Head tube issues.
Head tube issues.
Postby teamex » Tue Oct 23, 2012 3:35 pm
Hey Guys,
I've recently had a frame powder coating and went to being rebuilding the head unit. and it appears with the power coating one or two parts no longer fit in the head tube. I was thinking about doing some filing, but i don't want to damage the paint work (after already clumisly putting a small ding it with my own handy work).
Is there another potential way to do this?
I though about maybe putting the parts in the freezer for a while to see if they would squeeze in after that
teamex
by BNA » Tue Oct 23, 2012 3:41 pm
Re: Head tube issues.
Postby twizzle » Tue Oct 23, 2012 3:41 pm
Find someone with the correct reamers. A frame builder will have them.
I ride, therefore I am.
twizzle
Postby elantra » Thu Oct 25, 2012 4:04 pm
Yes this is frustrating !
But surely if they are the same parts you took out, then it is due to some excess paint that can be scraped off from the inside of the headtube
If it is more than that and there is no urgency, as Twizzle has suggested, go to a framebuilder.
But if you are prepared to take a slight risk, get a metal file, preferably one with a slightly curved face.
But be careful. metal file
Favorite bike - whatever i am riding, as long as it has indexed downtube shifters
elantra
Postby jacks1071 » Fri Oct 26, 2012 3:20 pm
twizzle wrote:Find someone with the correct reamers. A frame builder will have them.
Shops with an expert mechanic should have them as well.
jacks1071
Postby il padrone » Fri Oct 26, 2012 10:07 pm
Yep, if you're worried about filing it yourself then your LBS would be the best place to go. If they're not too busy they'll have the headset in, fitted and set correctly inside half an hour.
Postby teamex » Thu Apr 18, 2013 7:03 pm
this is going back away.. moved house so the bike was packed up..
the other day i pulled it back out, fixed the above issue, however now i realise that in the painting the chrome (?) spacer at the top of the forks that separate them from the head tube has been lost.
any idea of how to replace?
teamex
Postby Mulger bill » Thu Apr 18, 2013 7:20 pm
teamex wrote:this is going back away.. moved house so the bike was packed up..
Let's make sure we're talking the same bit here...
Thank you Sheldon.
Users browsing this forum: bosvit
