Page 1 of 1
Lateral movement in rear wheel
Posted: Sun Jul 22, 2012 9:18 pm
by Pravda
Did my regular once over of the bike after a longish ride yesterday and noticed my rear wheel is wobbling slightly on its hub. Not buckled by the way, it's like the hub isn't attached tightly enough and it's getting about 10mm of movement side to side. I pulled the cassette and freehub off, checked them and put them back on but it's not changed. Any suggestions?
Re: Lateral movement in rear wheel
Posted: Sun Jul 22, 2012 9:35 pm
by ranget@bigpond.com
Pravda wrote:Did my regular once over of the bike after a longish ride yesterday and noticed my rear wheel is wobbling slightly on its hub. Not buckled by the way, it's like the hub isn't attached tightly enough and it's getting about 10mm of movement side to side. I pulled the cassette and freehub off, checked them and put them back on but it's not changed. Any suggestions?
my rear 90mm full carbon wheel does that to , it makes you think the wheel laterally flexes rubbing against the brake pads,dont no but it pi$$i$ me of thinking about it
Posted: Sun Jul 22, 2012 10:16 pm
by bychosis
Adjustable cones comes loose?
Posted: Sun Jul 22, 2012 11:14 pm
by Pravda
bychosis wrote:Adjustable cones comes loose?
This is probably what it is I'd imagine. Buggered if I know how it's happened though.
Posted: Mon Jul 23, 2012 8:12 am
by bychosis
Had it happen to me/mates a few times. They just seem to need checking/adjusting reasonably often. Sometimes if there are no tool available winding them n by hand is enough to get back to the workshop without ruining your bearings.
Posted: Tue Jul 24, 2012 6:14 pm
by master6
Wobbling slightly...........................10mm
I think we can delete "slightly".
Posted: Tue Jul 24, 2012 9:38 pm
by jacks1071
Probably need to get the axel out so you can have a propper look at it. Could be loose cones, could be a collapsed bearing or could be a broken rear axle.
Posted: Wed Jul 25, 2012 9:27 am
by Pravda
Axle is all fine, pulled it apart last night and it seems to be in order. Apart from the wobble. Exhausted my expertise on the subject so Im dropping it into the lbs today.
Sent from my GT-I9100 using Tapatalk 2
Posted: Wed Jul 25, 2012 11:08 pm
by jacks1071
Pravda wrote:Axle is all fine, pulled it apart last night and it seems to be in order. Apart from the wobble. Exhausted my expertise on the subject so Im dropping it into the lbs today.
I'm intersted to know what they find.
Posted: Thu Jul 26, 2012 1:28 am
by Dr_Mutley
Would help if we knew what sort of hub?
Ie zipp 188 hubs have some lateral play which is taken up when the wheel is vertically loaded (but not 10mm)... You adjust the lateral play by adjusting the bearing preload on the hub... If its a cone arrangement then given them a tighten and reassess
Posted: Thu Jul 26, 2012 1:57 pm
by Crawf
Cartridge bearings knackered?
Posted: Thu Jul 26, 2012 3:24 pm
by westab
Just in case it is a cone type bearing with loose balls - have you checked if there are the correct number of balls.
One of my mates had one of his bikes that was a ball short on each side and he adjusted and adjusted and adj..... then added one ball and adjusted and all was good.
Posted: Thu Jul 26, 2012 4:19 pm
by Pravda
It was loose cones. Almost brand new campag Zondas - 300km or so and they worked loose. Appear to be all good now.
Posted: Thu Jul 26, 2012 7:26 pm
by Burlo
Could possibly be the free hub needs tightening. Remove the axle and tighten the free hub.
Posted: Thu Jul 26, 2012 8:13 pm
by RonK
westab wrote:One of my mates had one of his bikes that was a ball short on each side and he adjusted and adjusted and adj..... then added one ball and adjusted and all was good.
They are supposed to be like that...
