Any suggestions welcome.
Rear Sprocket removal
• Page 1 of 1
Rear Sprocket removalCan't do it
Re: Rear Sprocket removalI think it was Sheldon brown that suggested put the tool in a vice and use the wheel to undo it rather than a spanner.
Re: Rear Sprocket removalI like sheldon's idea. But I've got this set:
![]() works really well (use it all the time)
Re: Rear Sprocket removalIt's not spinning, or budging for that matter. The wheel and all it's components don't seem rusty at all so it's got me beat at the moment. I have a vice a work so I may try that.
Re: Rear Sprocket removalI bought a second hand wheel and could not get the sprocket off it. I tried my chain whip, and a vice, it still would not budge.
Then I bought one of these: http://i872.photobucket.com/albums/ab288/mickho/PedrosViseWhiptool.jpg Pedros make it, was designed by Leonard Zinn. An example of true genius, what an amazing world we live in.
so i gather it locks into the smaller sprockets? awesome
That looks way cool. Is the point of it to apply as much force as possible and where did you get it from?
Re: Rear Sprocket removalIt locks onto the cassette so that you have a firm hold.
http://www.youtube.com/watch?v=wuuZYN6POPo I bought mine from Wiggle.
Thanks very much.
Thats the way to go. Took wheel to work, tool in vice and 5 seconds later. Voila!
My commuter had a cassette that I could not remove, not sure why as I use a torque wrench to tighten to correct setting. Tried and tried and bent the chain whip so it was useless. I bought the Pedros tool but have found its not long enough. For a really tight lockring you cant get enough leverage on it. I ended up putting a steel bar on the end of it and off came the cassette. Its good, but could be better with a longer lever arm. Would I buy again? Well I was not going to get the cassette of any other way, but for the price it could be better.
Re: Rear Sprocket removalI use standard 1/2" square drive rear cassette removal socket.
Hook it up to a 30cm standard car breaker bar for the hard one. Never fail.
• Page 1 of 1
Who is onlineUsers browsing this forum: liamw |
