Disc rotor bolts, threadlock or not?
Postby simonn » Tue Sep 11, 2012 10:11 am
Building my first disc wheel and having never replaced a rotor either should I use a low strength thread locker on the bolts?
After taking the rotor I am using off the original crappy formula hub it looks like the bolts had threadlock on.
simonn
by Forum Ads » Tue Sep 11, 2012 10:31 am
Re: Disc rotor bolts, threadlock or not?
Postby Nobody » Tue Sep 11, 2012 10:31 am
The bolts should come with a kind or dried thread locking compound on them. If reusing the bolts, it is a good idea to put some low strength thread locker on.
Nobody
Postby jacks1071 » Tue Sep 11, 2012 12:55 pm
Nobody wrote:The bolts should come with a kind or dried thread locking compound on them. If reusing the bolts, it is a good idea to put some low strength thread locker on.
What he said :-) You should torque them as well to ensure they are even and also to avoid over or under tightening them, they will strip easy if you over-do them.
jacks1071
Postby jules21 » Tue Sep 11, 2012 3:02 pm
i reckon you can re-use the thread lock - assuming you are re-using the bolts. it won't adhere anymore, but it still dampens the vibration which leads to bolts loosening.
jules21
Postby simonn » Tue Sep 11, 2012 3:07 pm
jules21 wrote:i reckon you can re-use the thread lock - assuming you are re-using the bolts. it won't adhere anymore, but it still dampens the vibration which leads to bolts loosening.
I've got some threadlock at home so no worries.
Thanks everyone.
simonn
Users browsing this forum: bychosis, Gassy
