Page 1 of 1
upgrading cassetts
Posted: Mon Apr 30, 2012 10:22 am
by OH DIO
hi guys i just want to know if i need any spacers for when i upgrade my cassette from 105 12-25t to ultegra 11-25t i will be fitting a new ultegra chain at the same time the wheels are shimano r500
Re: upgrading cassetts
Posted: Mon Apr 30, 2012 11:14 am
by scotto
nothing to change except the cassette.
leave the spacer on the hub thats already between the cassette and the spokes where it is.
Posted: Mon Apr 30, 2012 1:22 pm
by jasonc
scotto wrote:nothing to change except the cassette.
+1.
when you buy the cassette, it will come with a spacer anyway
Posted: Mon Apr 30, 2012 2:04 pm
by PawPaw
I did this about 6 mths ago and needed one spacer of the two that came in the ultegra packaging.
From memory it was because the ultegra cassette has a recessed space on the wheel side, and the 105 doesn't.
Posted: Mon Apr 30, 2012 3:34 pm
by antipodean
Both 105 and Ultegra 10 speed cassette's only need 1 spacer on the hub side unless you are using Mavic wheels which need their own spacer plus the Shimano.
What Pawpaw is on about 2 spacers for Ultegra only he would know.
upgrading cassetts
Posted: Mon Apr 30, 2012 4:28 pm
by toolonglegs
^^^ yup, only one shim spacer behind for both ( except on mavic hubs ).
Posted: Mon Apr 30, 2012 5:35 pm
by R12RT
antipodean wrote:Both 105 and Ultegra 10 speed cassette's only need 1 spacer on the hub side unless you are using Mavic wheels which need their own spacer plus the Shimano.
Only 1 spacer on th Mavic Ksyrium Equipes on my Oppy.
Posted: Mon Apr 30, 2012 7:07 pm
by toolonglegs
R12RT wrote:antipodean wrote:Both 105 and Ultegra 10 speed cassette's only need 1 spacer on the hub side unless you are using Mavic wheels which need their own spacer plus the Shimano.
You sure?... the big fat mavic spacer and if you are running 10 speed shimano there will be (or should be) the thin shim as well.
Mavic Ksyrium Equipe's you run ...
-Mavic spacer with shimano shim on 10 speed shimano cassettes...no shim on 9 speed.
-Remove Mavic spacer if you have a Mavic cassette.
-No spacer needed with Campag freewheel body / cassette.
Posted: Tue May 01, 2012 10:32 am
by scotto
my sons mavic's run one spacer, but its a bit different to the shimano ones from memory...
Posted: Tue May 01, 2012 12:07 pm
by PawPaw
antipodean wrote:What Pawpaw is on about 2 spacers for Ultegra only he would know.
ok, pick which is which in the pic.
Posted: Tue May 01, 2012 12:40 pm
by Jake
PawPaw wrote:antipodean wrote:What Pawpaw is on about 2 spacers for Ultegra only he would know.
Ultegra on the right.
Posted: Tue May 01, 2012 1:34 pm
by antipodean
They are both 10 speed of course?
Posted: Tue May 01, 2012 3:59 pm
by PawPaw
Jake wrote:Ultegra on the right.
what's your reasoning Jake?
Posted: Tue May 01, 2012 4:03 pm
by PawPaw
antipodean wrote:They are both 10 speed of course?
There's a 5700 and a 6700, both of which are 10 speed. Hopefully it's obvious their differences can result in a need for variable spacer numbers, on some freehubs, if you don't want to adjust limit screws and indexing.
Posted: Tue May 01, 2012 11:10 pm
by R12RT
toolonglegs wrote:R12RT wrote:antipodean wrote:Both 105 and Ultegra 10 speed cassette's only need 1 spacer on the hub side unless you are using Mavic wheels which need their own spacer plus the Shimano.
Yes. Just has the spacer that comes with the Shimano cassette. Unless there the Magic spacer is stuck on the free wheel and I haven't noticed it.
Posted: Wed May 02, 2012 7:45 pm
by Jake
PawPaw wrote:Jake wrote:Ultegra on the right.
Dunno, can't put my finger on it. Call it a hunch.
Posted: Mon Sep 17, 2012 9:12 pm
by ball bearing
I'm putting on a MTB XT cassette on a Shimano road freehub. The instructions say that the wheels are 8, 9 and 10 speed compatable with a 1mm spacer on a 10 speed cassette. I tried to tighten the lock ring to 40Nm but it came off and some tiny bits of thread were floating around.
I'd say that the lock ring did not engage enough threads to work properly. When I don't use the 1mm spacer it tightens normally, but there is a very tiny amount of play. Should the cassette have absolutely no play?
Posted: Tue Sep 18, 2012 4:16 pm
by biker jk
ball bearing wrote:I'm putting on a MTB XT cassette on a Shimano road freehub. The instructions say that the wheels are 8, 9 and 10 speed compatable with a 1mm spacer on a 10 speed cassette. I tried to tighten the lock ring to 40Nm but it came off and some tiny bits of thread were floating around.
If it's a 9-speed XT cassette then you don't need a spacer. If it's 10-speed you do. There should only be a tiny degree of play when tightened correctly.
Posted: Tue Sep 18, 2012 4:35 pm
by ball bearing
biker jk wrote:ball bearing wrote:I'm putting on a MTB XT cassette on a Shimano road freehub. The instructions say that the wheels are 8, 9 and 10 speed compatable with a 1mm spacer on a 10 speed cassette. I tried to tighten the lock ring to 40Nm but it came off and some tiny bits of thread were floating around.
I meant to say it was a 10 speed cassette. I don't think that there is a way to make it work with a spacer so it looks as though I will have to live with a bit of play. it's not much - only a slight wiggle.
Thanks.
