Velo Saddle Bolt Source
as7431
Postby as7431 » Thu Oct 18, 2012 12:39 am
Hi all
Broke the saddle bolt today on my velo saddle - the both that hold the clamp that grips the saddle rails. Had to ride the remaining 7km of my commute standing up - not fun! The bolt is an M8 x 1.0 (that is fine pitch thread), and has a curved base to the head which locates into the curve of the seat post. Anyone know where I can get one in Perth or online? For now I have a conventional socket cap bolt, which got me home, but the contact area with the seat post is not great.
Any ideas?
Tim
open roader
Re: Velo Saddle Bolt Source
Postby open roader » Sat Oct 20, 2012 10:43 pm
The bolt that holds the clamp that grips the saddle rails is actually part of the seat post - the seat post clamp tension bolt.
Should not be difficult to find a replacement - can you post up a pic illustrating the curved base to the head which you describe?
If not try searching Probolt Australia
http://www.probolt-australia.com/
as7431
Postby as7431 » Mon Oct 22, 2012 6:39 pm
Open Roader
You are correct - no idea what I was thinking assuming it was part of the saddle!! Clearly it is not. I blame the 7km of stand-up riding.
The seat post. I think is one of these
I need the nut with the little serrations on it.
Tim
JustJames
Postby JustJames » Tue Oct 23, 2012 9:33 am
Oxygen debt is still impairing your cognitive functions. 8)
The serrated part is a "washer" for want of a better word between the head of the bolt and the seat post. On my bikes it is an allen headed machine screw. (Technically a bolt is only threaded at the end.)
My bike blog. Long on rumination, rambling and opinion. Why let facts ruin everything?
as7431
Postby as7431 » Tue Oct 23, 2012 12:05 pm
JustJames wrote:Oxygen debt is still impairing your cognitive functions. 8)
No doubt impaired and let's blame the oxygen debt :D
JustJames wrote:The serrated part is a "washer" for want of a better word between the head of the bolt and the seat post. On my bikes it is an allen headed machine screw. (Technically a bolt is only threaded at the end.)
Agreed - I have a bolt at the moment (only machined at the end) but no washer - I need a source for the washer (and probably something better than a mild steel bolt)
Tim
JustJames
Postby JustJames » Tue Oct 23, 2012 12:13 pm
This is one of those cases where your LBS is more useful than the interwebz.
Pop along to your LBS with the wreckage...they will prolly have what you need in a box somewhere.
