Black grease coming out of front fork join
Postby auswi2 » Mon Sep 17, 2012 8:16 am
Hello,
I went for a ride this morning and I noticed some black grease sitting just below the front fork join on my road bike. The bike had been sitting for a few weeks in the garage prior to be ridden.
Is this normal??
I have a Carbon road bike 105
Any suggestions would be great
auswi2
auswi2
by BNA » Mon Sep 17, 2012 9:32 am
Re: Black grease coming out of front fork join
Postby cyclotaur » Mon Sep 17, 2012 9:32 am
Get an exorcist.
"Riding not racing...."
cyclotaur
Postby auswi2 » Mon Sep 17, 2012 9:53 am
If you are going to put stupid comments do it somewhere else
auswi2
auswi2
Postby rkelsen » Mon Sep 17, 2012 9:55 am
Check that the headset isn't loose.
volutamus scandemus
rkelsen
Postby cyclotaur » Mon Sep 17, 2012 10:06 am
auswi2 wrote:If you are going to put stupid comments do it somewhere else
auswi2
.... aw c'mon ... lighten up - Monday-itis ....?
Like rkelsen said, check the headset isn't loose - you might find some perspective in there as well. :P
cyclotaur
Postby DavidL » Mon Sep 17, 2012 10:15 am
Needs to be cleaned up immediately as it detracts from the visual appeal of the bicycle and has been known to cause people to think your not a real cyclist as you bike isn't "just purchased" clean and looking very expensive.
But other than that, if you are going to ride your bike this will happen. Most headsets aren't sealed and small amounts of grease will come out. If there is a big lump of grease that has come out then maybe the last mechanic to service this was over excited with the quantity of grease put in there but other than that all should be fine.
You might be able to reduce the amount of grease that comes out by using one of the thicker Teflon products available for bikes, but if packed with you garden variety wheel bearing grease happens all the time.
DavidL
Postby JustJames » Mon Sep 17, 2012 11:11 am
auswi2 wrote:The bike had been sitting for a few weeks in the garage prior to be ridden.
Is this normal??
No - you definitely need to ride your bike more.
My bike blog. Long on rumination, rambling and opinion. Why let facts ruin everything?
JustJames
Postby auswi2 » Tue Sep 18, 2012 10:59 am
Thanks for your help
auswi2
auswi2
Postby burger » Wed Sep 19, 2012 12:20 pm
JustJames wrote:
auswi2 wrote:The bike had been sitting for a few weeks in the garage . .
Is this normal??
:lol:
The world is round, so what seems like the end may actually be the beginning.
burger
Postby jacks1071 » Wed Sep 19, 2012 4:08 pm
auswi2 wrote:Hello,
Is this normal??
auswi2
Assuming headset is not loose, it will just be a combination of wind and gravity pulling some of the grease out of your headset. If you don't ride in the rain the headset should get re-greased at least once per year. If you ride in the wet a lot then its a more regular job if you want to look after it...
If the black grease stops comming out, it maybe a sign there is not much left in the headset.
jacks1071
Users browsing this forum: ZepinAtor
