Page 2 of 3
Re: Speedplay - the good the great and the the ugly
Posted: Thu Aug 02, 2012 3:53 pm
by biker jk
bosvit wrote:Do you need speedplay specific shoes or can you get adaptors?
The adapter plate comes with the pedals so you can use three hole shoes but as mentioned Sidi now makes a speedplay version (which gives you lower stack height).
Posted: Thu Aug 02, 2012 5:55 pm
by bosvit
Thanks JK
Posted: Sun Aug 05, 2012 8:18 pm
by qeaou
twizzle wrote:NhiTrac wrote:Nah I dont service it due to the damage mentioned above so I thought it'll die on me at anytime, cept it kept on going! I'm literally running these into the ground so I can get a new pair, which I will look after properly
Assuming you don't have the CrMo spindles... buy the approriate Torx driver, buy a set of CrMo pedals (the 'cheap' version), swap the pedal bodies onto your spindles. It's an absolute bitch to get the bolts out of the spindles (loctite'd in place), but they always come out in the end.
And for everyone else...
Get this
grease gun.
Always use the
wear plate, even when using the plastic platform.
That is great advice buddy!
Thanks!
Long live the speedplays i guess
Posted: Mon Aug 06, 2012 3:59 pm
by hannos
or for your cheap mongrels out there (like me) there's
this grease gun.
Works just fine for me
Posted: Mon Aug 06, 2012 5:21 pm
by steve-waters
No grease gun using a cheap syringe from the chemist but just small one that fits in the grease port.
Posted: Mon Aug 13, 2012 10:04 pm
by qeaou
Adaptors!
and it sucks, but getting new shoes just to fit speedplays?
perhaps the best option, don't know.
On another note, big difference between stainless steel and titaniums?
Posted: Tue Aug 14, 2012 6:28 am
by twizzle
qeaou wrote:On another note, big difference between stainless steel and titaniums?
Mostly to your wallet. No real-world differences, anyway.
Sent from my iThingy...
Posted: Wed Aug 15, 2012 9:29 am
by Rex
steve-waters wrote:No grease gun using a cheap syringe from the chemist but just small one that fits in the grease port.
Yep, I've got a medium size syringe as you really need to squeeze the bejesus out of it to get the grease in there.
Then a tiny self tapping screw to seal it off when not in use.
The ugly - So my Speedplays have been getting quite wet of course and the screws that mount it to my shoes have been getting a little surface rust. When I get a mechanical and I can't avoid walking in sand, getting sand out of the pedals is a PITA. Getting the cafe covers off is very difficult at times, especially at 5am when it's freeking freezing with gloves on etc.
The good - Pedals are low profile and small.
The great - I have 100% confidence my shoes are never going to unclip. Easy to clip back on, as the pedals don't need to be 'flipped' (the biggest selling point for me as my Looks were TERRIBLE).
Posted: Thu Aug 16, 2012 9:58 pm
by Dr_Mutley
Here's a previous thread on getting grease into the SPs on the cheap...
U can see from the YouTube vid that it don't get much easier than that!
http://www.bicycles.net.au/forums/viewtopic.php?t=44598
Posted: Sun Sep 30, 2012 7:40 pm
by qeaou
From what I know, most people get adaptors (which come as a kit with new speedplay set)
I am considering myself the Sidi Ergo 3 speedplay ready (4 screws), but haven't got three yet, the regular 3 screw shows with adapters are doing just fine
Posted: Sun Sep 30, 2012 9:37 pm
by jacks1071
qeaou wrote:bosvit wrote:Do you need speedplay specific shoes or can you get adaptors?
Just a tip incase you were unaware, if you buy speedplay specific shoes, you need to order the stainless steel wear plate to go with them. I havn't seen these supplied with the shoes that I've seen. These stop your pedals from wearning a hole in your carbon sole, its basically a 1mm stainless steel plate that goes under your cleat.
Posted: Sun Sep 30, 2012 9:46 pm
by DaveOZ
Yes, I recently bought new Sidi Speedplay 4 hole shoes and was a bit disappointed not to receive the wear plate with either the shoes or pedals. Luckily I have a sheet metal shop and I made my own.
Posted: Mon Oct 01, 2012 9:26 am
by Dr_Mutley
DaveOZ wrote:Yes, I recently bought new Sidi Speedplay 4 hole shoes and was a bit disappointed not to receive the wear plate with either the shoes or pedals. Luckily I have a sheet metal shop and I made my own.
