Lateral movement in rear wheel
Postby Pravda » Sun Jul 22, 2012 9:18 pm
Did my regular once over of the bike after a longish ride yesterday and noticed my rear wheel is wobbling slightly on its hub. Not buckled by the way, it's like the hub isn't attached tightly enough and it's getting about 10mm of movement side to side. I pulled the cassette and freehub off, checked them and put them back on but it's not changed. Any suggestions?
2011 Bianchi Via Nirone Veloce
Puegeot Aneto 105
Kona Jake the Snake CX
Pravda
by Forum Ads » Sun Jul 22, 2012 9:35 pm
Re: Lateral movement in rear wheel
Postby [email protected] » Sun Jul 22, 2012 9:35 pm
Pravda wrote:Did my regular once over of the bike after a longish ride yesterday and noticed my rear wheel is wobbling slightly on its hub. Not buckled by the way, it's like the hub isn't attached tightly enough and it's getting about 10mm of movement side to side. I pulled the cassette and freehub off, checked them and put them back on but it's not changed. Any suggestions?
my rear 90mm full carbon wheel does that to , it makes you think the wheel laterally flexes rubbing against the brake pads,dont no but it pi$$i$ me of thinking about it
[email protected]
Postby bychosis » Sun Jul 22, 2012 10:16 pm
Adjustable cones comes loose?
Postby Pravda » Sun Jul 22, 2012 11:14 pm
bychosis wrote:Adjustable cones comes loose?
This is probably what it is I'd imagine. Buggered if I know how it's happened though.
Puegeot Aneto 105
Pravda
Postby bychosis » Mon Jul 23, 2012 8:12 am
Had it happen to me/mates a few times. They just seem to need checking/adjusting reasonably often. Sometimes if there are no tool available winding them n by hand is enough to get back to the workshop without ruining your bearings.
Postby master6 » Tue Jul 24, 2012 6:14 pm
Wobbling slightly...........................10mm
I think we can delete "slightly". :cry:
master6
Postby jacks1071 » Tue Jul 24, 2012 9:38 pm
Probably need to get the axel out so you can have a propper look at it. Could be loose cones, could be a collapsed bearing or could be a broken rear axle.
jacks1071
Postby Pravda » Wed Jul 25, 2012 9:27 am
Axle is all fine, pulled it apart last night and it seems to be in order. Apart from the wobble. Exhausted my expertise on the subject so Im dropping it into the lbs today.
Sent from my GT-I9100 using Tapatalk 2
Puegeot Aneto 105
Pravda
Postby jacks1071 » Wed Jul 25, 2012 11:08 pm
Pravda wrote:Axle is all fine, pulled it apart last night and it seems to be in order. Apart from the wobble. Exhausted my expertise on the subject so Im dropping it into the lbs today.
I'm intersted to know what they find.
jacks1071
Postby Dr_Mutley » Thu Jul 26, 2012 1:28 am
Would help if we knew what sort of hub?
Ie zipp 188 hubs have some lateral play which is taken up when the wheel is vertically loaded (but not 10mm)... You adjust the lateral play by adjusting the bearing preload on the hub... If its a cone arrangement then given them a tighten and reassess
Dr_Mutley
Postby Crawf » Thu Jul 26, 2012 1:57 pm
Cartridge bearings knackered?
Crawf
Postby westab » Thu Jul 26, 2012 3:24 pm
Just in case it is a cone type bearing with loose balls - have you checked if there are the correct number of balls.
One of my mates had one of his bikes that was a ball short on each side and he adjusted and adjusted and adj..... then added one ball and adjusted and all was good.
Not fast, no style, but still get there.
westab
Postby Pravda » Thu Jul 26, 2012 4:19 pm
It was loose cones. Almost brand new campag Zondas - 300km or so and they worked loose. Appear to be all good now.
Puegeot Aneto 105
Pravda
Postby Burlo » Thu Jul 26, 2012 7:26 pm
Could possibly be the free hub needs tightening. Remove the axle and tighten the free hub.
Burlo
Postby RonK » Thu Jul 26, 2012 8:13 pm
westab wrote:One of my mates had one of his bikes that was a ball short on each side and he adjusted and adjusted and adj..... then added one ball and adjusted and all was good.
They are supposed to be like that...
Users browsing this forum: QuangVuong
