Grooved steerers and loose headsets
Postby familyguy » Sat Aug 04, 2012 8:15 am
Toni-bike has a non-grooved steerer tube. Could this be contributing to the headset constantly coming loose? No matter whether I use a washer or not, or in spite of tightness, 30 minutes into a ride it comes loose. It's a 600EX wavy jobbie.
I'm debating about grabbing the dremel-like object out of the cupboard and putting a groove in it. Bad idea?
by Forum Ads » Sat Aug 04, 2012 12:05 pm
Re: Grooved steerers and loose headsets
Postby Mulger bill » Sat Aug 04, 2012 12:05 pm
I'd exhaust all possibilities before giving power tools a run Jim.
Are you sure all parts are assembled correctly? One item in backwards or upside down will bring this on. Go on, ask me how I know... :oops:
Shaun
Postby RonK » Sat Aug 04, 2012 2:21 pm
What is a grooved steerer? The steerers on all my bikes are definitely not groovy.
Postby darkhorse75 » Sat Aug 04, 2012 2:43 pm
I think the OP means a slot in the threaded section of the steerer.
darkhorse75
Postby familyguy » Sat Aug 04, 2012 4:20 pm
Er, yes, the groove that runs vertically up a threaded steerer tube. Is it a notch? Slot? Recess? Thingy?
Will try some grease, assembly paste/liquid torque and see if that solves it. Seeing the top nut is rather soft aluminium, I wouldn't be surprised if its been over tightened and rendered useless.
Postby Mulger bill » Sat Aug 04, 2012 7:45 pm
Sheldon calls it a keyway :wink:
I take it the washer is keyed?
Postby Nobody » Sat Aug 04, 2012 8:09 pm
If all else fails, maybe get a threadless fork, headset and stem. I think the Aheadset (threadless) system was a step forward in this regard.
Nobody
Postby familyguy » Sat Aug 04, 2012 8:45 pm
Absence of keyway meant I had to put in a round washer, no key. Didn't make a lick of difference anyway, still came loose.
If I can find a threadless 1" 531 or equivalent fork with eyelets going cheap, I'd consider changing over :)
