Shimano Freewheel on Record Hub
Postby igstar » Mon Oct 22, 2012 9:01 am
As the topic suggests, is it possible to fit a Shimano Freewheel on a Record Hub?
igstar
by Forum Ads » Mon Oct 22, 2012 9:25 am
Re: Shimano Freewheel on Record Hub
Postby stanzarallyman » Mon Oct 22, 2012 9:25 am
no, but I believe you can get a campy freewheel with a shimano spline pattern.
stanzarallyman
Postby jacks1071 » Mon Oct 22, 2012 10:06 am
I'm pretty sure you can get a 10sp Campy cassette to work fine with a Shimano groupset although I've never done it, that'd be your cheapest option.
The gear spacing is the same so other than some initial adjustments of the limit screws I can't see it being a problem.
jacks1071
Postby ironhanglider » Mon Oct 22, 2012 10:32 am
Stan and Deon have answered the question that you likely meant to ask. If you have a Record Freehub you would need to either get a Shimano pattern freehub body, or you can use different spacers to make a Campag Cassette mimic a Shimano Cassette or various other kludges.
The answer to the question that you actually asked is yes. Shimano freewheels and more recent (at least since the 70s) Campag hubs both used standard ISO threads, so a Shimano freewheel will screw straight on to a Record Hub. This supposes that you are dealing with 20+ year old equipment. (Sheldon on Freewheel vs Freehub)
http://www.sheldonbrown.com/freewheels.html
Cameron
ironhanglider
Postby petal665 » Mon Oct 22, 2012 12:21 pm
Depending on the age of your Record hubs, you buy the Campy freehub with Shimano spline (I'm sure that is what you meant anyway). The Campag one is hard to find but the Fulcrum one is EXACTLY the same and easy enough to get. I have one in my cupboard at home, but you can't have it. :)
petal665
Postby igstar » Mon Oct 22, 2012 1:13 pm
Thanks for all your help. After doing some homework on the internet, it turns out the answer is no. While many wheel and hub manufecturers offer Shimano and Campag compatible freebodies to be fitted, Record hubs (2010) only allow Campag freebody. I think I'll just use the Campag cluster till I get a new wheel and see how it rolls.
igstar
Postby petal665 » Mon Oct 22, 2012 1:36 pm
Rubbish. This works on the current black record hubs, I have done it.
petal665
Postby usernameforme » Mon Oct 22, 2012 2:51 pm
Get a Jtek shiftmate and use a campag cassette on your shimano group
___________________________
Giant Defy Advanced 0
Shogun Katana
usernameforme
Postby toolonglegs » Mon Oct 22, 2012 3:00 pm
I used a 10 speed campy cassette on my disc rear wheel with a dura ace drive chain... Ran beautifully.
Postby igstar » Mon Oct 22, 2012 4:21 pm
petal665 wrote:Rubbish. This works on the current black record hubs, I have done it.
I was just talking a to friend at work who had Fulcrum wheels and I remembered they are Campag owned company - I'll borrow the freehub off him to try it out.
toolonglegs wrote:I used a 10 speed campy cassette on my disc rear wheel with a dura ace drive chain... Ran beautifully.
And glad to hear this should work.
igstar
Users browsing this forum: Ben82, Bing [Bot]
