Noisy Cranks - Newish Bike?
Postby Crawf » Sat Mar 01, 2008 10:39 pm
Have had my road bike for only 2 months now, and from what I can tell it seems to be the cranks making a real racket, and I mean embarrassingly bad racket. 20 yo clunkers with rusted out chains and cassettes make less noise than mine.
It churns out a clickety clack sound 90% of the time, if I ease right off the crank applying minimal rotational force only then does it ease up. I don't suspect it is effecting my drive/momentum. But its certainly not right.
It's running full 105 gear. I'd take it back to the LBS but I have not been impressed with their service and they wont be seeing my business again (even if warranty)
The bike has not been running smooth from day 1 and when I asked them to look at certain issues with the running gear during its first service there was minimal improvement.
Pretty frustrating when a work colleague has the same bike with zero issues.
I know its not much to go off, but can anyone maybe identify what the problem may be by the sound :/ ?
Crawf
by BNA » Sat Mar 01, 2008 11:12 pm
Postby Bnej » Sat Mar 01, 2008 11:12 pm
Probably just crank arms & BB needs tightening, maybe some grease.
Bnej
Postby Kalgrm » Sat Mar 01, 2008 11:26 pm
Also check that the pedals are inserted into the cranks tightly. The left hand side pedal is left threaded. (They should have greased the pedal threads before inserting them: my first annoying creak was a dry pedal thread.)
Graeme
Kalgrm
Postby sogood » Sun Mar 02, 2008 5:08 am
Take it back the LBS and let them sort it out.
sogood
Postby mikesbytes » Sun Mar 02, 2008 10:14 am
Hi Jacobite, as per sogood, it's the bike shops responsibility to fix it.
Noises on bikes can be deceptive and what appears to be a bottom bracket noise could be coming from pretty much anywhere on the bike;
- Seat
- Seat post
- Stem
- Front or Rear Wheel
- Pedals
- Cleats
- Crack in frame
- Bottom bracket
I've got stuff on ebay
mikesbytes
