, tyre pressure effects spoke tension BUT NOT THE OTHER WAY AROUND.
Posted: Fri Dec 14, 2012 8:00 am
by WMC1
May be of interest, I found this in the Barnett's repair manual.
"SYMPTOM: Tire seats correctly initially, and then blows off of rim."
Tire was over-inflated. Inspect for bead damage, then re-install.
Tire bead is damaged. Inspect for damage and replace.
Seems it could be pressure related. Cheers.
Posted: Fri Dec 14, 2012 9:12 am
by winstonw
jacks1071 wrote:That looks more like a fatigue crack caused possibly by excessive tyre pressure. Exactly why you shouldn't run too much pressure in a clincher.
That might be more appropriate for a perfect wheel. But as my wheel builder alluded, rim extrusion faults or real world rims possibly compromised by heavy pothole hits or bunny hops requires a subtler approach to troubleshooting. Barnett's Manual also says: "Cracks around nipple holes or at the inner perimeter of the sidewall usually indicate excessive spoke tension."
Posted: Fri Dec 14, 2012 11:13 am
by jules21
i suspect jacks meant the "inner edge" - which is where the spokes anchor and where your manual suggests they'd crack.
Posted: Fri Dec 14, 2012 1:18 pm
by jacks1071
jules21 wrote:i suspect jacks meant the "inner edge" - which is where the spokes anchor and where your manual suggests they'd crack.
Yes exactly. That being said, cracks around the nipples can be just as easily caused by not enough tension as they can by excessive tension. Not to mention good old fashioned wear and tear - metals fatigue and everything has a useable life. Premature failures though, either too little, or too much spoke tension.
If you get a split up the middle of the rim where the tube sits (ie. under the rim tape) - this most likely excessive pressure related in my opinion. Its not uncommon for full carbon clinchers to have similar failures. Less common, I'd even say very rare on alloy wheels. As you increase the pressure, the tyre bead is trying to open the rim up like a banana.
Posted: Fri Dec 14, 2012 9:18 pm
by winstonw
Jack (deon?), do you think a wheel tensioned to 50kgf will be harder/easier to fit a tire to than the same wheel tensioned to 200kgf?
Posted: Fri Dec 14, 2012 10:17 pm
by ironhanglider
winstonw wrote:Jack (deon?), do you think a wheel tensioned to 50kgf will be harder/easier to fit a tire to than the same wheel tensioned to 200kgf?
Why would you try to fit a tyre to a pringle?
I presume that you are trying to suggest that at higher tension the BSD of the rim is less than at lower tension. This may have been true of the old pinned rims with a visible gap at the join that closed under tension (Fiamme Red label anyone?), but if there is a difference in a welded or bonded rim it is negligible. How much do you reckon that you can compress aluminium? (or CFRP)
I have seen a theme in your posts that you seem to believe that an exploding tube can blow a tyre off a rim. I do not believe this. The bang occurs when the tube suddenly expands such as when it is no longer contained, either when the bead lifts off the rim, or there is a failure of the sidewall. Internal punctures off spokes, cracks etc tend to cause a rapid pssst but not a bang IME. Uncontained tubes will explode at very low pressure differentials, 10psi or so, tubes that are contained within a pressure vessel such as a rim, tape, tyre combination do not have to support any pressure differential because the container is providing the support. If that support is taken away such as when the bead lifts off the rim the tube will go bang.
BTW spoke tension will not cause the cracking on the tube side of a rim. Spoke tension will in fact act to draw the sidewalls of the rim together (weakly), whereas air pressure is trying to tear the sidewalls apart and is a much more likely cause.
Cameron
Posted: Fri Dec 14, 2012 10:59 pm
by winstonw
ironhanglider wrote:Internal punctures off spokes, cracks etc tend to cause a rapid pssst but not a bang IME.
3 weeks ago, I had 3 tubes "bang"....no tire off...they punctured via a growing hole in the side wall of the tire...witnessed by two experienced audax mates....
I've also experienced the tube caught between tire and rim bang when the brakes are first applied 200 metres from where an LBS mechanic sloppily installed the new tube. no tire off again.
no theme or tidy theory I'm afraid....just harsh light of day reality clocking up the k's.
and here's last Wed's bang......towards the rear of a C grade bunch sprint....tire not even partially off.
Posted: Fri Dec 14, 2012 11:28 pm
by toolonglegs
Lot of people looking backwards in that photo
... If it doesn't bring me down I prefer to keep my eyes looking forward when I am two inches off someones else's wheel!.
Posted: Sat Dec 15, 2012 12:26 am
by jacks1071
toolonglegs wrote:Lot of people looking backwards in that photo
Too right, fully clenched and push hard as you can and hope the carnage doesn't catch up with you.
Posted: Sat Dec 15, 2012 12:32 am
by jacks1071
I don't think it'd make any difference. The spokes are to support the rim, I don't think cranking the tension is going to reduce the overall diameter of the wheel.
I've fitted tyres to rims that wern't built up for displays and they were no easier or harder than a fully assembled wheel.
The more I think about this issue, the more I am confident that the OP is stretching the tyres by over inflating them. Although he's well within what the tyre manufacturer says the tyre is capable of I don't think the tyre manufacturer's "max" is realistic.
This is assuming his rims arn't all cracked up the centre like one of the pictures someone posted
