Page 1 of 1
pin spanner question...
Posted: Mon Feb 18, 2008 5:03 pm
by winona_rider
It seems i needthis tool to remove my current bottom bracket...
does anyone have any tips on how to remove it maybe without buying that tool, keeping in mind i don't need to keep the existing BB?
Posted: Mon Feb 18, 2008 5:16 pm
by sogood
LBS would probably be willing to do the job for $5.
Posted: Mon Feb 18, 2008 5:17 pm
by winona_rider
i just wanna macguyver something dammit!
Posted: Mon Feb 18, 2008 5:24 pm
by sogood
How about $2? :wink:
Posted: Mon Feb 18, 2008 5:26 pm
by europa
There are a variety of tools that will do the job ... provided it isn't in too tight which is a very distinct probability. Of course, they were all designed to do other jobs, but there are tools out there. You probably won't find them in Bunnies though.
Unless you want it done in a hurry (in which case the lbs is the best bet), haunt the second hand tools markets and I'm sure you'll find something sooner or later :D
If you want to make something, go into a model aeroplane shop and buy some spring steel. Modellers use it for undercarriages and it'll probably be the same stuff as Park Tools use to make theirs. Ordinary fencing wire won't do it if you need a lot of force. Just make sure you get exactly the right piece of wire (use the blind end of a drill bit to measure it) because it comes in a wide range of sizes and you won't get it right by guessing.
by winona_rider
Posted: Mon Feb 18, 2008 5:28 pm
by stryker84
So glad they picked him for SG-1 though, instead of Kurt Russell from the movie.
Posted: Mon Feb 18, 2008 5:30 pm
by winona_rider
thanks richard
one more thing...on the crank side - to loosen i would be turning anti-clockwise right?
Posted: Mon Feb 18, 2008 5:34 pm
by europa
winona_rider wrote:thanks richard
Unless it's one of them weird dago bikes, you turn towards the front to do one thing and turn towards the back to do the other ... but I can never remember which is which (got Tuco's disease)
Posted: Mon Feb 18, 2008 6:14 pm
by tallywhacker
you can try 2 lengths of wood (1cm square) in the shape of a V, drill a hole in the end of each and push a nail thru. I made one up out of an old spoke, not particularly robust but it did work.
Posted: Mon Feb 18, 2008 7:47 pm
by dr.gonzo
A cheap pair of circlip pliers will do the job
just make sure you get the squeezy out not squeezy in type (unless they have good reach).
I got some for $2.50 from a 2nd hand tool stand at a sunday market.
Before that i had tried the homemade type.. Not worth the hastle..
Posted: Mon Feb 18, 2008 8:22 pm
by thomas_cho
I would go to the LBS. If you DIY it, you might damage the holes, and even the proper tool may not extract it.
My LBS would do these kind of jobs free ... and I always end up buying something from them, handlebar tape, or the like.
Posted: Mon Feb 18, 2008 8:54 pm
by winona_rider
UPDATE!
OMGosh - i got it loose! i don't know how i did it - i suspect it was loose already - but it is free!
now i just have to get the other side off. i bought the specific tool for this job, but it seems to be about 1mm too big. it just won't fit.
i am crushed!
Posted: Mon Feb 18, 2008 11:20 pm
by Mulger bill
Bugger.
OK MacGyver, seeing as the BB's a binner....
You'll need a bigarse bolt, two nuts and some penetrene or similar. The bolt has to fit thru the spindle hole in the cup, the nuts have to be a tight fit inside the cup. Spin a nut on far enough so there is enough thread showing to get the second on once you've put the bolt through the hole from the inside. Sandwich the cup between the nuts and tighten down hard. Too see if it will work for you, try turning the bolt head clockwise.
I haven't done this myself, but I've seen it done. :roll: Good luck and don't forget the penetrene.
You could still try the LBS...
Shaun
Posted: Tue Feb 19, 2008 6:20 am
by Kid_Carbine
The left side, the one with the lock ring, is supposed to be loose once the lockring is loosened, so that it can be adjusted.
The drive side cup is the fixed one & is left hand threaded, so will need to be turned CLOCKWISE to LOOSEN it.
The correct tool can be determined once both cranks are removed & the B/B axle taken out. Some of these cups have flats, some don't & have pin holes only.
Strip the rest of it & have a good look. If you don't have a tool that will do the job, then completely strip the rest of the frame & take it to the nearest LBS that has a halfway decent workshop.
Posted: Tue Feb 19, 2008 11:47 pm
by Mulger bill
Kid_Carbine wrote:The drive side cup is the fixed one & is left hand threaded, so will need to be turned CLOCKWISE to LOOSEN it.
:oops: Who's a silly boy, thinking of his Eyetie frame... :roll:
Shaun
