Rim Tape!
Rim Tape!
Postby ningnangnong » Fri Oct 05, 2012 12:18 pm
Hey fellas, just wondering... is this 'fixable', or do I need to get myself some new rim tape? Not fussed if I can't salvage it, as it's one of the cheaper parts out there. :)
It's folded in like that for roughly 10cm, then the rest is fine. I'm guessing the tape has come unstuck somehow? Would I have caused it having my tyre pressure too high or something?
Anyway, if I need to get some more, I understand the recommendation is to get Velox?
ningnangnong
by Forum Ads » Fri Oct 05, 2012 1:03 pm
Re: Rim Tape!
Postby JustJames » Fri Oct 05, 2012 1:03 pm
Rim tape is not adhesive.
Unless you've found a way to make air pressure directional, either it was always like that or a tyre lever would be my prime suspect.
I'd just unfold it and boogey on.
My bike blog. Long on rumination, rambling and opinion. Why let facts ruin everything?
JustJames
Re: Rim Tape!
Postby ningnangnong » Fri Oct 05, 2012 1:07 pm
Ah, fair enough then... probably a stray tyre lever. I've tried unfolding it, but it just folds itself back the second I let go.
ningnangnong
Re: Rim Tape!
Postby familyguy » Fri Oct 05, 2012 1:47 pm
JustJames wrote:Rim tape is not adhesive.
Unless you get the cloth stuff with the adhesive backing.
New stuff will cost you about $5 a wheel. Always worth doing to replace that plastic stuff IMHO.
Re: Rim Tape!
Postby bychosis » Fri Oct 05, 2012 2:33 pm
Just run some electrical tape over it to hold it down.
Re: Rim Tape!
Postby Mulger bill » Fri Oct 05, 2012 7:34 pm
And order some Velox for when it becomes needful...
Re: Rim Tape!
Postby ldrcycles » Fri Oct 05, 2012 7:52 pm
or use 5 layers of masking tape (did that once when i was caught out :) ).
Users browsing this forum: petal665
