Rear brakes have become innefective
Postby ozstriker » Tue Sep 25, 2012 6:48 pm
I am running an ultegra group set with 1100 k's on it and I have recently done a few long fast decents, and my rear brake has become almost completely useless.
Could I have glazed the pad, I have checked the rim and haven't noticed any oily residue on it, and my front brakes are still working relatively well?
Thoughts?
ozstriker
by BNA » Tue Sep 25, 2012 7:21 pm
Re: Rear brakes have become innefective
Postby Reman » Tue Sep 25, 2012 7:21 pm
Try cleaning the rims with acetone or metho, I've found that helps remove any oily residue (especially what you can't feel).
Otherwise maybe dial out the levers so you get more leverage, or your brake cables have stretched and need to be reseated or replaced.
Reman
Postby R12RT » Tue Sep 25, 2012 7:49 pm
You could try lightly sanding the pads.
I've had success with this in the past to improve brake performance.
John Beaven
2009 Giant CRX2
2010 Malvern Star Oppy C6
R12RT
Postby open roader » Tue Sep 25, 2012 8:21 pm
R12RT wrote:You could try lightly sanding the pads.
+1
Sand them face down on some very fine emery paper and make sure the emery paper is dead flat to ensure an even cleaning. I'd also clean the brake track with metho or acetone.
open roader
Postby Stepr » Tue Sep 25, 2012 8:34 pm
yeah reface the brake pads on a smooth file, and give the rims a going over with metho and 0000 (4 zero) steel wool lightly
Stepr
Postby jacks1071 » Tue Sep 25, 2012 10:24 pm
A metal file is best for this - you can do it in the bike and it doesn't take much to take the glaze off.
I'd also wipe down the rims with metho or similar incase you've got oil or grease on them.
jacks1071
Postby jules21 » Wed Sep 26, 2012 1:35 pm
check that the pads are mating properly with the rim surface. as pads become worn, the caliper arc gets longer and this can result in the pads making contact with the rim lower down. if the bottom of the pad clears the rim braking surface, you'll get uneven pad wear and reduced braking performance.
jules21
Users browsing this forum: grantw, xx68, ZepinAtor
