Better "grease life" for the bearings??
Re: Better "grease life" for the bearings??
Postby mick243 » Sun Feb 08, 2015 3:22 pm
- Mulger bill
Postby Mulger bill » Sun Feb 08, 2015 7:11 pm
That's only because I'm trying to get rid of the HTB, methinks the tub of each I have will see me out.
- Rob74
Postby Rob74 » Sun Feb 15, 2015 4:44 pm
Moreys-super-red-premium-EP2-waterproof-grease
Tech Data Sheet Moreys-super-red-premium-EP2-waterproof-grease
Timken OK Load = 32kg Minimum
$16 for 500g Tub
Have done the commuter hubs with it…..It is actually "translucent Red" in colour….the consistency is similar to Vaseline ie lighter than Castrol Boating Grease BUT very very tacky…the Shimano 105 hubs spin very smoothly with it......will see how it goes.
Also picked up some of this to try
MOREYS RED-i WATERSPORT MARINE GREASE
Tech Data Sheet RED– i WATERSPORT MARINE UTILITY GREASE
Timken OK Load = 39kg Minimum
$18 for 500g Tub
Its Blue in Colour and appears of similar consistency to Castrol Boating Grease
I'll try it out on the Cyclocross bike for Comparison.
Rob
Postby PatNZ » Sun Feb 15, 2015 5:02 pm
- Rob74
Postby Rob74 » Mon Feb 16, 2015 8:27 am
"Marine trailer bearing grease" is a very generic description.
Which Brand? & Type?...
Rob
- Rob74
Postby Rob74 » Sun Mar 20, 2016 7:28 pm
Penrite Marine Grease - Lithium Complex - NLGI2
500g
Product Code: MARGR0005
Green in Colour
NLGI Grade 2
Drop Point, °C 275
Base Oil Viscosity, ISO 220
Timkin OK Load, kg 23
4-ball Weld Load, kg 315
Continuous Operating Temperature, °C -15 to +170
Maximum Temperature, Intermittent use, °C 180.
Full strip & build of Bianchi rigid MTB done will see how it stands up.
Rob
Postby hedgehog » Sun Mar 20, 2016 7:49 pm
so i don't have to pull things apart.
tony
- Tim
Postby Tim » Mon Mar 21, 2016 8:21 am
I do recall seeing bike hubs and bottom bracket grease nipples on older bikes from my childhood.hedgehog wrote:i just wish that bicycle part manufacturer's put grease nipples on hubs,
Postby hedgehog » Thu Mar 24, 2016 10:23 am
Postby Roinik » Mon Mar 28, 2016 12:10 am
- Rob74
Postby Rob74 » Thu Mar 31, 2016 12:54 am
NLGI Grade 2
Drop Point, °C 280
Base oil viscosity ISO ?
Timkin OK Load, kg 25
4-ball Weld Load, kg 250
Continuous Operating Temperature, °C -40 to +205
Maximum Temperature, Intermittent use, °C 280.
Pro-Ma MBL grease
Spec Data
450g = $25.30 + shipping
2.5kg = $125
ok Roinik - something else to try if I can find it locally. Where do you suggest to purchase?
Rob
Postby Roinik » Wed Apr 13, 2016 6:06 am
- Dragster1
Postby Dragster1 » Thu Apr 14, 2016 1:13 pm
Postby Roinik » Thu Apr 14, 2016 9:27 pm
Postby hedgehog » Thu Apr 14, 2016 9:40 pm
on my car hubs i use a nm ratchet 3nm loosen then 1.5nm re tighten, on i bike ? i do the best i can not to over tighten
at the same time no side movement.
Postby Lurkin » Thu Apr 14, 2016 11:13 pm
- Rob74
Postby Rob74 » Sun Apr 24, 2016 6:17 pm
The problem with HTB is that it is bentone clay based & suffers washout/goes milky white for both my off road MTB & my all weather commuter. Push bike cup & cone bearings are not a “sealed bearing” despite the two fibre washers in Shimano 105 type cones that attempt to seal between the cone and the outer hub grease cup.
My experience has been that a Marine Grease offers superior performance over HTB, you just need to chose one. However the flow point of the marine greases discussed above vary. I often transport a bike in a car, in doing so the bike may be exposed to above 60 degrees and observe some extrusion of grease around the two fibre washers in Shimano 105 type cones that attempt to seal between the cone and the outer hub grease cup.
Finding a Marine Grease that is reasonably priced is the key. Castrol Marine Blue was used by many due to being readily available and relatively low cost, but it is no longer available, so this thread has become about what others are using and service experience.
Re Hedgehog “setting the cone pressure”
Agree that setting cone pressure is very important, noted also that QR Skewers put additional compression and making allowance for this is important.
Rob
- Dragster1
Postby Dragster1 » Wed Nov 09, 2016 1:10 pm
It lasts in automotive wheel bearings for over 40000kms if you are having trouble with it something is very wrong. I used it for years without problems.
Are you using a pressure cleaner on your bike or aiming the hose into your wheel bearings ?
- Nate
Postby Nate » Thu Nov 10, 2016 12:23 pm
Their chain oil is INSANELY good & i'll be getting their greases next
Postby hedgehog » Tue Nov 15, 2016 9:41 pm
Postby mitzikatzi » Wed Nov 16, 2016 6:12 pm
The just changed the name "marine grease" is now called http://www.castrol.com/en_au/australia/ ... -duty.htmlRob74 wrote:..snip..
..snip..
Rob
from viewtopic.php?f=34&t=91227&p=1363281&hi ... e#p1363281
- Rob74
Postby Rob74 » Fri Jan 27, 2017 12:33 pm
Noting previous post above "Rob74 » Sun Feb 15, 2015 3:44 pm
$16 for 500g Tub"
"translucent Red" in colour - Grease BUT very very tacky…the Shimano 105 hubs spin very smoothly with it......will see how it goes.
=>> I have switched to running Moreys-super-red-premium-EP2-waterproof-grease "translucent Red" in colour in all my bikes....Road Bike, Commuter, MTB etc. Its performance WRT washout & placed in car heated extrusion leaves it as the standout.
** Thanks very much to Bosvit per “bosvit » Thu Jun 28, 2012 12:34 am “ for the heads up*** …very impressed with this stuff it is a considerable improvement over the last of my Castrol Marine Blue Grease.
Rob
(No affiliation with with Morey's or any other, just very pleased with the results)
Postby Lurkin » Sun Feb 19, 2017 8:14 pm
I think I'll continue to use the moreys on the older bikes, but back to Shimano for the newer stuff.
