new road wheel/cassette question
Postby jjcp » Sat Oct 20, 2012 6:16 am
Hi All,
A newbie question.
So after purchasing my first new set of road wheels. I decided to mix the gearing and bought a new cassette aswell. Now here is the question/problem: 1) why is the middle part of the cassette loose? i have tightened it according to the shimano intructions.Do i need spacers? 2) it wont shift to the biggest cog. Do i need to adjust the rear derailleur? 3) there are some noise when shifting up/down. I am pretty sure its the chain rubbing against the cassette.
Here are the specs:
Groupset: Full Ultegra 6700, cassette: 12-25
New cassette: 11-23
thanks all
jjcp
by BNA » Sat Oct 20, 2012 8:41 am
Re: new road wheel/cassette question
Postby Bentnose » Sat Oct 20, 2012 8:41 am
Are you sure you aren't missing some spacers in the middle, I just put a new Ultegra cassette on my bike and it was nearly all loose sprokets with loose spacers in between, can you see a spacer between every cog?
Bentnose
Postby open roader » Sun Oct 21, 2012 2:10 pm
+ 1 spacer placement most likely.
Check, check, double check......?
A 25 tooth cog is not going to create a chain / cage length issue and the rear derailleur should maintain it's alignment if you are switch between like for like cassettes. My guess without seeing the set up is that the biggest cog (25t) is set too far into the hub for the rear derailleur to engage meaning a cog spacing issue..........
open roader
Postby jjcp » Mon Oct 22, 2012 11:12 am
it looks like I need a mavic spacer instead of the shimano ones.
jjcp
Postby biker jk » Mon Oct 22, 2012 7:06 pm
When I changed a cassette on a friend's Mavic rear wheel (some time ago now) I had to use both the Mavic spacer and the Shimano spacer.
biker jk
