Page 1 of 1
Rim Tape!
Posted: Fri Oct 05, 2012 12:18 pm
by ningnangnong
Hey fellas, just wondering... is this 'fixable', or do I need to get myself some new rim tape? Not fussed if I can't salvage it, as it's one of the cheaper parts out there.
It's folded in like that for roughly 10cm, then the rest is fine. I'm guessing the tape has come unstuck somehow? Would I have caused it having my tyre pressure too high or something?
Anyway, if I need to get some more, I understand the recommendation is to get Velox?
Re: Rim Tape!
Posted: Fri Oct 05, 2012 1:03 pm
by JustJames
Rim tape is not adhesive.
Unless you've found a way to make air pressure directional, either it was always like that or a tyre lever would be my prime suspect.
I'd just unfold it and boogey on.
Re: Rim Tape!
Posted: Fri Oct 05, 2012 1:07 pm
by ningnangnong
Ah, fair enough then... probably a stray tyre lever. I've tried unfolding it, but it just folds itself back the second I let go.
Re: Rim Tape!
Posted: Fri Oct 05, 2012 1:47 pm
by familyguy
JustJames wrote:Rim tape is not adhesive.
Unless you get the cloth stuff with the adhesive backing.
New stuff will cost you about $5 a wheel. Always worth doing to replace that plastic stuff IMHO.
Re: Rim Tape!
Posted: Fri Oct 05, 2012 2:33 pm
by bychosis
Just run some electrical tape over it to hold it down.
Re: Rim Tape!
Posted: Fri Oct 05, 2012 7:34 pm
by Mulger bill
And order some Velox for when it becomes needful...
Re: Rim Tape!
Posted: Fri Oct 05, 2012 7:52 pm
by ldrcycles
or use 5 layers of masking tape (did that once when i was caught out
