How much difference should there be between your tyre wear between front and back?
I am about to replace my back tyre after about 2500km and the front looks like it will go another 2500km at least. Are these good km's to achieve?
Difference in tyre wear
• Page 1 of 1
Difference in tyre wearHow much difference should there be between your tyre wear between front and back?
Re: Difference in tyre wearWith Continental GP4000S's I get about 6000km out of a front tyre and about 4000km out of a rear. That is if that don't get destroyed by road debris.
John Beaven
2009 Giant CRX2 2010 Malvern Star Oppy C6
I wonder if the weight of the rider makes a difference? I was about 100kg to start and am now 70kg, so hopefully this will increase the wear
Re: Difference in tyre wear2,500km is pretty poor for a rear tyre. I got 4,500km out of a 23mm Vittoria Rubino back when I was >105kg... but I don't replace my tyres until the cotton is showing.
volutamus scandemus
I am going to try to hold off until the Brisbane to Gold Coast and then run a brand new one for that ride. I will stick to my method of applying super glue to all cuts I get. This morning I removed 3 pieces of glass from the tyre and glued the holes.
Re: Difference in tyre wearActual k's I'm not sure of, but my rear definitely wears much faster than the front. When the rear needs replacing, I rotate the front to the rear and put the new one on the front. I find the rear gets quite squared off.
Re: Difference in tyre wearHow long is a piece of string?
As for actual kilometres from a tyre: That depends of a number of factors such as type of tyre, rider weight, riding style, conditions of road surface & etc. I have had tyres that last from 2,000 kilometres (road tyres) to over 12,000 kilometres (touring tyres). I generally go through 2.5 rear tyres for every one on the front.
twice the distance from the centre to the end
• Page 1 of 1
