Cross threaded freewheel
AP81
Postby AP81 » Fri Sep 07, 2012 11:16 pm
I was recently given a set of near new Alex R540 wheels from a mate who upgraded his wheelset. After removing the freewheel to replace it with a bigger one, I noticed all the threads are damaged. There is no way another freewheel can go on it.
I've now got two options- use it fixed (no thanks), or replace the entire hub. I can get another identical hub for around $35, but have never built a wheel before. Is this worth doing? Seeing as they were free, I don't mind spending some money on them.
Steel - is - real
Re: Cross threaded freewheel
Postby bychosis » Sat Sep 08, 2012 7:16 am
Wheel building can be a frustrating and rewarding experience.
http://www.bicycles.net.au/forums/viewtopic.php?f=34&t=55616
darkhorse75
Postby darkhorse75 » Sat Sep 08, 2012 12:01 pm
Assuming it's a single speed flip flop hub just screw the freewheel onto the fixed side and you're good to go.
drumondo
Postby drumondo » Sat Sep 08, 2012 1:55 pm
How bad is it? Can you run a tap through the thread to clean it up to a usable level?
AP81
Postby AP81 » Mon Sep 10, 2012 9:41 am
darkhorse75 wrote:Assuming it's a single speed flip flop hub just screw the freewheel onto the fixed side and you're good to go.
Thanks, didn't even think of that
drumondo wrote:How bad is it? Can you run a tap through the thread to clean it up to a usable level?
Upon closer inspection, thre threads aren't actually that damaged. After cleaning the grease out, the threaded sections came out with it.
I managed to screw a dicta freewheel on it with no issues (no lateral play). I guess I'll run with this for now, and if it plays up I'll switch it to the fixed side.
Thanks for the help.
Steel - is - real