U could start selling them! I bet u could do them cheaper than what speedplay try and sell them for!
Posted: Tue Oct 02, 2012 9:14 am
by biker jk
Dr_Mutley wrote:DaveOZ wrote:Yes, I recently bought new Sidi Speedplay 4 hole shoes and was a bit disappointed not to receive the wear plate with either the shoes or pedals. Luckily I have a sheet metal shop and I made my own.
But then Speedplay would sue you like they did with the guy who was selling his own servicing kits (bearings, etc.).
Posted: Tue Oct 02, 2012 9:36 am
by Dr_Mutley
biker jk wrote:Dr_Mutley wrote:DaveOZ wrote:Yes, I recently bought new Sidi Speedplay 4 hole shoes and was a bit disappointed not to receive the wear plate with either the shoes or pedals. Luckily I have a sheet metal shop and I made my own.
Yes, but they would be for sidi shoes, not speedplay pedals
But I hear what yr saying, speedplay have been über pricks in the past wrt Frikinspit on WW and his bearing kits.
Posted: Tue Oct 02, 2012 12:24 pm
by twizzle
Don't suppose you would be up to the challenge of making the bottom plates in stainless? You could sell them individually, I only ever wear out my right hand bottom plate, it's pretty much the only reason I need to replace the cleats!
Posted: Tue Oct 02, 2012 2:22 pm
by DaveOZ
Which bit do you call the bottom plate? I don't have my Sidi shoes here so I'm not quite sure. The bit I made is called the wear plate in 0.7mm Stainless steel. I did make a few sets and gave a pair to Norbs. Surely they can't sue me if I make them for personal use and give them to mates.
Posted: Tue Oct 02, 2012 2:31 pm
by DaveOZ
Oh, You mean the plate on the bottom. Sorry I'm being thick.
May be able to make those. It worries me that the screw heads might wear down on mine to the point that they won't come out. I think they should be recessed a bit further. Actually titanium would be excellent for that bottom plate.
Posted: Tue Oct 02, 2012 2:46 pm
by twizzle
DaveOZ wrote:Oh, You mean the plate on the bottom. Sorry I'm being thick.
Ooooooh - weigh weenie as well! And you could do fixed-position holes to stop the cleats from moving across the shoe.
If you do go into production, you will move a stack of these - cleat replacement is something we all bitch about. I'd take two pair to start with, and a couple of spare 'right' plates, and I know someone else who would grab a pair plus spares as well.
Posted: Tue Oct 02, 2012 3:11 pm
by m@
twizzle wrote:DaveOZ wrote:Oh, You mean the plate on the bottom. Sorry I'm being thick.
+2 (pairs)!
(and I can hear SP's lawyers sharpening their pencils as we type...)
Posted: Tue Oct 02, 2012 4:29 pm
by Mulger bill
biker jk wrote:But then Speedplay would sue you like they did with the guy who was selling his own servicing kits (bearings, etc.).
Maybe they should rename their bits "iPedal"
Posted: Tue Oct 02, 2012 4:52 pm
by Dr_Mutley
The wear plate fits between the sole of the shoe and the cleat to stop the pedal wearing into the soles of carbon shoes... A thin plate on top of the cleat would prevent wear of the cleat when walking, and if your interested in that, then there is already a "leave on" device available to prevent wear and facilitate easier walking..
http://item.mobileweb.ebay.com/viewitem ... 0447214984" onclick="window.open(this.href);return false;
Posted: Tue Oct 02, 2012 6:31 pm
by geoffs
Here is a link to the local place to buy the cleat covers from
http://www.stevehoggbikefitting.com/sto ... at-covers/
Same price but Steve's local so I am presuming the postage wil be cheaper
Posted: Tue Oct 02, 2012 7:14 pm
by qeaou
I use the adaptors on sidi ergo 3 (ergo 3 also come with speedplay specific shoes, but I didn't bother)
No issues, just a higher profile, but that's that.
Posted: Tue Oct 02, 2012 10:27 pm
by twizzle
Sorry - "leave on" cleat covers negate the whole euro-cool feel.
Plus... the beveled edge that guides the pedal into the c-spring eventually wears and makes it hard to clip in.
