upload pictures
How to maintain this chain? (pic inside!)
• Page 1 of 1
How to maintain this chain? (pic inside!)Hi team, what do I do to this? I took the best pic I could to describe the overall condition.
![]() upload pictures
Re: How to maintain this chain? (pic inside!)It looks ok to me - I'd give it a liberal flush with Rock'n'Roll Gold, wipe off the excess, and ride...
Re: How to maintain this chain? (pic inside!)Best way to clean the chain (for me and no doubt everyone has a different technique) is with some citrus cleaner and a toothbrush. I spray the cleaner on the chain on the bottom section of the chain stay so it will drip directly out on the ground (lawn as I clean the bike outside) then spin the crank a bit, spray and scrub again with the toothbrush until you have gone all around. Et into the cassette while you are at it and the jockey wheels on the RD as well. Then wash it all off and I dry the chain with a rag then let it air dry for a few hours or overnight then relube and voila . This should get you on your way for a much smoother gear change also
Plus one. Should take less than 5min. Would only go to greater measures if it is not moving freely. Cleaned plenty that look like that after a mud run on the MTB and only used Rock n Roll in the last couple of years. bychosis (bahy-koh-sis): A mental disorder characterised by symptoms, such as delusions or hallucinations, that indicate impaired contact with reality not containing bicycles.
Re: How to maintain this chain? (pic inside!)Looks like a normal amount of gunk. Chains do pick up gunk.
I wash mine once a month by soaking it in kero, using toothbrush to clean it and then I let it dry. After this I too use Rock and Roll gold to lubricate and off we go. Since my bike is for commuting the chain and bike can get dirty so can do with a clean once a month. DS Riding: Cannondale Quick Speed 2
+1 this is good advice, if you use rock and roll lube you'd probably be flat out needing a propper clean once a month. Our Website is: http://www.pro-liteoz.com Find us on Facebook by searching for "Pro-Lite Australia"
Re: How to maintain this chain? (pic inside!)Meh, scrube the bejabbers out of it with kero and toothbrush, apply Purple Extreme. Ignore for 4-500 kms
Re: How to maintain this chain? (pic inside!)Sheldon gives you the only method guaranteed to get a clean chain http://sheldonbrown.com/chainclean.html
+ 1 or otherwise degrease the chain and relube. Not a bit issue either way by the looks of it. Andrew
• Page 1 of 1
Who is onlineUsers browsing this forum: Bah77, Farmer Elvis, ikm, jules21 |
